Question about Danby Silhouette DWC512BL Wine Cooler
Noisy fan on DWC513BLS
How do you get to replace upper fan?
i could not find the way. i tried from outside an from inside.
The upper fan is mounted to a board inside the refrigerator near the back. To access it, you have to remove all of the shelves completely. Once you do that, you should be able to see the screws that hold the backing in place. Remove all of those, and pull the board out. The fan is mounted directly to the board.
When you replace the fan, I suggest you use rubber washers or grommets when you mount the new fan to the board. That will dampen the vibrations that otherwise are amplified by the board itself.
http://www.adrianmccarthy.com/blog/?p=79
Posted on Sep 29, 2008
Noisy fan and no heat
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
May 06, 2014 | KitchenAid KEBC207 Electric Double Oven
Right Door is making loud popping noise
HI,
Noise can come from these areas:
The inside of the freezer
The outside back of the refrigerator
The bottom of the refrigerator
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Aug 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I am in need of a fan motor for my Danby Frig. Paret #JG50.DQ-10. Cannot find it anywhere. Suggestions?
The problem with the factory fan is that it is a sleeve-bearing fan. On average, a fan should operate for about 50,000 hours, which if it runs continuously would be over five years. However when the operating temperature rises or the fan is installed "not exactly" vertically, it will have shorter life.
I had to replace my fan two times withing two years since we bought the unit! Plus the stock fan becomes quite noisy after a couple of months of work.
With all of these problems I did some research for better fans and decided to purchase a ball-bearing fan to install it into the cooler by myself.
Ball-bearing fans on average outlast sleeve-bearing fans by 50 percent and produce less noise.
It's very important to purchase the right AC 115 Volts fan for this Danby wine cooler.
The original fan is Rullian Science RAL 1225S2 (120x120x25 mm in size, 100-125V AC, 0.09A)
The replacement model is Orion OA12AP-11-3TB which I got for $16.75 from Mouser Electronics (mouser.com). The replacement model is ball-bearing cooling fan with slightly higher/better parameters, which will help to cool down the wine cooler coil faster.
To replace the fan you need to tilt the wine cooler on the side and unscrew two small screws at the bottom that keep the original fan in place, remove one screw to the black box where the fan wires are attached and unplug these wires. Then you just need to replace it with the new fan and test that it works properly. If you never used Soldering Tool before you probably will be better off with getting some help from certified electrician - it still will be less expensive than getting this fan ordered every year from Danby.
Nov 06, 2012 | Danby DWC513BLS Wine Cooler
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
It's making a loud running noise
The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
Mar 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Noisy Aga fridge
where is the noise? inside or outside? inside maybe the evaporator fan motor. hitting somethig> wire . get a tech to double check not dangerous. outside. noise compressor dont replace. have to live like that or replace the whole fridge. or condenser fan motor. call atech for replaced
Mar 30, 2010 | Refrigerators
Refridgerator make a noise every 3 minutes
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
Mar 29, 2010 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
I am getting a loud rattling noise. could this be my compressor
Jan 29, 2010 | Frigidaire Refrigerators
Noisy outside from the Unit
Could be compressor noise Improper charge bad fan motor hard to say. What is the brand name of your unit. Russ
Jul 20, 2009 | Ruud Handle Air Conditioner
'91 GM truck heater fan noisy. Attempting to replace and the new fan is even noisier than the old one. It sounds like it maybe rubbing somewhere but have taken it out and adjusted the fan depth on the...
Sounds like the fan motor is hitting on somthing.
Take some chalk and coat the outside of the fan blade. Install it back into the truck and turn it on for a second. Take it out and see where the chalk like is inside the fan housing. make adjustments to anything it is hitting and/or replace fan if it is bent/damaged.
Mar 20, 2009 | 1991 GMC K1500
Danby Silhouette DWC512BL Wine Cooler Logo
192 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
