Question about Maytag Refrigerators
Mtb 2156 ge freezer is cold enough to make ice slowly, but now cold enough to keep ice cream frozen. also sweats in the fresh food comp.from the top.
I have icing on the walls of frezer.
Posted on Aug 18, 2008
HAVE GE PSS26MSRSS SIDE BY SIDE THAT WILL NOT FREEZE COLD ENOUGH OR MAKE ICE
Hi , you probably need a repairman to check the freon level and test the thermostat
Jun 19, 2015 | GE Refrigerators
What can I do to get the ice cream to be frozen?
It might be a good idea to clean the condeser coil. If the coil is blocked, your freezer will not get cold enough.
Jun 03, 2014 | Sub-Zero Freezers
GE refrigerator / Freezer - Erratic freezing
Do you see any ice buildup on the back wall of the freezer or behind it?
Oct 22, 2012 | GE Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Kenmore upright freezer. Ice cream soft. Food is cold. HELP!
Ice cream has to be colder than 0 degrees C /32 degrees F. You need a cheap thermometer If your Ice maker Ice is not sweating in the bin, -10 degrees F ice stops sweating. you need not to sweat the freezer untill your cheap freezer thermometer can be compared to -10 degrees F
Nov 29, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer is no longer keeping ice cream solid/frozen
Ice cream is usually kept at -10 degrees to stay firm. Need to check temperature. Look at condenser coil for cleaning. This is usually the most simple and common issue. If not making the desired temp, and the temperature control is set for that temp, and compressor run constant, it is a refrigeration issue. If compressor does not run constant, then a control issue.
Jan 24, 2018 | True GDM-49FC Refrigerator Commercial
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Freezer not freezing enough and fridge not cold enough
Hello Scott, remove the food from the freezer side and remove the rear freezer panel. You will see a coil and it should be completely frosted over. If not then you have a sealed system issue. If it is froze solid in frost where you cannot even see the coil, then you have a defrost issue. You should have a little frost on all the coil, the defrost is what clears the frost so the evap fan motor can circulate the air thru out the unit. If frost is good, push the light door switch to start the fan. If it isn't running check for 120 volts. If it has voltage, but not running, replace the motor. Hope this helps.
Aug 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
144 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
