Question about Frigidaire FTF530FS Front Load Washer
Kill Yourself
Posted on Jul 21, 2008
I have a Frigidaire FTF530FS washer with a problem. The Timer gets stuck in between the drain and the spin cycle. It occurs when the timer dial is about 3 o'clock. I replaced the drain pump, the door...
Good Morning kvojik, thanks for your post!
From my understanding your Frigidaire front load washer is getting stuck between the drain and spin cycle. I noticed that you have replaced many components within your washer and continue to experience this issue. I would not advise to manually advance any part of the washer because this could cause issues within your washer. It could be a potential issue with the motor. At this point you may want to reach out to a technician for proper diagnosis and repair. This will help you to avoid any further part purchases. -Matt
Feb 21, 2015 | Frigidaire FTF530FS Front Load Washer
The washer will drain but will not spin
hi mite be worth checking motor brushes this will cause your problem
Mar 16, 2014 | Frigidaire FTF530FS Front Load Washer
Frigidaire FTF530FS Front Load Washer will not advance through cycles... need to manually turn knob. New timer did not do the trick nor control panel...
Hi Jacquie, thank you for your inquiry! First, when you are referring to the control panel are you speaking about the motor control board? The motor control board advances the timer, and the timer will not advance if it does not sense that the door is closed and securely locked. Therefore, I highly recommend reaching out to an expert technician that can accurately diagnose the motor control board and/or door switch on this particular unit. The servicer will ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Aug 10, 2013 | Frigidaire FTF530FS Front Load Washer
No agitate or spin
It could be your motor brushed are worn
Nov 07, 2012 | Frigidaire FTF530FS Front Load Washer
My frigidaire stopped working
The bearings are bad. My sears kenmore did the same thing. Do you have hard water, that would be one cause. Or maybe it's still under warrenty because it is not a cheap fix.
Dec 31, 2009 | Frigidaire FTF530FS Front Load Washer
Frigidaire front load FTF530FS
If under warranty get a tech out there and have him check the control panel, clutch, and motor control board. If not under warranty its probably the clutch...they are made of plastic and will break....if the tube spins freely its the clutch. But those electrical boards do go out.
Oct 13, 2009 | Frigidaire FTF530FS Front Load Washer
Noise when on spin cycle
Check inner drum for excessive play, if so Bearing fault. Could also be loose motor mount or Counterweights.. Good luck
Sep 29, 2009 | Frigidaire FTF530FS Front Load Washer
Frigidaire FTF530FS Front Load washer
Take off the lower panel. Inspect the shocks too see if they are damaged. If they are OK turn the wash basket by hand if the knock is heard then most likely you have a broken wash basket.
Jan 13, 2008 | Frigidaire FTF530FS Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
199 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
