Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissell Proheat Problem
Hi Tech Person . . . As soon as I switch my procleaner on . . . soap and water come out as if I am pulling the trigger. . .but I am not. . . How do I get it to stop?
Thank you so much.
    President:
  • 1,673 Answers
Take the top part of the handle off, make sure that the rod in the handle is moving up and down when squeezing the trigger. The lower part of the handle has a valve that the handle rod pushes on, it make be stuck in the open position.
Posted on Jul 20, 2008
Been cleaning for 2 hours now with my Bissell Quicksteamer and on my next run i presses the water release trigger on the handle and water isnt being squirted on the carpet..why?
ran out of water? (if water) >
Is there some form of water filter?
Problem with the trigger?
Bad steam heating element or the power connection supplying the power to it?
Of could it just be tired and need a break? (grin)
Best Regards
Ck
Aug 16, 2011 | Vacuums
My bissell steam cleaner will not spray any water or soap how do I correct this problem
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
kjgtllgj
Aug 23, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
No water/cleaning solution comes out on wash cycle
With this model, the soap dispensed is controlled by electric solenoids. these can be tricky to troubleshoot. I would take it to your nearest dealer. these solenoids fail, and cause a variety of symptoms.
Oct 08, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Water does not dispense on wash cycle
this would be the soap/ water valve. it is stuck closed or isn't opened.( no cure for an non-opened valve, just replace.)
Jul 16, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
No solution is spraying out when i press the trigger
I had somewhat the same problem.... I had water comming out but the solution was not comming out.... I called bissell and the woman talked me through it.... first put in water only mode,,,,, then Fill water tank with fresh water and put back in place,,,, then remove soap dispenser put to the side,,,, now , power on your cleaner,,,, for the next steps, do this exactly as I tell you >>>>>>hold down the trigger that releases soap the whole time you do the following>>>>>> switch between water only and heavy traffic four times,,,, all while while holding the trigger, then still holding the trigger, stop on high traffic the fourth time, leave it there,,, now put the soap bottle back in,,,,, still holding the trigger and hold the trigger down for exactly one minute after you replace soap bottle,,,, you should start seeing the soap come out........ (make sure its on floor cleaning and not TOOLS) Hope this helps and if it does,,,, give these instructions to someone else in this help area.........
Jul 04, 2009 | Bissell 8910 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
74 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
