Question about Breville Die Cast 800ESXL Espresso Machine
Need a new cupfilter number 2 hole blocked and cant be cleared
  1. number 2 cup filter blocked
  • 74 Answers
Trie and put the cup filter in descaling solution a couple of yours and then clean it extremly good. this might clear out the blockage in the filter.
Posted on Jul 15, 2008
No water coming down to cups
Assuming that you are certain that there is no scale blocking the brew head and that the pump is running normally, try making a cup with no filter cup installed into the filter handle (obviously with no coffee grounds either) but with the handle installed into the machine
If water now flows, your problem is a blocked filter in the floor of the filter cup, and the easiest and most reliable way to fix that is to purchase a replacement filter cup :o)
Check also that the filter handle's outlet holes are not blocked. The tar like gunk that builds up in the filters and handles can be quite hard to remove
Nov 12, 2013 | Bialetti Mokona Espresso Machine
Coffee holder cup blocked
The same just happened to me, thus, looking for a replacement filterholder.
Jun 12, 2013 | Ariete Cafe Retro Espresso Machine
Why is my cafe retro espressione not making espresso? It look like the water is pumping up but not draining into the cup! Thanks
You need to descale it. step 1: run some white vinegar through it. step 2: use a commercial descling product (more effective than vinegar). Step 3: if the water flow is completely blocked by scale you need to un screw the exit filter by tipping the machine upside down. Then, remove the scale that built up under the filter, and clean the filter holes. Reassmeble the device and run a descaler through it.
Nov 08, 2011 | Ariete Cafe Retro Espresso Machine
It seems like dirt in glasses and cups in the topack of the dishwasher, is there a kind of filter that should be cleaned??
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Daniel
May 18, 2011 | Dishwashers
Coffee machine blocked
it could be grind stuck in the (yes the, as in the only) hole in the filter cup. remove the filter cup from the cup holder (the thing with the black handle) and use the tiny pin in the little brown tool to push out whatever is in there. you may have used to fine a grind or stuffed the filter cup too much. careful, that is how you break the plastic filter holder ring.
for calcifying, i just use plain white vinegar. i put it in straight into the clear water holder, about 3/4 cup, then i run it throuhg a bit, let it sit 5 min, run it through a bit, let it sit 30 min to an hour. depending on the day, i repeat a few times, rinse with clean water. i do this about every 2 months.
Aug 03, 2010 | Breville ESP8XL Espresso Machine
Guinea pig bedding has blocked the sweeper hole
The base of the vacuum needs to come apart. You will need the service manual if this is not a common task for you. It may be possible to reach the vacuum hole if the roller is removed.
The service manual is here:
http://www.hoover.com/shop/searchresults.aspx?itemid=220964&filters=
Mar 22, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Coffee grounds in cup w/ Keurig 60
I have the answer because it is happening to me now. Moreso with the Timmothy's brand K cups. I did a little forensics on a good brew, and then on two slow with grounds in the final brewed coffee.
The inner filter is placed in the k cup and it is not glued to the top rim. The bag then just sits on the bottom of the k cup as it is passed with the hot pressurized water.
The good cups are glued to the top rim and there is no problem.
To investigate....remove the foil top carefully after the cup cools. Rinse out the grounds, and the filter bag should still be glued to the rim. if you've got a dribbler and one that passes the grounds into the cup...you will find the filter bag had fallen loose from the rim. Manufacturer defect...You bet!!!
I had 8 from a box of Timmothys 25 count pass grounds. Green mountain coffee may once in a while pass grounds, but very rare and maybe three times in the 4,000 k-cups we've used.
Mar 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
Filter cone is full of hot water & thermo pot has about 5 - 6 cup
Te water fill lid is not closed or or the flow valve in the tank is plugged. Remove the basket and clear the hole in the bottom of it.. If new, return it to place of purchase.
Jun 22, 2009 | Black & Decker Programmable 8 Cup...
Pressure but no water
Make sure your filter is clean, take the filter and head it to light. If it is clean then you can see a little hole in the midle.
Aug 09, 2008 | Breville ESP8XL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
176 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
