Question about Sony Playstation 3 (PS3) Console
Ps3 problem, ps3 doesnt turn on (stays in red light flashing)
When I turn on the console from the main switch, it just turn red light as normal then in less than a half second it makes a vip, and it star flashing the red light and you cant turn on the console, stays like that all the time, what can I do to repare my ps3??? or what is the problem with my ps3??. I just buy a 250gb hd memory thinking that the 60gb memory was corupted or damage.
  • Anonymous Jul 15, 2008
    The PS3 will not stay on more than a second. The blinking red light becomes green, then switches back to red. We have a BluRay movie stuck in there, so we're quite concerned. We left it alone all night hoping it was a temperature problem, but it didn't work.
    Champion:
  • 241 Answers
Its Died go here http://www.youtube.com/watch?v=U70SgRDVcBo&feature=PlayList&p=7671174E22A52E35&index=0&playnext=1 to fix it or Pay Sony to do it or just use it as a Doorstop
Posted on Mar 24, 2010
    Problem Solver:
  • 11 Answers
Unfortunatley if there is a yellow light when it powers down you have the yellow light of death (ylod). I just fixed mine using a youtube video but would not recommend it for everyone. your best bet is to mail it in to sony for a refurbished on for $149.
Posted on Aug 27, 2009
    Sniper:
  • 85 Answers
More than likely your system has overheated. The thermal compound has heated and moved away from the CPU/GPU and the heat sync keep the heat from being dissipated via the heat sync. Eventually you will get the YLOD which is the equivalent of the Xbox 360 RROD. This is due to heat sysnc problems. Your CPU and GPU will more than likely need to be reflowed. I got the YLOD on my PS3 around the first of March 09. I also fixed my PS3 in about an hour. I have had no problems since. You can slow the YLOD but i dont believe it can be stopped. It seems it will eventually happen to all PS3's. One tip do not stand the PS3 on its side keep flat. This will help keep the thermal compound from moving as much when it heats up. Also i run a home based computer repair business in southern California. Feel free to email me at dwdpcrepair@gmail.com.
Posted on May 17, 2009
Red light blinks and wont stay on when push power button
You can do this fan test.
Turn the main switch off, hold the eject button.
While holding the eject button, turn the main switch on, when the power light is green, release it and you should hear a beep.
The fan will operate at the highest speed possible and will eject any disc that is inside.
After about 15 seconds the fan will stop spinning and the ps3 will beep 3 times and the red light will blink. When this happens, turn the main switch off and on then turn it on normally.
Tell me how this goes!!
May 05, 2011 | Sony Playstation 3 (PS3) Console
Ps3 is off with game in it, try to turn on but it will not turn on. it tries but flashes blue then red an wii stay off.
u try switching on it in hdmi mode and if it doesnt work ..u can reach the help of this site .it has a repirguide with which u can solve every error in ps3...
Dec 02, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont stay on
charge it red light turning of and beeping is meaning its dead
Mar 02, 2010 | Sony Playstation 3 (PS3) Console
My ps3 beeps 3 times when i turn on by main switch and light stays red, when i try to insert disk it flashes green and yellow and disk will not go in????
I had the same problem unfortunalty i had to replace my ps3's mainframe, an issue of over heating, along those lines, it had been fried :( Can be repaired although, if not claim your warrenty! :D
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
From standby PS3 wont turn on.
that sounds like your main power supply unit
May 28, 2009 | Sony Playstation 3 (PS3) Console
Console doesnt work it just hAS A FLASHING RED LIGHT
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like No Display Problme. You may check out the informative blog post at PS3 Repairs blog
Hope it helps to fix the problem.
Apr 17, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Ps3 doesnt start!!
Ok so if its not reformat the hd .. if it flashes other colors then red let me know as this is a motherboard failure!
Jul 16, 2008 | Sony Playstation 3 (PS3) Console
Sounds like a heat sync problem. you will more that likely need to re-seat the GPU and CPU as well. email dwdpcrepair@gmail.com for more assistance
Jul 14, 2008 | Sony Playstation 3 (PS3) Console
Ps3's green light turns on usually screen stay's black
Call Sony so they can fix it. This sounds like multiple problems. Good luck.
Nov 17, 2007 | Sony PlayStation® 3 (60 GB) Console
Sony Playstation 3 (PS3) Console Logo
117 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
