Question about Epson AcuLaser C900 Printer
How to change toner cartridges.
I got a Epson ALC900 printer without the manuals. There is no control panel or display on it.
How can I change the toner cartridges? The Magenta and Yellow are empty or very close to it.
Please explain it step by step. Your help very much appreciated.
Thanks
Joseph
  • 1 more comment
  • Anonymous Aug 21, 2008
    you need to load Epson status monitor
  • rob_real1602 Jan 19, 2009
    i can't seem to find that round plastic thing to be pushed in with a key/screwdriver though I carefully pressed every possible round object near the big toner..no avail.
  • Anonymous Apr 07, 2009
    thanks for your suggest, really very easy (when I fund the microscopic little strange and rare button to release the mecchanism..
Read some of the other problems and answers and found out how to move the cassettes around manually.
Press a little spring loaded button beneath an oval hole to the left of the cassette removal hole with something like a key or flat screwdriver. This enables the cassettes to be moved around manually anti-clockwise until the one that needs changing is in position. Then just carefully pull it out. Push in the new cassette after rolling and rocking to ensure the toner is distributed as advised in all instructions.
This method is actually much easier that trying to do it from the software in your your PC or Mac. Don't know if it means that some things are not reset - but it worked perfectly for me. In fact once I knew how, it was the easiest cassette change I have ever done........!
Posted on Sep 25, 2008
Epson printer CX9300 error B73 cannot recognise ink cartridge
A clone cartridge is a type of third-party ink cartridge that uses an identical chip to the original ink cartridge. People buy cloned cartridges to save money, since original cartridges are more expensive. However, sometimes the Epson printer does not recognize the cloned ink cartridge. After you install the cartridge, you might receive a message that says "An ink cartridge cannot be recognized." In this case, you will have to disable the Epson printer monitor.
Read more: How to Make an Epson Printer Recognize Clone Cartridges ' eHow.co.uk http://www.ehow.co.uk/how_6163069_make-printer-recognize-clone-cartridges.html#ixzz1YgKjqw42
Instructions
    • 1
      Install your cloned ink cartridge into the Epson printer.
    • 2
      Go to "Start > Control Panel" on your computer.
    • 3
      Double-click on "Printer."
    • 4
      Right-click on the icon of your Epson printer and choose "Printer Preferences" at the bottom of the dialog box.
    • 5
      Click on the tab entitled "Speed and Progress" and see the Epson printer monitor box.
    • 6
      Check off the box that says "Disable Epson Status Monitor" to turn off the ink monitor.
    • 7
      Click "Save" and close the windows. Your cloned ink cartridges should now work.
Epson may also display an error message if you refill the ink cartridges.
Mar 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
The printer is giving me service error E527 what can be done to overcome this error
Hi Good day!!!
This error message "Service Req E527" means that the toner carousel housing the toner cartridges is obstructed, or is unable to rotate correctly. It can be caused by installing a toner cartridge incorrectly.
Solution 1:Check that the toner cartridge at the front of the printer is installed correctly.
Solution 2: Manually remove all of the toner cartridges.
Close all the covers, and then power the printer off.Open Cover B, and then remove the photo conductor unit (PCU).Turn the toner carousel by hand to line up a toner cartridge with the front of the printer.Open Cover A.If the toner cartridge is not in position to remove it, close Cover A and repeat the steps above.Remove the toner cartridge, and then close Cover A.Repeat all the steps above until you have removed all four toner cartridges.Reinstall the PCU.Close all the covers, and then power on the printer.Open Cover A and Cover B.Check thoroughly for any jammed paper, foreign objects or damaged parts.If you can locate an obstruction, remove it. Then, close all the covers and restart the printer again. If you can identify any damaged parts, there is an obstruction you cannot remove, or there is no change after restarting the printer, then contact Epson for further advice.Reinstall the toner cartridges (Follow the prompts on the LCD display), and then test the printer.
Don't forget to vote thanks!!!
Nov 02, 2010 | Epson ACULASER CX11NF All-In-One Printer
How exchange cartridge for Epson C1100
Make sure that Ready or Sleep is displayed in the LCD panel.
Select Change Toner X (The letters C, M, Y, or K appear in place of X, indicating the colors Cyan, Magenta, Yellow, and Black.) in the Reset Menu on the control panel.While the cartridge X you selected above moves to the cartridge replacement position, Please Wait appears on the LCD panel.Replace Toner X appears in the LCD panel when the cartridge to be replaced reaches the cartridge replacement position.Then Open Cover A.Push up the right lever to unlock the toner cartridge. Then remove the toner cartridge from the printer.
May 15, 2010 | Epson Aculaser C1100 Printer
Toners c1100 epson
Easiest way is to open the front door, poke a screw driver into the interlock on the left side and this will free the carriage to rotate.
You can also do this via the printer driver, and the printer control panel. It's all listed in the User Manual.
Jul 04, 2008 | Epson Aculaser C1100 Printer
Toner changing
Open the front door, poke a screwdriver into the interlock on the left side. Rotate the carriage as you wish.
You can also rotate to the correct cartridge by using the printer driver and via the control panel on the printer.
Jul 03, 2008 | Epson Aculaser C1100 Printer
Black Cartridge just changed, but still says K-toner low
The only way to clear the message is to wait until the the display shows XXXX Toner Out, then change the cartridge and the message will clear itself.
May 18, 2008 | Epson AcuLaser C4000 Printer
How to change cartdridge for other color???
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the printers' control panel, press the "right" button (labeled no. 3) once and then the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the "right" button (labeled no. 3) once.
3. Press the "down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the "right" button (labeled no. 3) once. The printer will rotate the toner carousel to the correct position for you to change.
5. Open the printer door and change the toner as normal.
Jan 20, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100N - Black Toner problem
IF the problem persists with an original cartridge then the factory settings should be restored refer the manual or go through the settings in the control panel . minimise the tone of printing . If toner is getting accumulated in the printer then it might be due to refilled toner not the original cartridge . use the original cartridges
Nov 18, 2007 | Epson Aculaser C1100 Printer
Epson aculaser c1100 cant access empty ink cartridge.
go to the reset menu (right arrow and then down arrow until reset menu is displayed) on the lcd display and then choose change toner #(right arrow until the desired toner is displayed) Hope this helps
Sep 27, 2007 | Epson Aculaser C1100 Printer
Epson AcuLaser C900 Printer Logo
362 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
