Question about Toshiba 51H93 51" Rear Projection HDTV
Toshiba 51H93 won't turn on **HELP**
I have a 51 in. Toshiba that has been great for 4+ years. My real problem now is that it won't turn. Worked fine on Sat. night, and Sunday night it didn't work. I tried manually using power button, I tried plugging into another wall socket and the reset button didn't work either. Sounds like clicking in the back of tv but nothing happens. What happened? Is the blurry area related to not working? Did something happen when power was shut off?
(Note 1) - Several months ago, I noticed that it was a little blurry at the bottom and center of the screen where scores are displayed.
(Note 2) - I turned power off in my house yesterday by circuit breaker but the TV was off. I have surge protector. All other units on power strip still work.
Thanks for any help.
  • djlewis0714 Nov 16, 2008
    So do you have an idea of what the repair would cost for something like this??? Or maybe a rough estimate?? Ive got the same problem it makes a clicking noise if I unplug it and plug it back in!!! I am going to buy a plasma tommorow but the picture on this toshiba is great with an hdmi to dvi cord .......... I want to eventually get it up and going and put in the the game room
  • Anonymous Dec 13, 2008
    I have the same problem... still looking for answers.
  • 927 Answers
Good Day, jsilver05;
That's a very good TV, sorry you're having a problem. I have the same TV.
1. The blurring of the pic may be an indication of a convergence problem.
2. The surge protector is not a fail safe device, it will reduce damage to the TV but will not not 100% protect it.
It is possible that by turning the power off may damaged the already weaken convergence circuit, but more then likely some other electronic device failed.Like a voltage regulator, high voltage device,and etc.
At this point I would recommend that you call a factory authorized service dealer and them come out and give you an estimate, or you can e me if want troubleshoot TV if you have digital meter etc.
Good Luck, big IRISH, mmrkcar@yahoo.com.
Posted on Jul 15, 2008
Horiz output failure repeatedly?
can you please provide the TV model and part #.
Thanks
Apr 15, 2008 | Toshiba 51H93 51" Rear Projection HDTV
Tv will not turn on even when reset button is pushed all you hear is a clicking noise
You need to replace the power supply on your set, this happen when horizontal output fail.
Dec 18, 2010 | Toshiba 51H93 51" Rear Projection HDTV
Screen had a red an blue blur
lilretard93,
Try using the convergence adjustment; listed at the bottom under the picture settings in the menu. If you are unable to focus the TV using its convergence adjustment it's time to call the TV repair guy. Figure about $300.00 USD for your model.
-Chris
Aug 23, 2010 | Toshiba 51H93 51" Rear Projection HDTV
I bought a used Toshiba 51HC85 less than 2 months ago. It has been working fine...until yesterday. I watched the morning news, and when I came home for lunch, it wouldn't come on. The red power light comes...
Sounds like the power supply went south on you.
Its likely that one of the supplied voltages is missing or low coming out of the regulated power supply. Its not something that you'll be able to do yourself. If you call a Toshiba authorized service center, expect to spend $250-400 to resolve this.
michtech
Feb 20, 2009 | Toshiba 51H93 51" Rear Projection HDTV
Will not turn on
if main power supply is working check sub power supply.should be 1.5 volts on pe 42 pin8 and 9.
if missing replace ce36 and ce 39. i mounted mine caps on foil side.
May 20, 2008 | Toshiba 51H93 51" Rear Projection HDTV
Toshiba 51H93 .
check for cracks in the driver circuit, also i believe this maybe on of the models that had a kit that helped from driving the h-output to hard causing it to get hotter then normal.
Apr 11, 2008 | Toshiba 51H93 51" Rear Projection HDTV
Horizontal output transistor failure
check b+ comming from p/s. also check for blue flat caps in line with h-output circuit. if blown out the side. remove them from circuit. also might have a HVT goin bad. I believe this is also the model that might have a mod for h-out running too hott that requires adding a resister in the h-drive circuit. also try a heavier duty h-output.
Apr 09, 2008 | Toshiba 51H93 51" Rear Projection HDTV
Tv struck by lightning
This set is pretty common for the regulator IC to go bad. Its inside on the power supply Printed circuit boad assy. It will start with STR#### and have 4 digits after the STR####, depending on the model of the set. Good Luck
Jun 03, 2006 | Toshiba 51H93 51" Rear Projection HDTV
Toshiba 51H93 51" Rear Projection HDTV Logo
604 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
