Question about Sony Grand WEGA KDF55E2000 55" Projection HDTV
The tv turns blank by itself while the power is on. it worked perfectly before and this just started to happen. it stays blank and then the picture comes back right now. it has started to happen alot more frequently. please help!! i dont know what to do.
  • Sony Master
  • 5,138 Answers
You could very well have poor solder connections.
Posted on Jul 15, 2008
Tv won't turn on
Most likely the power supply or Main PCB
Nov 24, 2013 | Sanyo 42 in. LCD TV
Blue light turns on but tv screen stays blank
The blue light indicates power is getting to your TV but there may have been failure of the internal power supply
Jul 07, 2013 | Sceptre Televison & Video
I keep getting a blank blue screen when I turn on my Mitsubishi 60 inch TV and then turns off by itself after about a minute. When I press "pip" on my TV remote I can see a small square screen...
there are 2 tuners in a rear projection tv. maybe the main tuner is faulty or the tuner's associated circuit has problem. if there is no signal these tv are programmed to turn the power off/stand by.
Aug 19, 2011 | Mitsubishi VS-50603 50" Rear Projection...
Toshiba 27af45 repeatedly turns itself off. Sometimes (usually) every few minutes, other times will stay on for hours. Works perfectly otherwise.
The fact that the television stays on for hours and other times turns in five minutes shows that your problem is intermitent .A defective component in the power supply is probaly causing the B plus voltage to go up.The TV can also have a dry joint which looks more likley i am curtain if you gave the TV a firm tap to the side when it come off it would come on back. Try it .
Dec 29, 2010 | Toshiba 27AF45 27" TV
TV screen went blank and it began clicking, turning itself on/off repeatedly. Had to unplug from wall to make it stop. TV is only 2 years old and has worked perfectly until now.
the power supply board has failed. call 1-800-samsung for nearest service center. power supplies are usually $125.00 plus labor, 1 hour maximum to repair.
Nov 24, 2009 | Samsung LN-T4665F 46 in. LCD Television
It will power on but then turn right back off it worked fine yesterday
One of four things happen when these lcd's get power problems. 1. They either go completely dead[no power with no lights] 2. Little green light will blink and go back to red with dtv briefly showing and then the tv screen go blank 3. Same as # 2, but with screen staying blank. The fourth is extremely rare, which is a shorted panel that makes the tv set behave like it's getting no power. All signal a bad tv, and the fourth is not usually repairable, requiring a whole new panel. I hear that power flows thru the panel, so that would explain how sometimes it will short out.
Apr 28, 2009 | Emerson EWL3706 37 in. LCD Television
Sony KDF-46E2000 - Screen Goes Blank
The lamp can cause the picture to cycle without spitting out a lamp error. I'd replace the lamp and clean out the dust/dirt from fans, etc to hopefully resolve your issues.
Dec 06, 2008 | Televison & Video
42 in LG LCD TV turns off by itself
Found that TV started switching off by itself. Would try to come on..green light blinked for 2-3 seconds, tv came on (with picture and sound) for 1 or 2 seconds and then it would turn itself off. Found that the issue is with one channel only. If you are facing this issue....try quickly changing the channel the moment it comes on. You can do it either with remote or with the TV buttons directly. also in the same logic, if this is still happening, try changing the source to another (rgb-pc, av1, av2 etc). Basically change it from whatever input it is on currently, if changing the channels does not work. My symptom was that the tv made a loud 'TIK' 'TAK' sound which is louder than normal.
Jan 22, 2008 | LG 42LC2D 42 in. LCD HDTV
Startup problem
try pressing F8 on start up and getting into the safe mode and highlight last known good configuration. If still no luck try this:- Only other solution is to remove right side panel of pc and locate the JBAT1 terminal and move jumper from pins 1-2 to pins 2-3 for a few seconds and back again. Turn on pc and then hopefully you can access the bios to set the time and date and save settings then re start.
Jan 21, 2007 | IBM NetVista M42 PC Desktop
Sony Grand WEGA KDF55E2000 55" Projection HDTV Logo
32 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
