Question about Sony STR-DE715 Receiver
Protector appears on the screen
How do you fix this?
I have the same problem, i also have a STR-DE715. I have two thunder acoustic speakers and two 12in. punch subs. Now when i only play the subs i can go max volume, no problem, great bass the whole deal. Then when i play the thunder speakers i cant even go half way without the receiver shutting off and saying "protector" on the screen(both the speakers are 120 watt). From personal experience i think it could be the speakers youre using, either the receiver is giving too much juice and its preventing the speakers from blowing or the speakers need more power and the receiver cant give it. So a new set of speaker might be what you need. The receiver is 280 watts so something in that zone should work out. Also try turning off the sound field if you're using more than two speakers for the front output (i read this in the manual, you can pull up the users manual on www.manualshark.org and see if you can find something i might've missed) it supposed tp help it in one way or another. E-mail me at flores_j@live.com and tell me if your problem was fixed or not. Im pretty curious myself to find a solution to this problem. hope this helps!
Posted on Sep 20, 2008
I pulled the screen protector off of My 7inch rca tablet and white, black, blue and brown vertical lines appeared.. How do I fix this, please ?
Seem like when you pull off the protector you have cause flat screen and bd connection to come loose they will have to take it apart to try to fix it
Feb 23, 2016 | RCA Televison & Video
Ipod touch screen is unresponsive but it makes sounds like normal
Fix an Unresponsive Ipod Screen
Many of today's electronic devices including cell phones, music players and portable game systems have a touch screen.
When a touch screen fails, it does not respond when you tap it with your finger or a stylus.
This can happen due to several reasons, such as a screen protector, dust or improper calibration.
You can often fix an unresponsive touch screen by cleaning it or resetting the device.
Remove the plastic touch screen protector sheet.
Some protector sheets are too thick and prevent the touch screen from responding to your touch. If you must use a protector screen, only use one that is licensed for your specific device.
Wipe the screen with a soft microfiber cloth.
Clean off any dirt, dust or fingerprints on the screen.
Dry your hands thoroughly.
The touch screen will not respond if your hands are wet.
Reset the device.
If your device does not have a "Reset" button, remove the battery, memory card or SIM card, then reinstall them.
Delete any third-party applications you recently installed.
Some third-party applications can cause your device to lock up or freeze.
Recalibrate the touch screen.
Look in the device's Settings menu for a calibration option and follow the prompts.
http://support.apple.com/kb/ts2771
iPod touch: Hardware troubleshooting
If this fails to fix the problem
Press the "On/Off-Sleep/Wake" button and hold it for a few seconds, until a red slider appears. Press the "Home" button until the frozen app quits.
If this doesn't work, you can try restarting the iPod touch.
Press the "On/Off-Sleep/Wake" button if you need to restart the iPod touch, and hold it until the red slider appears on the screen.
Slide your finger over the slider to turn off the device.
Press the "On/Off-Sleep/Wake" button and hold it until the iPod touch turns back on.
If you can't turn off the iPod touch, you can try resetting it.
Press the "On/Off-Sleep/Wake" button while simultaneously pressing the "Home" button when you want to reset the iPod touch, and continue to hold the buttons for at least 10 seconds, until the screen goes black and the Apple logo appears.
Jul 31, 2013 | Apple iPod touch
How do you get bubbles out of iPad screen protector?
To lift the protector off one edge of the display, place a sticky tape on the edge of the protector and then pull on the sticky tape to lift off the protector.
Lift the screen protector from one edge, peel it back to the last bubble then re-fix the protector in place by slowly apply pressure across the proctector as you push the protector onto the display making sure no bubbles forms between the display and the protector.
Dec 28, 2011 | Apple iPad Tablets & eReaders
How do I clean the LG KP500 screen protector
Hello Sir,
It seems that you have got dust in the inner adhesive part of the screen protector. If that is so, there isn't a way to clean it. You have to get a new screen protector. If you have dust and other particles on the screen protector, then use a micro fiber cloth. That is the best.
Reply me back for any future inconveniences.
Thank you Sir, Have a nice day.
Jan 13, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
SONY BRAVIA KDL-40s4100 is not working right
Please check whether the connections are secured between the TV and the connected devices.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Try connecting the TV to a different wall outlet and check if that helps.
Please connect a different device to the TV and check whether the issue persists.
If the issue still persists service of the TV is determined.
Jun 18, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
I put a plastic screen protector on my blackberry 8310 and when trying to remove the screen protector because it was twisted,spots like water appeared between the lcd screen and the plastic cover of the...
When you put the plastic screen on make sure that the plastic and the screen on the phone are absolutely clean. If there is any dirt or debris on either the plastic screen will not sit directly on the phone and bubble up where there is residue.
Jun 04, 2009 | RIM BlackBerry Curve 8310 Smartphone
Sony Bravia KLV-40U100M-screen is distorted, overlay or various vertical lines
The resolution on this was to check the surge protector the television was plugged into. Once we unplugged and plugged into another surge protector, the screen went back to normal and the appearance was great. We believe this was due to one of the resistors within the surge protector may have become faulty.
Oct 08, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Protector mode SONY STR D1011S am fm receiver
I've had this happen, it's when you have speaker wires crossed.....
Dec 27, 2007 | Sony STR-DE945 Receiver
Rca hd61thw263 61 in. dlp
Seems a lightning strike took out my bulb
eventhough i have a surge protector.
after replacing the bulb perhaps 1 hour later a shadow began to appear at the top of the screen and progressed slowly down until only the edges are visible.
please can you help?
Sep 09, 2007 | RCA HD61THW263 61" Rear Projection HDTV
Screen Protectors
When you apply the screen protector, try to flatten it out with a CC as you apply it.
Sep 13, 2005 | Dell Axim X5 Pocket PC
236 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
