Was it a genuine toner cartridge? I bought some aftermarket ink cartridges for my canon. The colour one was OK but the black... The printer kept saying black empty. I put my nearly empty genuine one back and the fault disappeared. Put the copy one in and same result. I bought a genuine black and no problem.
sc582 is an inverter error. The coil that heats the fuser may be bad, or there may be a bad connection somewhere. If you go into SP mode and execute SP 5810 to reset the fuser, see if the code comes back. If it does, have a Ricoh technician check the IH coil and the connections for it.
There are many counters in this machine. Jam, Error, Feed, All, Memory, Service Codes etc, that are located in the service software of the machine. If you don't know what each one does you can end up doing more harm than good by wiping out the wrong ones. Best to call a trained tech.
Mr Aziz, the machine tell you the termistor had to be replaced located at the back of the fuser unit.After replaced it ,you have to reset the maschine in SP mode.....good day
once again the tech boyz mix up the formula ssl is a device unique identifier technology which has many permutations i'd expect it will take an act of God to get gmail apps to do this for a single device, and Ricoh is not in that business
keep an eye on the gmail apps forums and you might get lucky
