Question about ViewSonic Computers & Internet
A new 22" Viewsonic VX2235WM will not work on digital. When I turn on the computer the screen is black. It works ok on a friends anolouge
  • 2 more comments
  • billmc15 Jul 15, 2008
    22" Viewsonic VX2235WM will not work on digital. Works on anolouge. The screen is black on startup. Tried it on 3 different computers with same result. Other lcds work fine
    tried it on 3 different computers with 3 different cards
    still does not work
  • billmc15 Jul 17, 2008
    the problem with a new digital connection cable
  • ViewSonic Master
  • 13,433 Answers
So the dvi side of the lcd screen would be faulty then. Is the screen still under warranty? its generally year or more in these, I have 3 years in my Asus displays.
Check your warranty if you still have warranty that should cover the repair or replacement.
Posted on Jul 15, 2008
  • 2,071 Answers
1. It could be limitation of your video card. Older cards would not support high resolution for LCD monitors.
2. Be sure to use DVI(digital) output from your video card. You will not get a good resolution with VGA(analog)
3. When installing driver for a monitor sometimes you will get a chose to install analog(VGA) or digital(DVI) driver. Choose the correct driver.
  • 2,427 Answers
Did you check your video card settings to see if its enabled,
To do thsi you need a monitor so you can actually see what you are doing
1.) right click on the desktop and you should see you graphics card in the select menu. Click on your card. Browse the settings to see its digital enabled or something to that effect, or the monitor type (differecnt cards have different settings)
or
Right click the desktop and choose properties.
That should work actuall that can be the only problem, the monitor is fine its just the display settings thats not. Your friend's computer has the correct settings but yours and the 3 others does not.
You can also
  • Rishi Roshan Ali Jul 15, 2008
    Look at the refresh rate, hardware accelleration and Resolution any of these can also affect the the display
    Lower your resolution and your refresh rate as well as the hardare accelleration to as lowest it it would go.. and find out what graphics card your friend is using and please specify what card u got.
  • 868 Answers
Go into your display settings on your computer using a monitor thats compatible.In the advanced section you can change the mode.Lower it all the way down ,and re try the new monitor.
Please Rate This!
  • 6,487 Answers
That can be a problem with your video card, So if you have a spare video card try it on that monitor.
Hope that helps...........
  • 1 more comment
  • Mark Gil
    Mark Gil Jul 15, 2008
    That's kind or weird, the working LCD on that CPU are they using the same brand/model of video card?? and also the other LCD are they same model with the one that you just purchased?
    Keep us posted.....
  • Mark Gil
    So I think it will be better if you just have that LCD replace since it did not work with 3 CPU that you have tried evethough it work on your friends CPU..
    Good luck........
  • Mark Gil
    Mark Gil Jul 18, 2008
    So you already made work>?
    Genius:
  • 1,847 Answers
Are you sure that you are connection it to the white port.
  • Legin Varghese
    Legin Varghese Jul 15, 2008
    See the white port is for digital and the blue is analog.
No power to vx2235wm. How can I fix it?
Black screens or no pictures are usually caused by a failure in the back light power supply. Many times the monitor is working but with the back lights not turning on you can't see the display. Here is a link to a repair guide that will show you how to open the unit and what to look for and replace to rebuild the power supply and bring the unit back to life.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Dec 07, 2011 | ViewSonic VX2235WM Monitor
Hi, I have ViewSonic VX2235wm-5 22"
It appear the monitor has been connected to another system unit than the default. disconnect the entire systems and reconnect altogether, restart the computer to allow the unit to recognise the new monitor. should diplay possible soluiton, else follow the instrcutions below
1.locate the control panel where the options of systems setting is displyed.
2. a click should dispaly a list among which is device speaker options
3. the computer speaker could be updated by clicking to install drivers or codes acquirable from the network.
alternately
1. click on the hardware icons located after locating and clicking into control panel.
2. on the list of add delete hardware provides the option to attempt to delete the speaker codes
3. a delete of the speaker drivers on system restart would prompt the user to update the speakers. A click on the prompt should acquire the necessary installation kit patches from an internet connection if any.
Dec 06, 2010 | ViewSonic VX2235WM Monitor
Viewsonic monitor vx2035wm goes black with a steady blue light on power button when the monitor is turned off or computer is restarted. Disconnecting it and letting it sit for a minimum of 24 hours makes...
I've been having the same problems with my Viewsonic.I plug it in and the blue light blinks but there's no picture it's just a black screen.I do know if Viewsonic doesn't repair my monitor I'll never buy anything from them again.I have the LCD Viewsonic 22' Vx2235wm monitor.
Does anyone have any idea what could be wrong with mine?I've bought a new video cable & video card but the monitor still does the same thing?Thanks
Oct 29, 2010 | ViewSonic VX2035WM LCD Monitor
We have a Viewsonic VX2235wm Black 22" Widescreen We have been experiencing a Grey shadow to the right - damn annoying. Can you please help.
There are "on-screen controls" (electronic) on the monitor and can adjust the screen "position" up-down, left-right, wider-narrower and perhaps twist; clockwise-counter clockwise).
Try that and see if it removes the grey (empty?) area.
Brock
Sep 16, 2010 | Computers & Internet
Screen is black
Please look for bad caps as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Common problem with all LCD monitors.
Make sure to use good caps such as PANASONIC FM or FC series from Digikey.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 10, 2010 | ViewSonic VX2235WM Monitor
Trying to pack
Few steps to take the stand and base off the 22" ViewSonic VX2235WM
1- Squeeze the bottom of the base to take the base off from the collar
2-This step is very important. The collar has two parts snapped in together, with 3 snap in each side. Carefully use small flat screw driver to take off the back side of collar
Feb 19, 2010 | ViewSonic VX2235WM Monitor
Viewsonic monitor -- VX2235wm LCD
avintagedish, Possible problem w/unit power supply. Go trade it in on new a new wide screen so the electronics technician in the repair area of the store can (with a little luck) put less than $10 in parts into your unit and maybe have a nice VX2235WM to give to his 10 year old kid to play games on. I sure hope you have a valid warranty!! You should verify that VX2235WM does same at KNOWN GOOD pc!!! Swap-in a KNOWN GOOD monitor to prove pc is OK!!! Read my FIXYA profile and learn "flashlight test" for "rude an crude" test of "switch-mode-power-supply" status. Follow the links you find there to other web sites for more info. Check to see if ViewSonic has a cash+old swapout for factory refurbished unit for premature failed units! I'm lmistyrel over on aim. and 12fixlouie on FIXYA good luck in your quest to fix unit. It can be fixed. Just do your research FIRST! So you don't get ROOKED if you contract out the work. Read, read, and read some more!! Visit YOUTUBE for video clips of LCD monitor repair and disassembly. FYI.
Bye for now.
Feb 05, 2010 | ViewSonic VX2235WM Monitor
Black screen
Look in the power/inverter board for bad caps with bulging top first, post back what you see inside so we can you further, see failed VIEWSOINC due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 02, 2010 | ViewSonic VX2235WM Monitor
I have a viewsonic 22'' (I think) model VX2235wm. It has both digital and analog connections in back. Can I use both -- one going to one PC, the other to a 2nd PC -- and switch between them?
yes you can. If you need further assistance on how to do it please let me know though its as simple as switching inputs with the buttons on the monitor.
Thank you,
Lee
Apr 21, 2009 | ViewSonic VX2235wm LCD Monitor
Computers & Internet Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
