Question about Motorola Mobility RAZR V3
How to program a certain ringtone for a certain phone number
How do I program a certain ringtone to play when a certain phone number is calling?
THANKS!
    Problem Solver:
  • 6 Answers
Go to whatever contact u want then choose options, select edit, go down to ringer id and choose the ringtone u want.
Posted on Jul 15, 2008
How to change call ringtone on nokia e63
Hi Violin,
I have this steps for you for work around setting up call ringtone. Hope it helps.
--- there should be no prob to set a custom tone if you go to the tone and select options you should get an option to select from a list from the menu otherwise go to profile and select edit then when you come to ringtone select options and you will get options you should be able to select a tone from the gallery
---I discovered something about this problem. It appears that if you have the same phone number assigned to two (or more) contacts the ringtone plays the default ringtone. Once I deleted one of the contacts with the same number, it played the correct custom ringtone. What is strange is that both contacts had the same ringtone. BTW, the reason I had done this was to simplify the voice command to make a call to this contact.
Apr 25, 2014 | Nokia E63 Cell Phone
How do i cahgne the ring tone on the panasonic kx-t7565 phone. I have changed it but it only appears to have chagned if ring ring the number internally. we need the ring tone to change from external...
The ringtone for the CO or outside line buttons can be programmed by pressing program then press the
CO button twice, enter the ringtone you want by dialing 01 to 08, press enter or store then program to end. This will set the ringtone for that line assuming it is programmed to ring at that phone. Transferred calls will use the ringtone of the intercom button which can be set by the same procedure. Use the same procedure if calls ring to a Group Directory Number(GDN) on the phone. The 7600 series of digital phones have ringtone settings of 01 through 30.
Dec 15, 2010 | Panasonic KX-T7565 Corded Telephone
Ringtone for each phone number
I have verizon too and I used to have this phone. You need to go to contacts, and choose the contact you want to put the custom ringtone for. Once you get to the contact you want to add the ringtone for, press edit. Scroll down till it says ringtone, then press "set" and choose from your list of ringtones. Press ok, then press save. This should work. If not, contact verizon because then it would be a software issue :) Hope I've helped you out!
Mar 19, 2009 | Samsung SCH-u340 Cellular Phone
Ringtone problem
You settings are not activated so please refer your phone user manual do the steps by step then it will work fine
1) First save the specific number
2) Select the ring tone
3) Assign the this ring tone for that number
This information help to you othere wise refer your phone user manuals
Jun 11, 2008 | LG VX8300 Cellular Phone
Ringtones
You need to check what ring style you have selected.. That will change eveyrthing.
Mar 13, 2008 | Motorola Mobility RAZR V3
When a text msg comes in it plays a mp3 instead of the normal text sound.
yes there is just go back into the setup and look at what you have as your text msg alert and change it.
Feb 01, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Setting Ringtones
just upgrade with flashing ur mobile
Jan 20, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Ringtone wont play
with the phone closed, goto tools, voice commands....click on settings in the lower right.......scroll down to call alert.......change to ring only or caller id+ring....on the env that should solve your problem
Dec 12, 2007 | LG enV VX9900 Cellular Phone
Phone wont play ringtone with incoming call eventhough one is selected will spell out number calli
Motorola Mobility RAZR V3 Logo
61 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
