I have several new HP desktops. I am finding that all of
them have sporadic problems with reading/formatting
floppies. I have tried several new, different brands of
floppies in these drives. Sometimes they format fine,
sometimes they get to the end of the format and tell me it
cannot format.
Any ideas?
Thank you!
1 Other User Has The Same Problem
Comment by beststar, posted on May 05, 2008
hi
I am Osama
my problem is about formatting
I have driver floppy disk 3.5 formatting 1.44
I wanna convert formatting to 1.2
do you have software to my driver floppy disk 3.5 can format 1.44 and 1.2
thank you for your help
could you please send it to my e-mail addres : Osamabeststar@hotmail.com )
Rating: 0%, 0 votes
machines now and works perfect.
At our school we are having all the floppy problems mentioned in this NG.The
only one that is 100% reproducable is this: take a floppy, format it
inWin9x, and put files on it. Stick it in an XP PC and select "Copy
Disk"from the A: drive context menu. We get errors nearly 100% of the time.
Ifound the following fix
at:http://discuss.extremetech.com /n/mb/display.asp?webtag=extre metech&ms...
301.1 posted by someone called cluberti. The drivers he mentions work,
butthey leave a phantom B: 5.25 drive that needs to be
disabled.-------------------------------------------------------------------
----------------------------------I looked at everything I could find, and
everything technically SHOULD bethe same in the way Windows 98 and Windows
XP format and access floppydiskettes (FAT12, 512bytes/sector, etc). And
what did I find? As usual,things have changed (and you wouldn't know it
unless you dug deep). Thefollowing is what I found (and how I fixed it -
get this information OUTTHERE): After beating my head against the wall for a
few weeks and polling everyoneI knew personally that was running Windows XP,
I found that quite a few ofus had this problem - format and/or use a floppy
in XP, it doesn't work inWin98 (and sometimes Windows 2000 too). Format
and/or use a floppy inWindows 95, 98, ME, NT, or 2000, it no longer works in
XP (even if it workedbefore). It seemed that the brand name PC's had this
problem lessfrequently than a white box machine, but they were not immune
either -especially Compaq PC's. So, I dug around google groups for a while,
andfound LOTS of people complaining of this particular problem. However,
quitea few searches on Microsoft's site about floppies, corruption, and
WindowsXP turned up absolutely nothing of value. After LOTS of digging, I
did find this interesting Microsoft Q
article(http://support.microsoft.com/d efault.aspx?scid=kb;en-us;Q309 623)
that I hadoriginally perused and thought of no use. I read it again, very
CAREFULLY,and read it over a few times more to make sure what I was reading
was reallythere. If you're interested, read it in all it's glory on the
Microsoftsite and be amazed - then come back (open a new tab or window! :O)
here forthe fix. For those of you not inclined to visit Microsoft.com (and
you know who youare ;O), here's the interesting tidbit (and the root of the
problem): "Windows XP supports formatting only the 1.44MB disk format.
Three-modefloppy drives (drives that are capable of reading/writing with
720KB, 1.2MBand 1.44MB 3.5" disks) requires special driver support, and
support for thisfeature is not inclu
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
condense the information that is necessary to install the driver. I tried to
compose a "canned" response to all those having floppy problems but, I
decided that every attempt would only make sense to me,...I gave up!
JAX
disabled.---------------------­----------------------------------------------
Rating: 0%, 0 votes
I found the article on the web-site you have quoted to be rather difficult
to follow but, after trying everything else, with no success, I was able to
cure my chronic FD problems by installing the 3 mode driver from that site.
I had a friend format a floppy and write to it on his 98 machine, as well as
one with a 2K machine. We were able to move floppies from one to the other
with my XP machine. The most important thing to me is, I have a camera that
uses floppies, NO SWEAT!
It seems to me that some XP install CD's have defective floppy drivers and
some don't. The reason I have come to this conclusion is, some people post
and say they have no problem at all. I've tried every suggestion I could
find including changing FDD's 3 or 4 times. The 3 mode driver seems to be
the "Silver Bullet" for the problem.
Thanks for passing the information in your post to others.
Cheers, JAX
on!-------------------------------------------------------------------------
Rating: 0%, 0 votes
But it worked for me also. Lots of people have the "bug". Later on.
Rating: 0%, 0 votes
pencil holders. It isn't an o/s specific problem. It's all drives and disks
in general. I've gone through 25 disks only to find 3 that were good. might
have something to do with those magnetic antitheft strips everyone uses. Try
buying floppys from someplace that doesn't use those tags? Just a
suggestion, although the pencil holder works great on my computers.
Post a New problem for Sony Beige 3.5" Internal Floppy Drive
Email this problem
Can you Help with these Floppy Drives problems?
Floppy Drive Message:...
