Question about Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum
Suction problem I have a Hoover Widepath Fold Away, 12 amp motor vacuum cleaner and the problem I am having is every time I vacuum, the vacuum gets clogged up with carpet. I am probably only able to do one stroke then it gets clogged and I have to stop and unclog it or it spits it out on the carpet. This is very frustrating and I don't get much vacuuming done. Please can you help me. Thank you. Gwen email is jonesgwendolynj@verizon.net
  • jonesgwendol Jul 15, 2008
    it is model #U5172-900, not U8145-900
  • toop Jul 17, 2008
    How do I unclog it
  • 281 Answers
Get rid of the carpet its shredding and falling apart.no sence in vacuuming old rotten carpet.or try using a vacuum without a brush roller and just suction
Posted on Apr 24, 2009
  • PETE GALATI
    PETE GALATI May 01, 2009
    on the top towards the back on each side there are 2 screws and on the bottom in the front thare 2 screws take those out and the top cover will come offtake the bewlt offand pull the brush roller out the bottomcut all the carpet strands off and try and tale the bearing ends off to clean inside of there.some pull off and some unscrew
Does it have a reset button?
There is no reset button on this model. If the motor shut off it is due to the motor getting too hot. This can be caused by poor aire flow, usually afull bag or clogged filters. The vac is designed this way for safety.
May 01, 2010 | Hoover U5172900 Fold Away Widepath Bagless...
I have a Hoover fold away and the floor cleaner doesn't work only the attachments are working.
The reason for this would most likely be a blockage in the bottom of the foot of the machine. could also be a bad belt. Check or change the belt and look for obstructions.
Apr 21, 2010 | Hoover U5172900 Fold Away Widepath Bagless...
Brush on hoover wide path does not spin around.
remove the bottom cover and check the drive belt.if belt is ok then your brush motor could be bad.
Jan 29, 2010 | Hoover U5172900 Fold Away Widepath Bagless...
After using my attachments I have a hard time getting suction when using upright again - how do I get the suction on my upright? It's a Hoover blue widepath Tempo~ thank you
It may be clogged underneath the vacuum where the roller is. Take the bottom plate off and look into the intake port. There may be some blocking the port.
Nov 09, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Hoover vacuum carpet cleaner will not sucktion (sic)
No, this cleaner uses no belts.
If you are having a suction problem, first check that the lid on the recovery tank is lined up to the tank when installed to get a good seal.
Second, remove the tank and make sure the round black rubber seal is present on the pipe from the base that aligns with the bottom of the recovery tank. That seal connects the vacuum from the motor to the recovery tank.
Oct 13, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Empower Widepath Vacuum Doesn't ****
This model requires the lower end of the hose to be installed into the base unit to pick up the dirt. If it is properly installed, I would check the belt and also look for a blockage. The normal life span of a belt is about 9-12 months. your belt # 40201190 2 pk
Mar 11, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
Vaccum Cleaner
You can download the manual here and it will tell you how to replace your belt. I could tell you, but I won't have diagrams which the manual does. Let me know if you require more assistance.
Dec 10, 2008 | Hoover U5172900 Fold Away Widepath Bagless...
Hoover Vacuum Elite (Allergen Filtration) 12 Amp Motor
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=646648
Generic problem for all Vacuums
Hoover Vacuum Elite (Allergen Filtration) 12 Amps...
Posted by Maya B on Jun 04, 2008
I received this vacuum (Hoover Vacuum Elite/Allergen Filtration 12 Amp Motor) from a friend. After using it in a few rooms it started giving off this burnt odor and the motor starts to sound as if it's dying. What is wrong with it and how can I fix it? If I need to change a part, which one is it and where do I get it from?
I love the suction in this vacuum even though it can be very loud when the attachments are being used. You can email me at fine_wonder@yahoo.com Thanks very much! -Maya
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Vacuum Elite/Allergen Filtration 12 Amp Motor. It certainly sounds like a motor that is on its way to going out or burning out – you can replace the motor and you can get the part from your local vacuum cleaner dealer in your area, either new or used to save money, or you can contact the cust serv dept @ Hoover. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 04, 2008 | Vacuums
Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum Logo
171 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
