My xms digital tv receiver and recorder sdx-250p will not open hard disk and in menu says hard disk 0 mb used and 0 mb available.
  • 2,071 Answers
Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Posted on Jul 15, 2008
  • lorentzsurfe May 10, 2011
    No -Problem was with Western Digital HDD
Only 7554 MB on a 320 GB western digital harddrive
you need to performe check dsk command on ur hard drive
Nov 19, 2011 | Western Digital Computers & Internet
Hi I am trying to download skype 5.5 free version and it is not going past skypetm -Install window.. I hv tried to wait for almost an hour but nothing has worked so far.. Will appreciate help solving the...
Maybe you need some hard disk space and Skype requires at least 256 MB of RAM and 18 MB of free hard-disk space for installation files. Try to delete some of your files that are not necessary especially images. To find out how much free disk space is on your computer:
  • Open your "My Computer" folder by clicking the icon on your desktop. If you do not have a shortcut on your desktop, open your "Start" menu and right-click on the "My Computer" icon.
  • 2 Right-click on your hard drive icon. Generally, the hard drive is named the C: drive. Select the "Properties" option from the drop-down menu.
  • 3 Read the pie chart and accompanying information to determine how much free disk space your hard drive has. Windows operating systems use blue to indicate how much disk space you are using and purple to depict how much free space is available.
  • If you have enough space, try to download SKYPE
    If this would help you please don't forget to give rating.
    Thank you for using FixYa. : )
    Sep 12, 2011 | Skype IM
    I asked this a few days ago; , I have a Samsung SpinPoint P80 SP1604N 160 GB Hard Drive in a HP compaq presario SR 1617CL I want to replace it with a larger HD, 500GB or 1TB. Can I replace it with a...
    Yes, either of these drives will work. The cache is not all that important it is just where data is stored temporarily in case you have to access it again soon after a file is written to the hard drive. The best thing you could do in this case is see if your motherboard has a sata connection which I would assume it does and buy a sata hard drive. It will be much faster than either of those drives, just make sure you also get a sata power adapter if your power supply doesn't already have one and a sata cable.
    Mar 11, 2011 | HP Compaq Presario SR1620NX...
    WD 2500BB is installed in an Xms tv digital recorder But hard drive hums or vibrates and appliance will not work. Can I replace it ?
    daferg
    Question was this hard drive the one that came with the unit or did you install it your self. Also please let me know the model number of the digital recorder so I can look up info on it.
    Issken
    http://www.fixya.com/users/issken
    Jan 16, 2011 | Western Digital Caviar WD2500BB 250 GB...
    I bought a "My DVR Expander" to use with my DirecTV HD DVR. Does Western Digital make this expander in anything larger than 1TB? If so, where can I buy one?
    Note that your DVR will treat this as "extra" storage, i.e., supplemental to its "internal" storage.
    A 1 terabyte hard drive allows you to record:
    • Up to an additional 600 hours of Digital TV
    • Up to an additional 120 hours of High Definition TV
    Since the largest EIDE/PATA disk-drive is 0.5 TB, the disk-drive inside the Expander must be a SATA disk-drive.
    So, disassemble the unit, disconnect the SATA disk-drive, and pay about $300 to buy a "2000Gb Western Digital Caviar RE4 Raid Edition 7200RPM 64 Mb Cache 3.5 7200RPM 64 MB Cache SATA Internal HD 3 Yr Warranty WD2003FYYS".
    Connect the disk-drive to its interface.
    Close-up the case.
    Connect your "custom" PVR expander to your DVR,
    and see if your DVR will recognize the 2TB of disk-storage.
    Sep 08, 2010 | Western Digital My Book Essential Edition...
    My thomson DTI6300 digital TV recorder shows that it is recording but does not stop at the required time. No recording is actually made and the message comes up ''recording failed''. This happens whatever...
    If you have no recordings and it's playing up, I'd do a complete reset as follows;
    Restore Factory Defaults
    This will restore all the factory settings and erase the contents of the box.
    Menu>Set-up>Help>Green>Red
    Format HDD
    This will re-partition and re-format the hard drive.
    Menu>Set-up>Help>Green>Blue
    This will wipe everything you have recorded. It will also dump your 14 day Electronic Program Guide which will take upto a day to reload. Leave the unit on standby.
    You might want to take this opporunity to do a channel scan as well.
