Question about Optoma Televison & Video
Need a new lamp for RD50 tv. - Optoma Televison & Video
  • 927 Answers
Good Day, jo;
When getting a new lamp it is less expensive and faster to purchase the needed lamp from the manufacture of TV. (Make sure you have model number at hand). They will send lamp directly to your home, the lamp will have enclosed instructions on replacement and any special tools you may require. It is very simple and will only take about 15 minutes at the most to replace.
Good Luck, big IRISH.
Posted on Jul 15, 2008
I replaced the bulb in this tv a year and half ago, and the tv just went out and will not come on. Could it need another bulb/lamp?
Yes, bulb life varies from bulb to bulb and how many times it is turned on and off. Do you get any flashing codes? In your manual you should find something on a bulb life indicator, some flash on the front of the set others are in the menu, look and see what it says there. If your getting any flashing codes on your indicator light let me know what they are as well
Jan 29, 2011 | Optoma RD50 50" Rear Projection HDTV-Ready...
I replaced my RD50's lamp recently and everything works perfectly, but the notice telling me that it is time to replace my light continues to display every time I turn the set on. There is probably a way...
There should be a reset lamp function in the service section of the menu. If there isn't, there is a way to do it by pushing and holding a sequence of buttons on the tv or remote. It varys from model to model. Check your manaul to see what the correct proceedure would be for your model.
Feb 09, 2010 | Optoma RD50 Television
My Optoma HDTV Model RD50 needs replacement of its internal lamp. Which model lamp is the correct one and how much does the lamp cost? Regards - Lee
Call Optoma technical support listed on the optomatv website. They will ask for the set serial number. Based on the serial number, they will tell you which replacement lamp is the correct model for your TV. (I found this out after ordering the wrong replacement lamp based simply on the model number of my TV and finding that it did not fit.)
Jan 11, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
I turn on the tv but I get no picture (black screen). A sound starts when I turn on the tv. The sound ( like a humming noise) fan perhaps which goes up and down for about a minute then the tv shuts off and...
Sounds like a problem with the color wheel. Unfortunately the color wheel is located inside the light engine. According to everything I have read, the only thing you can do is replace the light engine. You are better off replacing the TV. The light engines can run form $750 to $1400. Which is ridiculous!
Jan 02, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Ghost images!
I had the same problem, reset the lamp hours by pressing 'menu, 619 , menu" and browsing until I found the setting, but then I also saw an option to test the lamp.  The TV shut off when I tried this and 2 red lights indicating a new lamp is needed came on instead.  It's probably the ballast and not the lamp, but I don't know that I want to put any more money into this set.  I have only had it 2 years.
Apr 26, 2008 | Optoma RD50 50" Rear Projection HDTV-Ready...
Lamp light on picture off
You might try unplugging the set for maybe 20 mins. to see if that might help in resetting the internals. Good luck!
Mar 25, 2008 | Optoma RD50 50" Rear Projection HDTV-Ready...
Optoma RD50 Lamp Issues
replace the fuse thats on the little board beside the new lamp. that will reset the buld to new. I understand that the fuse will blow right after a new lamp is installed. It will reset the counter to 0.
Hope this helps
Ron
Dec 30, 2007 | Optoma RD50 50" Rear Projection HDTV-Ready...
After lamp replacement
Sounds like the plug is not making a good connection needs to be seated better.
Dec 10, 2007 | Optoma RD65 65" Rear Projection HDTV
Optoma RD50 Picture Flashing ghost images
Hello! Just a little additional info if you will on what might to expect. This is according to the repairman where my tv is still in the shop after almost 2 wks because of the need for parts: other than the lamp the only place to get other parts (ballast and color wheel) is from Optoma and if yu need the color wheel you will have to purchase the entire assembly ($999.99) because they do not sell it separately. If anyone knows differently please let me know for I am between a rock (not really) and a hard place.
Dec 04, 2007 | Optoma RD50 50" Rear Projection HDTV-Ready...
Televison & Video Logo
48 people viewed this question
Top Optoma Televison & Video Experts
jasbo
jasbo
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
