I have a Linksys Wireless-G USB adapter that I'm trying to install on a laptop with windows 98. Everything I do never works. Is it possible?
  • ljamisonii Jul 15, 2008
    have you had any errors when you tried to install the software? because when I do, my screen goes black with an error code on it.
    Sergeant:
    Champion:
  • 327 Answers
Yes it is goto linkysys website and find the driver download for windows 98 it is there i have seen it and i have the same router
i hope this helps you out
Posted on Jul 15, 2008
  • victoria bennett
    victoria bennett Jul 15, 2008
    yes i have and most time when i reboot the computr and then redownload them they work fine
Linksys USB300M cannot install driver for win 98 there is no "installer" on the CD and win98 does not see it for an automatic startup
This adapter is only supported on Windows 98 SE (Second Edition), not older versions of Windows 98. The drivers are already built into Windows 98 SE.
Apr 08, 2011 | Cisco Linksys USB300M Adapter Adapters USB...
I bought AE1000 wireless N USB adapter, and i cant get it to install, says "wireless adapter setup requires that wireless connections are managed by Microsoft windows, says to try the following,...
When you insert the setup disk on your computer, you can exit from the setup and then connect the adapter to the computer and a new window will popup "Found New Hardware Wizzard" and in that select the option "Install the drivers Automatically" and click on next, so it will automatically search for the drivers and install it on your computer... Once the drivers are installed on your computer then you can try to connect to your wireless network.
Setup
The Linksys AE1000 Wireless USB Adapter helps you connect your computer to a wireless network for quick Internet access. Installing the Linksys AE1000 is fairly easy. Just follow the steps below in setting up the Linksys AE1000 on your computer or laptop.
Minimum system requirements
- A computer with 1 GHz or faster processor.
- 512MB or more RAM.
- An available USB port.
NOTE: The Linksys AE1000 is supported for Windows 7, Vista SP1 and XP SP3 but NOT for Mac.
Step 1:
Insert the Setup CD into your CD-ROM drive.
Step 2:
Click Set up your Linksys Adapter. Proceed to Step 4.
If you do not see this, click Start on your computer and click Computer. Double-click on your CD-ROM drive. Continue to Step 3.
NOTE: For Windows XP, the file may be known as Setup.exe.
Step 3:
Read the License Agreement and click Next.
Step 4:
Insert the Wireless USB Adapter into a USB port on your computer or laptop.
Alternatively, you can also use the USB Extension Base to connect the Wireless USB Adapter. Plug the Wireless USB Adapter into the USB Extension Base and connect the Base to a USB port on your computer or laptop.
Step 5:
If you have an Easy Setup key, select Yes, I have an Easy Setup Key and click Next. Proceed to Step 8.
Otherwise, select No, I don't have an Easy Setup Key and click Next. Proceed to Step 6.
NOTE: For more information on Easy Setup Key, click here.
Step 6:
Select your wireless network and click Next.
Step 7:
If prompted, enter the wireless password for your network. Proceed to Step 10.
Step 8:
Follow the on-screen instructions. Click Next once you have completed the on-screen instructions.
Step 9:
The installation is complete when you see the screen below. Click OK.
Step 10:
You are directed to the Cisco Connect screen. Click Close to exit.
Nov 04, 2010 | Linksys AE1000 IEEE 80211abg IEEE80211n...
I tried to access my network by the adapter Linksys WUSB54GC Wireless-G USB on windows 7 but I can't. the driver with adapter for windows xp and vista I installed the vista driver, it's don but not...
You have to connect to your network without using wireless then u have to go to the linksys website and download the windows 7 driver. Install that driver then u can connect with wireless. Worked for me! Gl.
Aug 04, 2010 | Linksys WUSB54GC 802.11g/b Wireless...
Linksys compact wirelless G USB adapter model noWUSB54GC wersion1 a cant find driver for windows7
The driver for windows xp should be compatible with windows 7, Try to install it that way if it doesn't work call Linksys tech support 18003267114
Jan 16, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Linksys compact wireless-g usb adapter won't install
It appears that the Windows service WLAN Auto Config was stopped due to an unknown reason. After re-activating this service I was able to install the wireless usb adapter 100% correctly. The Windows service WLAN Auto Config can be found if you run the program msconfig.
Dec 04, 2009 | Linksys Wireless-G WUSB54GC (WUSB54GC-BP)
Wusb54g Linksys usb wireless adapter.
This wireless adapter wont work with Windows 98, the reason why your friend encounter an error when trying to install it, it will only work to windows2000 and higher that why you wont be able to install it on that computer, you can check this link and just click on datasheet so you can see the specs of computer in order for this adapter to work http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859843775&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=4377540888B31&displaypage=download#versiondetail
Hope that helps.........
Aug 26, 2008 | Linksys Wireless-G WUSB54GS 802.11g/b
Linksys WUSB54GC 802.11g/b.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859919492&packedargs=sku%3D1134691790190&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1949290190B03&displaypage=download#versiondetail
Select version 1.0
The .exe will install everything you need.
Mar 14, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Computers & Internet Logo
David Payne
David Payne
