Westinghouse LTV-37w2 HD picture malfunction
We bought our TV in 2006. A few months later, our picture became distorted - lines went through it and it changed to all pink. Westinghouse support told us to turn the TV off and unplug it to reset the computer. This seemed to work until this past week. Now, the picture will be clear for the first 10 to 30 minutes and then distort.
We replaces our cable TV line to ensure a good connection. We run the TV through a top of the line surge protector. Have you heard of this problem before? What can we do?
Thank you.
Have the same problem, have found others too, but no solution yet...
Posted on Oct 29, 2008
Westinghouse LTV-37w2 HD have no picture, no sound, no blue power light on - only some buzzing. What it can be ?
if it is just buzzing then the transformer has gone, may have over heated.it transforms the line in volts down to the volts needed to run the tv. so say 240v ac in and tv needs 110v ac. now the volts in will be making the buzzing sound but the coil on the 110vac side has gone. if you change the transformer. has to be the same colour and number. tv should be fine. as the coil in the transformer brakes its just like removing the plug from the wall and not do any more damage. so just the transformer will need changing.
Oct 01, 2013 | Westinghouse LTV-37w2 HDTV
Westinghouse ltv-46w1 has picture but no sound
check to see if same with a DVD etc connected to the rear inputs, if no sound the main board creates, controls and outputs audio.
check also with the maker to see if this is a known issue in this model.
Sep 02, 2012 | Westinghouse LTV-46w1 HD 46 in. LCD...
Westinghouse LTV-37w2 loses picture
Hello, you are getting some signs that your inverter boards on this unit are going to go out. By the sounds of the problem you could have a loose cable in the master or the slave inverter, or it is just an indication that one of the two is about to give out with in the near future. You can find these parts by visiting www.shopjimmy.com.
Apr 19, 2010 | Westinghouse LTV-37w2 HDTV
No picture on Westinghouse flat screen tv
westing house flat screen tv hd...has sound no picture
Feb 15, 2010 | Westinghouse LTV-37w2 HDTV
There is sound but no picture and there is no response when using the control buttons on side of tv or the remote. I turn the tv on and change channels thru Comcast cable.
Talked to a Westinghouse tech and told to unplug for about 3-5 minutes, then re-plug. It's like having to re-boot your computer when it goes down or starts acting wacky. It worked, I got picture. Says it could happen again, maybe 1-2 times a year is o.k., if it starts to happen every few weeks, then it's something more.
Oct 14, 2009 | Westinghouse LTV-37w2 HDTV
Wesitinghouse 37" all of a sudden wont work with hdmi cables plugged in. only picture with component cables in. ps3 wont work individually either currently have it directly into cable source and everything...
Same problem I had... My problem was with any HD input from PS3 (only HD device I have), the PS3 was fine on other televisions so I determined that it must be a problem with the TV in question. I fixed this problem by unplugging the TV, letting it sit for about a minute and then plugging back in.
Apr 13, 2009 | Westinghouse LTV-37w2 HDTV
Vertical Lines
Sounds like pixel problems, this could be a bad panel or board inside tv. I would contact manufacturer and see if they have policy with bad pixel panel. Even with out of warranty try anyways.
Jan 04, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse LTV-46w1HD
The conversion board on the TV is iffy at best, to replace it is about $169 available cheapest at cfusion.com
Dec 25, 2007 | Westinghouse LTV-46w1 HD 46 in. LCD...
Televison & Video Logo
187 people viewed this question
Top Televison & Video Experts
