Question about 2wire (1000-400108-001) Router
Modem reboots when using wireless
2wire 1000hw. works perfectly fine on desktop hardwired. when i open laptop i can connect and it stays on for varying lengths of time. then modem will reboot itself. have updated drivers on laptops intel adapter. when i hardwire laptop and do not use it as wireless, the modem works fine. went thru att support and they suggested new modem. it only reboots the modem when the wireless is turned on on laptop. help.
  • dheath7200 Oct 03, 2008
    I have the same problem. The 2Wire modem hardwired to my main computer works fine, but when the 2nd computer (using the 'fin') tries to connect, it knocks the modem out and it has to reboot. The 2nd computer had previously work fine with it for over a year. My son's IPhone also knocks out the 2Wire modem. I called ATT and they said same thing - get a new modem. My system is Windows XP.
Did you try upping your lease time and see if that changes things.
The lease time is the amount of time before a DHCP request a new IP address.
Ususally it get the same, but if it is malfunctioning it can cause problems like this.
Posted on Oct 19, 2008
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.
With an Ethernet cable, connect from the netbook to a LAN port on the 2WIRE modem.
Access the built-in web-server on the 2WIRE modem, and configure the "wireless network settings" to your choice of SSID and network password/passphrase.
Then, from your computer, "View Available Wireless Networks",
and connect to the SSID that you have chosen.
Dec 29, 2009 | Acer Aspire One PC Notebook
Connecting 2wire 1000HW to a laptop
The number that corresponds to the wireless password/key code is the one inside the brackets on the bottom of the 2wire on the sticker.
Jul 17, 2009 | 2wire Computers & Internet
2wire wireless connection problem
Make sure that the wireless switch on your laptop is on. Click on view wireless network by right clicking on the network icon on your system tray. Locate the name of your modem ( SSID ) & enter the wireless encryption key ( WEP ) or password
Apr 08, 2009 | 2wire HomePortal 1000HW DSL Modem and...
2wire homeportal 1000hw cannot find wireless address
Windows 7 (Beta) and Windows Vista 64 Bit. Step 1. Do not allow the autostartup to run the installation application. You must right click on the CD ROM and select the "OPEN" option. Locate the driver on the install CD. Since my DVD ROM drive is my "D:" drive I located the driver at D:\USB_VISTA32364\BACKUP_2WIRE_VISTA_USB_Installer.exe . Before you click on this you want to right click on this and select Properties. In the properties tab click on the middle tab marked "Compatibility". Make sure you select the checkmark box to: Run this program in compatibility mode for: and use the pull down menu to select Windows XP SP2. This is how I was able to get my 2wire utility to work on Windows 7 (beta) 64 Bit.
Feb 07, 2009 | 2wire HomePortal 1000HW DSL Modem and...
How do I set up a home network without internet?
By default, your wireless connection for your 2wire 1000HW is enabled.Assuming that everything is installed properly in your laptop ie wireless cards etc. than you can view your wireless connection using Dell Wireless connection tool and HP wireless tool. Your know its your network when it says 2wirexxxx {x=combined numbers}. To locate the built-in, 10-digit wireless encryption key for your system, please look at the bottom of the product [2wire] near the bar code label - looks like this : [xxxxxxxxxx].
If you want to access the 2wire Graphic Unit Interface ,you can access it by opening your browser and on your address bar type in homeportal- assuming you are able to connect to your 2wire wirelessly. You can view your network and change you wireless settings. This may also help you :
To connect your printer you must have a Print Server [ dep[ends on what model of laserjet you are using } and connected to your printer. Again you will need the encryption key to get it running. You must share your printer on each laptop by going to control panel and share it . In there you willl have the chance to change and modify the settings. You can also use the Windows File and Sharing Wizard. to get it both running.
Hope that would help you a bit. Pls feel free to post your questions in Fixya for further assistance.
Wish you all the best.
Jun 11, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Problems with 2wire HomePortal 1000HW DSL Modem and Network Router
Check your firewall setting and also your security settings for cookies. Try putting less of a restriction on your cookies. BofA and wells fargo require that they can ping you and get your IP address incase of fraud so chances are lowering your settings on your cookies will solve the problem.
Apr 28, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is Try this instead of to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
2wire (1000-400108-001) Router Logo
161 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
