Question about Toshiba TP55H60 55" Rear Projection Television
No picture,good sound
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
About 2 years ago I replaced the stk's (Q751 and 752) which worked till about 2 weeks ago when bent color horizontal lines started appearing intermittently in the middle top of the screen. Last week ,the picture died completely but the sound still works. I replaced the two power amps again(Q751 & 75) but had the same problem. Right now, if the remote is used to power and shut down the TV, the sound will not come on but if the power cord is unplugged then plug in ,the sound will come on but not the picture and also when the TV is turned off, a bright horizontal flash / line on the middle of the screen appears before it shuts off . I checked the power supplies and they seem to be good. I got bogged down by the fact that on pin 11 of Z801 and on pin 1 of P806, schematic says that I am suppose to get 24.7 VDC referenced to GRD and +38 (H.VCC) on pin 1 of P806( also referenced to chassis grd) but I was getting 0.0 volts. I don't see the secondary of the transformer directly referenced or tied to chassis grd so this made me doubt whether this is a printing error or valid reading. Help is appreciated, Thank you.
    Genius:
  • 1,665 Answers
Highland Electrix TV Repair Advice no pic snd ok Page Highland Electrix TV Repair Advice no pic snd ok PageNo picture, sound ok
First increase tube's first anode voltage (knob on the loptx) to see if the screen is just too dark.
if after you have turned up the bottom knob on the loptx, there is still no brightness,check, for crt heaters, and EHT 25kv and focus voltage (2kv) and A1's/Screen/G2 voltage is 300-600v.
and check for field timebase (height), the next thing to check is the sandcastle pulse.
If it's present, colour decoder chip is probably faulty or lacks supply from the LT regulators.
Posted on Jul 25, 2008
  • 2,071 Answers
Click this for more information:
T.S.S. LOG FOR TOSHIBA updated 4-2-2002
Posted on Jul 15, 2008
  • LORETO LACARON
    LORETO LACARON Jul 27, 2008
    Over time a bad convergence circuit
    could mess up the power supply in the tv.this would make the projection
    tubes have no power, it is possible the main power supply section that supplies
    them is defective. Audio is working, so that section of the power supply seems
    okey.
    Therefore, I suggest you start at the power supply level. There may be a
    fusable resistor in the line somewhere that powers the filaments to the
    projection tubes. If you have a voltmeter you might want to trace the
    filament wiring back to the transformer and see where the power is lost.
    Click below for sample service manual
    with schematic diagram;
    Training Toshiba PLASMA TV PDP 42WP37
  • LORETO LACARON
    LORETO LACARON Aug 01, 2008
    Toshiba troubleshooting;
    No
    picture sound ok
    Note 1 a Raster is the name for a screen made of lines of brightness
    Note 2, A Blank raster has no snow or picture, its just a lit up screen
    Sound ok but no raster.
    sandcastle pulse.
    the LT regulators.
    NO LINE DRIVE
    If it's absent,check the line driver, locate the loptr(big
    and usually has heat sink).
    follow the print from the base back to the driver stage , where you will
    usually find a tiny transformer with 4/5 pins
    resolder it, even if it looks good,then with power on, check for voltage on all
    its pins, 2 should have LT(12v to 32v) or HT (90v to 150v), if not there follow
    the print back and look for either a transistor(linedrivetr), or the feed
    voltage line (maybe regulated),
    If the voltage is ok on two of the driver transformer(drvtx) legs, the look
    from the base of the driver transistor to locate the timebase chip
    and check round its pins for a 12v supply line, if there ,replace the timebase
    generator chip
    see NO
    line Drive
    Method of testing line drive, remove line output transistor, and connect a
    normal red led, across the B/E (longest leg to base), and when you power up the
    led should lite up.
    Master:
  • 848 Answers
If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer. Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
The tv looks like it is in 3d. when i try to adjust the convergiance the plus signs on the left are bent
do not play with this tv replace the stk ic chips and the resistors around the stk chips ,cant miss em about 2 inches big with heat sinks on them.
Sep 11, 2010 | JVC AV-48WP30 48" Rear Projection...
I have a Sony KP-53HS10 TV for over 9 years. It still works great, good picture. But few weeks ago, it started making a "ssssssi" noise after turning on 4~5 minutes. The noise might come from a cooling fan...
There are no fan in this tv.This tv most common problems are the dead convergence board parts have problems,picture have colors lines R,B,G out of alignment,have colors shadows,and 3D pictures.The convergence board must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved convergence problems.The problems u discribing,it a starting point,just the convergence problems,have not take it effect yet.Sooner or later ur tv will have the convergence problems.
Jun 23, 2010 | Sony KP-53HS10 TV
Im getting a whirring noise in the back of the tv but the picture and sound is still on. picture quality is still good. i dont know if its the fan. color wheel was replaced a year ago. but the tv stopped...
Well that whirring noise is most probable to be the color wheel. Funny thing you replaced it a year ago. But it's most probable that is the issue. You did get the right one, did you? Because with Samsung TVs they have 2 types of color wheels, either gold or silver bearing.
Aug 10, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Picture flickers in and out rapidly,gets blurry for about 5sec then looks like new for about 5sec then back again
Did you replaced 2 IC convergence as well or just 2 resitors 3.9 ohms ? if you did replaced 2 IC then you might have probelm in convergence drive it is1 of the PCB mount vertical on the left side from the rear view under part BP95-00415C you need to readjust the convergence by using your remote control just follow in the servive manual
Nov 22, 2008 | Samsung HC-P4752W 47" Rear Projection...
Three colors are not together
OK, Time to fix it !!. Replace two Ic's Stk 392-110, and get in service menu settings , and adjust point by point. After replaced stk IC's, check if any resistor look brown or born, if yes, replaced it with 6.8 Ohms. If you have questions? noetvs@embarqmail.com . Good Luck !!
Jul 22, 2008 | Philips 60PP9202 60" Rear Projection...
Lost color sync
sounds like you have a convergence problem. replace the 2 convergence chips STK 390-110.
Feb 04, 2007 | Toshiba TP50G60 50" Rear Projection...
Toshiba TP55H60 55" Rear Projection Television Logo
104 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