    Jan 22, 2010 | Televison & Video
    Can not see canon dc220 recordings from PC
    Until you Finalize the disk it will be unreadable on the other devices. In order to finalize the disk you must have the power cord plugged in to the Camera. Then finalize will be an option on the menue. So no one does it on accident. After it is finalized you will be able to open it up on the computer or on most DVD players.I have the dame camera, I love it
    I hope this helps you. Let me know and don't forget to rate me.....
    Jun 16, 2009 | Canon DC220 DVD Camcorder
    How do i tune my philips 3590H philips dvd recorder into digital
    The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
    Info related to your specific problem is as follows...
    Setting your TV channel
    programmes
    Before the recorder can start recording
    the TV channel programmes, you need to
    search for the available TV channels and
    store them in the recorder.
    Note: Make sure you have successfully
    made all the required connections to the
    recorder, the TV and Satellite Receiver/
    Cable Box (if any) and switched them on.
    Tuner settings can only be changed
    when there is no disc in the disc tray.
    A Press SYSTEM-MENU on the remote
    control.
    �� The system menu appears on the TV.
    B Use ���� keys to highlight
    { System Menu - Channel Setup }
    and press ��.
    Modify Channel Information
    Sort Channels
    Channel Search
    Edit
    Sort
    C Use ���� keys to highlight { Channel
    Search } and press OK.
    �� The automatic TV channel search
    starts. This process may take several
    minutes. Once complete, the total
    number of channels found appears on the
    TV.
    Automatically scan all the receivable analogue local TV
    channels and store these channels on the recorder.
    �� Use ���� keys to highlight { Channel Search } and press OK.
    �� The automatic TV channel search starts. This process may take
    several minutes. Once complete, the total number of channels found
    and stored appears on the TV.
    Modify Channel Adjust a stored TV channel to your preference, improve the
    Information reception and the sound quality of that TV channel.
    1) Use ���� keys to highlight { Modify Channel Information } and
    press OK.
    �� The channel menu appears.
    2) Use ���� keys to select one of the options.
    { Name } – You can use the numeric keypad 0-9 to select
    the channel preset number which you wish to
    change.
    – Use ����keys to change alphabet/ number and
    use ���� keys to select different entry fi elds, then
    press OK to confi rm.
    { Scan Mode } – Select TV channel search mode based on
    channel allocation or frequency.
    – Use ���� keys to select { Frequency },
    { Channel } or { S-Channel } (Special Channel),
    then press OK to confi rm.
    { Frequency } – Shows the frequency of the current TV
    channel.
    – If required, use ���� keys to start the automatic
    frequency search and press OK to confi rm.
    { TV System } – Set the TV system that produces the least
    distortion of picture and sound.
    – Use ���� keys to select a suitable sound mode,
    then press OK to confi rm. (See chapter “TV
    System Guide” at the back of this manual for
    more information).
    { NICAM } – Turn on or off the digital sound transmission
    system which improves the sound quality of the
    TV channel.
    – Use ���� keys to select { On } or { Off }, then
    Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
    Formatting disks for EDSR1600
    The EverFocus EDSR Security DVRs use standard PC Parallel (PATA) hard drives. I have used ATA100 and ATA133 speeds with no problems. There are no PC-type settings required except as below. The DVR has it's own internal firmware and will format the drive to its requirements.
    If you are using a SINGLE drive tray, the largest hard drive I know will work is 500 GB. Set the drive to Master and you are done with the hardware setup. (CS Select would also probably work.)
    If you are using BOTH drive trays, the largest hard drive EverFocus says will work on the EDSR100 or EDSR110 is 320 GB. Set both drives to Master and you are done with the hardware setup. (CS-Select on both would also probably work.)
    Do NOT set any drive to Slave!
    Lock the drive trays; if you don't the DVR will not go into record.
    Press the STOP key and then press the MENU button. Go into the SYSTEM menu and do a DISK RENEW. This will erase the hard drive and also prepare it for DVR recording.
    Do this by using ► or ◄ to select DISK RENEW. Change NO to YES (by using ▼ or ▲) and press the ENTER button. Highlight YES again by using ► or ◄ and again press the ENTER button.
    Press the MENU button to exit and reboot the DVR. Then press RECord and you should be recording.
    Aug 09, 2008 | EverFocus EDSR1600 16 CHANNEL 160GB...
    DVR recording of off-the-air television signals
    TiVo works with 'off the air' TV watchers as wellNot really worth the extra money though if you just have VHF and UHF channels.
    May 22, 2008 | Tivo Series2 TCD649080 Video Recorder
    126 people viewed this question
     Grubhead
    Grubhead
