Question about Acer AL1711 17" Flat Panel LCD Monitor
Acer LCD AL1711 Monitor Flashes Colors
I dont know how to fix this, I've tried the turning it off then turning it back on holding the power button but it still flashes does anybody think they have another solution?
    Genius:
  • 1,689 Answers
Main power supply, and or the backplane power supply, and or the backplane lamps usually cause this.
The fix is to try new modules using the process of illimination. Once the defective modules are determined, the new ones must stay in the monitor.
That is the process used to service this monitor.
Jerry G.
Posted on Jul 15, 2008
Acer AL1711 17" LCD Monitor showing white screen
A white screen indicates the power supply board is not putting out the correct voltages to properly power the monitor, just the back light. This type of issue is caused by a failure of the filter capacitors on the power board. You can rebuild your power supply board and bring the monitor back to life by just replacing the the bad capacitors. The problem is that model the Acer AL1711 could come with 1 of 4 different power supply boards install depending and the date manufacturer and supply on hand. If you want to repair the monitor if you could open the unit and get either the model number of the power supply board or send a picture of the board to me I will be glad to help you repair the unit and get it back up and running. You can contact me to send the information at tech@ccl-la.com
Nov 30, 2012 | Acer AL1711 17" LCD Monitor
Monitor wont turn on power button flashes green and yellow
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Service manuals: www.elektrotanya.com
May 09, 2010 | Acer AL1711 17" LCD Monitor
THE ACER MONITOR AL1711 BLINKING IN DIFFERENT COLOURS AFTER THE COMPUTER IS SHUTDOWN - TO STOP IT I HAVE TO REMOVE THE POWER TO THE MONITOR OR BEFORE SHUTTING DOWN I HAVE TO PUT THE POWER OFF FROM THE...
I just had this problem at work and what I did was I powered up the computer and went into the menu. I went to the 2nd to last button and selected the reset. It's working perfectly now. I do not know if it will last but it's easy and free.
Jan 23, 2009 | Acer AL1711 17" LCD Monitor
Processing auto configuration
Check your settings in "Power Options Properties".
Control panel/ power options/ advanced/ under power buttons make sure you have "shut down" when you press the power button on your computer.
I hope I am understanding your problem correctly. If not pls. explain what you mean by and when processing auto config. keeps flashing. Is there a black screen or a windows interface?
Nov 18, 2008 | Acer AL1711 17" LCD Monitor
Al1711 Problem....
White screen is normally a problem with the LCD panel,generally difficult to repair
Samir.
Oct 25, 2008 | Acer AL1711 17" LCD Monitor
Acer L1711
Old request but . . . .
If you have the monitor connected and turned on, reboot the PC. It's possible that Windows will see both the monitor and sound capabilities and reinstall drivers for both.
Apr 28, 2008 | Acer AL1711 17" LCD Monitor
What is wrong with my AL1711
This is possibly an inverter. When the monitor goes out, examine the LCD to see if you can see a faint image of the video being displayed. IF so, replace inverter. If not, possibly a bad LCD or video circuitry.
Dec 07, 2007 | Acer AL1711 17" LCD Monitor
Monitor flashes primary colors
Your monitor has disco fever and will have to be shot in a midnight ritual in Palm Springs. Or, you will have to replace a diac circuit linking the display, power control, and power supply grounds (or possibly an overvolt protector of some sort in the power supply.) I don't know why for this kind of error the designer couldn't just put a message on the OSD in some random human language.
Nov 21, 2007 | Acer AL1711 17" LCD Monitor
Acer Al 1711 Monitor
Turn the monitor ON and continue to hold the power button for a few seconds.
Worked for me :)
Nov 09, 2007 | Acer AL1711 17" LCD Monitor
HELP!! ACER AL1711 On and Off forever
Most of these have inverters that power the LCD monitor more than likey that is what happened! These can be repaired, but you will get charged an nominal amount. Better off getting a new one! You better get one soon, 17" monitors will soon be out, they will no longer be sold as the standard will soon be 19".
Nov 17, 2006 | Acer AL1711 17" Flat Panel LCD Monitor
Acer AL1711 17" Flat Panel LCD Monitor Logo
330 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
