Question about Canon CanoScan 4400F Flatbed Scanner
Trying to make a copy- worked last week?
Unable to scan. make sure enough space on target disk????
I had the same problem and solved it like this:
I found out that the directory of Toolbox 5.0 (usually \Program files\Canon\CanoScan Toolbox Ver5.0)contains an outdated library module called "Msvcrt.dll" dated 02/03/1999. This file in my Windows XP home edition located in \Windows\system32 is much more recent (april 2008 !!!).
I replaced the old file with the newer one and now my Canoscan 4400f works fine.
It is also possible to download separatly from Internet a newer version of this file "Msvcrt.dll"
Maybe this solution will be helpful for some users.
frenchflyman
Posted on Oct 27, 2008
    Scholar:
  • 111 Answers
This is most likely only happening when attempting to scan through the CanoScan Toolbox. You can scan directly through ArcSoft PhotoStudio which came with the scanner. However, the error through Toolbox is likely caused by some limitation or restriction in the computer, possibly permissions of some sort. You may try deleting temp files from the Temp folder on the hard drive.
Posted on Jul 28, 2008
Why is there an error message: Space Not Enough when trying to copy DVD?
There is some space reserved for dvd information, error information etc. So solution is make the file archive by right click on file ->proprties-> click archive. After that use winrar and compress. http://www.rarlab.com/download.htm
Aug 22, 2013 | EZ Dupe Computers & Internet
I have a canon dr 5020 that just started scanning slowly
Check if there is enough disk space in the comp target area. Run defrag and scandisk.
S. Mohan, india
Mar 01, 2013 | Canon DR-5020 Path-Through Scanner
Scanner sends message "Unable to scan. Make sure there is enough space on target disk"
Check the resolution settings.  If you're trying to scan at 9600dpi, the image will be huge, it may not fit into ram either, so the swap file would be used and you would need twice the file space to scan the image.
Scanning at 600dpi is generally fine enough for most uses (300 or less for web use), including scanning photographs (you may want to scan negatives at 1200 though.)
JBV^_^
Sep 01, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Unable to scan, Make sure there is enough space on the target disk, There is about 200 GB.
check for disk partition permission, be sure you have full permission access.
Apr 07, 2010 | Canon CanoScan 4400F Flatbed Scanner
Unable to scan.make sure there is enough space on the target disk
Do a "reset".
•Go into the CanoScan toolbox,
•click Settings,
•click the Defaults button on the bottom
•then click OK.
It will take a few seconds to reset and you should be good to go.
Jan 24, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Error message: Can not scan. Not enough space on target disk
I have just cured this"not enough space on the target disc" on my set up.I had the problem from day one after buying scanner but learned to get around it.Today I went into Toolbox and opened settings and made a note of the target address. Then checked properties of the target folder and found there was 86mb in a space for 80mb.This was the default setting chosen by the installation programme. I went to my documents and made a new folder and called it Canoscan, clicked ok and it became the new target and the fault is gone. Hope it works for others.
Dec 29, 2008 | Canon CanoScan 4400f MultiFunction Color...
Won't scan - says not enough disk space.
I had the same problem. Solved it by going into the "CanoScan Toolbox" - "Settings" - and pressing the "Defaults" button in that panel - and then "OK" button. Afterwards everything worked fine. Hope this helps you.
Dec 18, 2008 | Canon CanoScan 8600F Flatbed Scanner
Scanning problem with a CanoScan8600F
Hi
 go to the your scanner properties please see there your current path.. and change the the path.. select your free hardisk space..which driver you've free space.. ther only stored you're all documents...
it will work
Nov 18, 2008 | Office Equipment & Supplies
LiDE 600DF - Unable to scan
Hi Peter
Have had the same problem, seems to come and go a bit... Quickest & easiest fix is to go to CanoScan toolboox > Settings then press the 'defauls' button at bottom... this sets everything back to factory settings and should fix your problem. Cheers.
Jun 08, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Canon CanoScan 4400F Flatbed Scanner Logo
242 people viewed this question
old marine
old marine
