Optics Logo
Posted on Jan 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model # F=5MM Model# F=10MM I received this telescope as a gift , the lens that are interchangeable were cracked after I opened the gift , if possible could I get these replaced . If possible can you send me a 1 800 number to reach a agent who can further assist me with this matter . Thank you very much . Gene Ballard
Narseman
Level 3:
President:
  • Master 1,088 Answers
  • Posted on Jan 17, 2011
Narseman
Master
Level 3:
President:
Answers
1088
Questions
Helped
311136
Points
3782
Where can i buy a replacement 10mm lens for celestron 31035 astromaster 76EQ telescope
There are various qualities of 10 mm, some fearsomely expensive. In the USA try here
http://www.optcorp.com/manufacturer/orion?cat=14
Hey guys! My brothers chipped in to get me a telescope for my birthday. It's a celestron sky prodigy 70. I took it out a few times with zero experience except for what I picked up from reading the owner...
Hi, I can see you'r statring a interesting journey in amateur astronomy. Which can be really amazing but also disappointing, because usually people are expecting too much (specially after viewing beautiful astronomy pictures on internet).
Before we go back to your question lets go over some basics here:
Your telescope has a F10 aperture (Focal lenght / Diameter).
So to be able to see the maximum amount of details from it, the smallest eyepiece you need is a 10mm (eyepiece mm = to f number of thetelescope).
Then it's easy to find the maximum useful magnification:
700mm (focal lenght) / 10mm (eyepiece) = 70x
Ok but why does the manufacturer say that it can be at a max of 170x... they are not really lying, if you get a smaller eyepiece it will make the image bigger but will show no additional details than a 10mm one. But the image being bigger it can make details easier to see.
That for the questions about magnification an image quality.
The more pieces you put between you eye and the telescope mirror, the dimmer and less contrasty the image will be. Especially after you go higher that the maximum useful magnification.
Hope this helps. And enjoy wathching the stars and planets, it is a always a beautiful sight.
Nov 08, 2013 • Optics
I have a zennox 700x76 with diemeter coated lens lenses h10 and h20 were do i get a lens to see things closer
The maximum magnification of any telescope is about 50 times aperture-- your scope is about 2.5 inches in diameter-- so 50 times 2.5 is about 125 power for your scope. Usually you only get 30-40 times aperture and 50 is only possible on perfect sky conditions.
You already have the 2 best eyepieces for that scope which are a 10mm and a 20mm. If you bought a 5mm you would only be able to use it a very few nights during the year (perfect sky nights) and it is more difficult to focus.
This company along with many others sell eyepieces--
http://www.agenaastro.com/
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Jul 29, 2011 • Optics
I am able to see with the 20m Lens but once i insert the 5mm Lens it looses focus and i cannot see anything, i tried adjusting the focus again with no success. The worst thing that even at day light i...
That's because the 5 mm is too much magnification for your small telescope. Maximum magnification is a function of APERTURE. Which is how big is the front lens or the mirror.
Your scope has about a 2 inch aperture, so the maximum posiible magnification is about 100 power (if it is like the one in the picture above)
50 times aperture (2 inches)-- 100 power
It will only achieve 50 times if the optics are perfect and the sky is very transparent and stable. Usually only 30-40 times is all you normally get.
5helpful
2answers
We just got this ata yard sale and for some reason we cant see through it i dont know any thing about these but need some help please
Thanks for the additional info.
Your telescope is a basic introductory model and so has very limited performance, but used correctly it's still a great introduction to astronomy. If you don't have it, download the user manual from here (courtesy of Retrevo).
If complete, it should have come with a 5mm and a 20mm eyepiece, also an erecting tube (so called as it ensures images are upright and also laterally corrected: used for terrestrial viewing only), a diagonal mirror and a 3x Barlow lens.
Only use the erecting tube for daytime viewing of distant objects on land or at sea. The diagonal mirror is what you use for astronomy and it allows a more comfortable viewing position: without it you'd be trying to crouch beneath the telescope and craning your neck upwards to look into the eyepiece. Check that the mirror inside is bright and clean; if it's dirty or corroded then images will be low contrast, dim or even impossible to see. The eyepieces allow different image magnifications; the 20mm one has the lowest magnification, but also the brightest images and vice-versa for the 5mm. To calculate the magnification, divide the objective lens focal length (in this case 700mm) by the eyepiece focal length. For the 20mm eyepiece you end up with 700/20 = 35 and for the 5mm it's 700/5 = 140. If you then add the 3x Barlow lens you end up with 105x and 420x.
