Sony kds r60xbr1 tv will not turn on, standby light flashes 5 times
    Genius:
  • Televison & ... Master
  • 1,689 Answers
Power supply, and or a failure on one of the boards that is causing the supply to go in to protect mode, or both.
The set will require factory level service.
Jerry G.
Posted on Jul 15, 2008
Sony KDS-R60XBR1 No picture
Sounds like your light engine might have broken. Its around a $400 fix and I noticed Tri-State is having a sell on there about 341 its easy to replace it here is the link
http://www.tristatemodule.com/casearch.aspx?SearchTerm=kds-r60xbr1&asug=&view=grid&lang=en
May 14, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
Sony kdf 50e standby light flashing 2 pulses
If your tv is Sony KDF-50E2000 model then 2 times standby light shows problem of over temperature in tv. Check temp sensor in tv.
If model number is different, let me know complete model number written on label at rear of tv to help you out.
Thanks.
May 14, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
5 red flashs on power/standby light on kdsr60xbr1 screen blank,
Thats the error for lamp driver error. Which means the Ballast is most likely defective. You can get the replacement ballast for your model at the following link which comes with installation instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/kdfe42a10-ballast-assembly/cName/sony-parts
May 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Kdf-60xbr950 no pic or sound. standby light flashing
Sounds like the lamp is bad. Might be time to replace the TV.
Mar 31, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Mar 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
