Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
How do I hook up
By tral50 on Jul 15, 2008
How do I hook up a HD satallite dvr to a av reciever dvd player and HDTV using HDMI cables
Comments:
Jul 15, 2008
- I have a Direct tv DVR a Sharp HD Tv a denon avr-2307ci reciever and a sony dvd player
Jul 15, 2008
- Shouldn't my cable in go to the satallite box then I have hdmi to denon and Hdmi to HDTV. I also have optcal cable from Satallite to reciever. Please go over wiring again
Best Solution
posted on Jul 15, 2008
Very Helpful)
DARKLORD1
Rank: Guru
Rating: 86%, 712 votes
If you got the cables and you tv has the 3 or more input ports
then Connect the dvd player to input 1
connect the Direct tv to input 2
connect the reciver to input 3
If you are short on ports you can purchase a switch box which will allow you to connect multiple devices to just one input of the tv..
I hope that answerd your question as to what i precived it to be. For further details in actually making the connections check your user manual ,, you can use the manual for your tv or any of the device it will have detailed instructions on actually which jack the cable jacks into.
if this what you meant please explain ecaxtly what you wish to accomplish
Rating Locked! (?) tral50 has rated this solution as Very Helpful
Solution #2
Not Rated)
VOTIT
Rank: Wiz
Rating: 84%, 852 votes
click this sample wiring diagram
http://www.hdtv.ca/plasma_lcd_projector/plasma_tv_wiring1.php
Comments:
Solution #3
Somewhat Helpful)
marked
Rank: Guru
Rating: 86%, 934 votes
Things You’ll Need:
  • HD television
  • HD satellite or cable receiver
  • DVD player
  • Stereo receiver
  • AV cables
  • Cable connector
  • HDMI cables
Step1Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar). Step2Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV. Step3Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row. Step4Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV. Step5Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will). Step6Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal. Hope that helps..........
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
Green light goes on then back off and tv won't turn on when power button is pushed. This is a... (More)
Answer
converger for blue will not line up.... where is the computer board located at in the back of the... (More)
Answer
I have a WS-55313. The screen will go totally blue and a message appears that says- tv will shut off... (More)
Answer
TV keeps going into standby but sometims comes back on again straight away. Picture normally... (More)
Answer
i have a toshiba 43vj33 projection ctv with a projection blub broken can you fix it or no anyone can... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Projection Televisions:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