You're probably thinking, "OK, but how does this fix my problem?" As long as the diagonal is clean then your problem is almost certainly badly chosen eyepieces by the manufacturer: the greater the magnification, the dimmer the image, and realistically the maximum useful magnification for a 60mm objective in perfect conditions is 120x and more usefully is 30x to 60x and these limits apply to a good quality telescope. Meade, Tasco and a few others are built to price first, impressive sounding features second and quality a very distant third, so those limits can be comfortably reduced. All of this means that whilst the 20mm eyepiece may be capable of providing a useful image, the 5mm really isn't and the 3x Barlow will be low quality and far too powerful. Using the 5mm even without the Barlow is going to result in too high a magnification. As the night sky is mostly dark, unless the telescope is directly pointing at a bright star you'll see nothing. Although a magnified image will show planets as discs, stars are so incredibly distant that even at the unusable 420x magnification they will still appear as near invisibly dark pinpoints, and at 140x will be very dim pinpoints. I use the word pinpoint hesitantly, as in all but the best conditions the Earth's atmosphere will cause the star to twinkle, so the pinpoint will be a blurry blob. The only reason to include the 5mm and the 3x Barlow is marketing: to a novice, a 420x telescope sounds far more impressive than one which may be more expensive but which only offer 120x maximum magnification.
In short, don't use the 5mm eyepiece or the 3x Barlow at all. Stick to the 20mm and if you only have the 5mm then go and buy a budget 20mm and a 12.5mm. If you join a local astronomy club you may even be offered them free of charge as someone is bound to have upgraded to better quality examples. If you stick to these eyepieces then your telescope will be great for observing the Moon and will be able to see Jupiter's four largest moons (don't expect to see details on Jupiter though). It will also be able to show Saturn as a spot with ears sticking out either side (the rings) but you won't see any detail. Mars will be a noticeably red disc but lacking in much detail. Although you won't be able to make stars appear to be any larger, you are able to see how many of them are actually binary stars. You need to upgrade the telescope quite a bit to improve on those images, and also to ensure that you're viewing away from city lights if possible. It also helps immensely if you leave the telescope outside for a few hours before using it, as warm air currents inside the telescope tube itself can be enough to ruin images. As long as you understand the limits of your telescope then even as a budget model it will teach you a lot and show you things you haven't seen before.
One final tip: it can be awkward to get the focus adjusted correctly using the rack and pinion mechanism. Use it to get as good as possible, and then adjust the fine focus using the eyepiece itself: if you examine yours then you'll probably find that the actual lens assembly is simply secured to the eyepiece tube by a screw thread. By tightening the small screw on the diagonal to grip the eyepiece tube you'll find that you can fine focus by turning the eyepiece lens assembly itself back and forth.
Sorry for so much detail, but I hope that you now understand that your bargain find probably isn't faulty at all but just needs the correct eyepiece under the right viewing conditions. Please take a moment to rate my answer or to ask for clarification if anything I've written is unclear.
Mar 13, 2010 • Optics
Can't focus using 5mm lens
TOO much magnification for that 3 inch telescope. The most you will get is about 120 power or so on perfect sky nights. Try a 10mm or 9 mm as your most powerful eyepiece.
50 times aperture is the maximum possible.
1helpful
How do I focus on the moon. Model 1400150. I have been gifted this telescope. Tried to focus on moon. Dont know how. Took big cap off end. Looked throughscope on top of large cylinder. Tried to focus...
first, use the lowest power eyepiece, that's the one with the high number on it with 'mm' after the number.
for a refractor telescope (uses lenses), you might have to add a diagnal lens (either 45 degree or 90 degree, whichever one you have) to focus on an object.
attach it in this order:
low power eyepiece-->diagnal lens-->main telescope
for a reflector telescope (uses mirrors, a telescope with a big tube with a mirror at the bottom and a focusing knob on one side of the tube). the open part of the tube points to your target.
hope this helps :D
2helpful
Can not see thru telescope.
Yes it will focus --- put the eyepiece with the LARGEST number written on it into the scope. DO NOT use the 2x or 3x barlow.
Practice focusing on a distant object at least 100 yards away during the day. The moon should be your first night time target.
Never used received in 10/2002 as a gift. It has
I answered in a previous post--- you posted this twice.
Lens came off-where do springs go?
There are a bunch of Sky Tour telescopes ---
http://www.opticsplanet.net/bushnell-warranty.html
which model you actually have??
I am assuming you have what is called a Dobsonian mounted reflector like this one:
http://www.bushnell.com/manuals/telescopes/78-4500_Voyager.pdf
Is that correct?
Top Vivitar Optics Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
ADMIN Andrew
ADMIN Andrew
Are you a Vivitar Optic Expert? Answer questions, earn points and help others
