Question about Sub-Zero 632 / S
Ice build up
Ice is forming on the back wall (left side, middle) of the refrigerator compartment.  Other than that, all seems normal.  Any advise?
  • leechesnut Jul 15, 2008
    No.  The refrigerator is not new.  It is about 6 years old.  Your expert asked me a question and I don't see any way to "reply" to the experts question.  Please let me know asap.  Thanks.
  • 790 Answers
Hi
is it brand new?
Posted on Jul 15, 2008
How to fix ice build up in freezer
Did you examine the drain behind the rear panel (location #11) and below the evaporator coil in photo HERE and location #20 HERE You will need to tell me how much frost there is on the evaporator coil (location 22) I want you to test the=> 12729129 Defrost Heater Assembly. Check the door seals around both doors. Are the door seals good? I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 11, 2014 | Maytag Refrigerators
Our kennmore side by side referigerator bought two years ago seems to have lot of ice in the freezer compartment. there is ice formed over the vents in the referigerator side and things (milk) is getting...
is the ice on the back wall or was the door left open?also send the model number,you'll find it in the fridge side on the right hand wall up near the ceiling,it will start with like 106. or similar
Sep 04, 2010 | Kenmore Refrigerators
I have ice forming on back wall above top drawer in refrigerator. Belive seal may need to be replaced. Any other suggestions?
The gasket would be the last thing I would suspect. Is the ice a ball to the left side or is it all the way across? Could be a sealed system issue or a bad thermistor. I would recomend calling a factory authorized servicer for proper diagnosis before putting the money into a gasket. Besides look at the gasket all the wat around for any damage and make sure the door is closeing properly. Isee units with torn gaskets all the time and it doesn't cause ice build up in th refrigerator side.
Jul 02, 2009 | Sub-Zero 642
Sub-Zero 690 Refrig Side Ice Forming on Back Wall
replacing leaking evaporator on Sub Zero Video
Jun 09, 2009 | Sub-Zero 642
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
May 07, 2009 | Refrigerators
Ice accumilation next to fan in freezer compartment
u have a defrost problem need to replace heater and tstat
Mar 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Flat ice forms at the bottom of the freezer compartment
check your freezer door see if it (ajar) what you can do if you can unplug unit clar drain with hot water then get apiece of shave wire hook on the defrost heater and put in drain line 1/8 in the drain line put back wall back together and plug unit in
Apr 07, 2008 | GE Profile 21.6 cu. ft. Side-by-Side...
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
Sub-Zero 632 / S Logo
128 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
