Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Refri temp 60degrees
I was wondering if you know what shoud I do to get my frig to work. My inside frig is reading 55-60 degrees but the freezer is still working great.. Please email me a solution if you have anything that I can do. My email address is qbozz@comcast.net. I cleaned everything their is to clean.
Please help...Thanks
  • 828 Answers
Try down behind the crisper drawers where you will find a vent opening to the lower section of the freezer. It may be blocked by ice buildup. Also check and see if there is frost buildup on the back wall of the freezer. These items can stop the air to the refrigerator and even though you may think the freezer is working O.K. it could be the source of your problem.
Posted on Jul 17, 2008
I have Samsung fridge model RS267LBSH. The freezer works but why won't the frig side cool?
If the door temp is reading low then it will not cool as that is the temperature the fridge thinks it is at (regardless of the real temperature). Try setting the door temp lower and see if there is still a 14 degree difference between the 2 readings. If it does cool down further and the difference is the same then I would suspect the thermostat.
Aug 16, 2015 | Samsung Refrigerators
Freezer is below 0 and refri is about 5 degrees. It does cut on & off
That is way too cold. There should be an adjustment knob to set temperature. If it is a new frig, call the dealer and go for the warranty if that doesn't work.
May 04, 2015 | Frigidaire Refrigerators
Amana bottom freezer temp 16 below. Turn temp down a little temp goes to 20 above
With that kind of spuratic actions I would strongly lean toward that the temperature control, also know as the cold control , is probably malfucntioning. Before I can 100% call that fact I would need more inforamtion, model number the most important. Also, a description of how the machine looks on the inside, like frost on the wall, ice, etc.
Apr 29, 2012 | Refrigerators
253.64802409 (model), serial #BA60607122. Top freezer and I am haqving to defrost freezer every 3-7 days. The frig part of it goes up to 60 degrees. I would like to know how many cubic feet this frig is
Just measure the the inside of the fzr and frige and multiply length x width x hieght this will give you your cubic feet. (you will have to convert inches to feet) It sounds like your defrost timer, heating element in freezer, or the Hi temp sensor for the defrost cycle is bad more than likely the timer or element. good luck
Aug 10, 2010 | Refrigerators
Have sub zero side by side freezer and frig 1981. Frig is out. Does that mean the freezer also out and why is frig part out and what dial number shoud frig be on?
nope you have 2 compressor 1 for the fridge one for the freezer. is like 2 complete diferent units. we recomend the set point in number 5. is arond 37 degrees
Mar 13, 2010 | Sub-Zero 695/O Side by Side Refrigerator
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
My frig. in the garage.. The freezer works great in summer months but in winter months it doesn't. Why is that?
Good day,
That is normal. The thermostat that runs the whole machine is located in the refrigerator compartment.
When it reaches normal temperature, it shuts off. In winter months that may mean as long as 12 hours or more. Thus not enough running time per day to keep the freezer near it's normal temperature.
Engineers design domestic refrigerators to be in an area comfortable to humans. Normally 70 degrees or higher. Thus your problem.
The only solution is to bring the machine inside.
Sorry.
Thank you for using FixYa
Dec 29, 2009 | Refrigerators
My ge profile psc25msta model's freezer is at 5 degrees and the fridge is 48. HELP!
5 def in freezer is good / look for frost on back for freezer . this would prevent air flow to fresh food side . laso both fans must be going . inside fan may be going to slow ( repl if so. ) clean coils under frig this will cause over run and poor refri. mm
Dec 07, 2009 | Washing Machines
Frig does not stay cold enough
you are either low on coolant or the fan inside the freezer compartment is stuck or defective.
Mar 25, 2009 | Kenmore 55203 Side by Side Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
96 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
