Question about Necchi 3101 Mechanical Sewing Machine
Necchi 525 FA model
I have recently acquired a Model 525 FA Necchi machine and have no idea of the thread diagram, can some one please assist me.
Thank you,
Alton
pmg@islc.net
This site (www.sewusa.com) sells manuals for many types of sewing machines. It also has a section (on left side of home page) that provides basic information about treading (bobbins too) and repair.
I also own a 525 FA and just read that someone considers it is a piece of junk. I'm having problems with the tread breaking constantly (with many hours spent on this problem) and I even have a manual! Perhaps it is a piece of junk?
Marla
Posted on Nov 05, 2008
    New Friend:
Http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_534_535_threading_Diagram.htm
This web site has a nice diagram for a slightly different model but I think would serve your purpose.
Posted on Jun 11, 2013
4 Suggested Answers
SOURCE: Necchi automatic BU supernova sewing machine
Hello! Hello!
Your machine is probably not 50 years old. I have one just like it that we purchased about 5 years ago. Necchi makes a very sturdy reliable machine. There are a couple of tricks, though. First, your bobbin thread has to turn clockwise. If it doesn't, it will either not sew, the stitch will look horrible or the thread will break. Second, threading it is pretty easy; however, I can't explain some of the parts. I would be happy to scan the diagram and e-mail it to you. E-mail: daridoll@yahoo.com. The tension should be set at 3 unless you are doing a ruffle or close zigzagging (machine applique). For applique, I find that I have to move it to 2. For ruffles or gathering, set it at 0 and your stitch width to 4. Another trick is to hold the top thread for the first 2 stitches. This alleviates a bobbin catch at the beginning. Other things you will want to know are in regard to the two knobs. One is pretty simple. It has a line that gradually increases in a zigzag. This knob basically adjusts the width of the zig zag. Obviously, for straight stitching, you would make sure the straight line is towards the top. The other knob determines the type of stitch you want to do. The red stitch options on top of the machine can be done with #1, 2, 3, 4 or 5 at the top; however, I usually use #1. The blue stitches are really fun! Simply decide which stich you want and make sure the corresponding number on the dial is turned towards the top. Also, it is very important that you adjust the other knob to the largest zigzag possible AND change the stitch length to 4. Don't pull on the fabric from behind the machine as you are sewing, because the machine will go forward and backwards while making many of these stitches. The green A, B, C on the dial are used for the automatic buttonhole feature. In order to use this, make sure you have the button hole foot. It looks like a long rectangular piece of plastic with measurements on it and hollow in the center. Not sure if that description makes sense. Anyway, the first step is "C." Make sure you begin with the button hole pressure foot measuring "0". Also, change your zigzag width to the desired width AND change the stitch length to less than 1. (You will notice that this area has a green line on it.) Begin stitching. You should be moving forward. When you have reached the desired length, make sure the needle is up, then turn the knob to "B" (sometimes I make my zigzag wider for this part), begin sewing. You should not go forward or backward. This step makes the bottom of the button hole. I only make 3 or 4 "B" stitches. When done, make sure the needle is up, adjust your zigzag back again if you changed it for B, and set it on "A". This will take you backwards. If you started your button hole with the foot on 0, it will automatically stop moving backwards when you reach 0 again. At this point make sure your needle is up again, then set the knob on "B" once more. If you adjusted B before, do it again. There you are! You can use twin needles on this machine. It also works well with a walking foot for quilting. Oh! To wind your bobbin (starting from the thread spool) you need to slide the thread under the little metal knob sticking out on top of the metal "?" right above the tension and then insert it into the hole in the bobbin spool. Push the bobbin to the right. This locks it into place. Next, hold the outer part of the flywheel (round wheel on right side of machine) while turning the inner wheel towards you. This will disengage the needle and allow the bobbin to wind. Now you can press on the "gas" and wa-laah. It will slow down and almost stop when it is completed. Cut your thread, slide the bobbin to the left to unlock, tighten the wheel and you're done. If you have any more questions, let me know. Hope this helps!
Posted on Oct 18, 2008
SOURCE: thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Posted on May 27, 2009
  • 4 Answers
SOURCE: I have a Necchi sewimg machine that i purchased second hand I would like to have a manual for it. It is possibly model 3101 or 3102. There isn't a model # only states "Heavy Duty"
You should also try www.sewusa.com. I found the manual for a used Necchi 521FB I brought. Hope that helps.
Posted on Feb 12, 2010
How to thread a Necchi 3205 FA royal series
Search for:
Make Model threading
or
Make Model manual
https://www.sewingpartsonline.com/instruction-manual-necchi-3205fa-sewing-machine.aspx
Even if not your particular model, basic machine threading is very similar from one to another. Just be sure to ALWAYS RAISE the presser foot when threading the top thread---and change the needle often.
How do thread Necchi Royal Series Model 3205 sewing discussion topic...
How to Thread Necchi Sewing Machine
How to thread Necchi model 535 FA sewing machine now with captions
Nov 06, 2017 | Sewing Machines
I have a Necchi 537-L and I would like to know the year of it. Any other information that I could get about this sewing machine would be great to thank you for your help in advance
Necchi 537-L Sandi, Machine made in Taiwan, My guess on age would be early 80's. Links below may help, first link one lady states buy her 537L from sears in 1982., other links are instruction and info.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Life With Lou Necchi 537L Sewing Machine
Necchi 536 FB 537 FA Sewing Machine Threading Diagram
http://www.sewingpartsonline.com/necchi-sewing-machine-instruction-manuals.aspx
Apr 03, 2016 | Necchi Sewing Machines
How to thread a NECCHI royal series machine 3204FB
How to thread a Necchi model 535 FA sewing machine [now ...
? 8:52
https://www.youtube.com/watch?v=CEGuA6kZG4A
Jan 8, 2012 - Uploaded by Wren Paasch
How to thread a Necchi model 535 fa sewing machine. I'll make a separate video to show how to wind a ...
Necchi 3215 Sewing Machine Demonstration - YouTube
? 0:40
https://www.youtube.com/watch?v=ulo4kvnj3PU
Aug 9, 2011 - Uploaded by GoldCoastSewVac
... explains what the Necchi Heavy Duty Sewing Machine can sew and ... How to thread a Necchi model 535 FA sewing machine [now with ...
How to Thread a Necchi Sewing Machine (with Pictures ...
Dec 14, 2015 | Necchi Sewing Machines
How do I download a manual for Necchi model # 3101 FA?
Search the internet for:
Necchi 3101FA Manual
Sometimes you can get lucky to find one for free.
Nov 08, 2015 | Necchi Sewing Machines
Where can I get a free downloadable manual for the Necchi 3101 FA?
Necchi Sewing Machine 3101 FA Manual - I Fix Machines
www.ifixmachines.com/.../1619-necchi-sewing-machine-3101-fa-manua...
PDF replacement manual, owners guide,instruction manual for your Necchi ... lost or damaged Necchi sewing machine model 3101 FA instruction manual.These manualsare downloadable and you'll need the free adobe reader to open them.
Nov 07, 2015 | Necchi Sewing Machines
I have a used Necchi 3101 and no manual, how do I replace the bobbin and thread it,? a diagram would be helpful.
Howdy. I was able to find a website and a phone number for you: allyint.com
is the site of the sole US importer of the Necchi machines. they have the manuals and accessories available for your model 3101. Their number is: 1 800 525 9987 ex 20
I sure hope this helps:)
Aug 20, 2010 | Necchi 3101 Mechanical Sewing Machine
Model 575 FA .. Haven't had it open in a long
Take out the bobbin and bobbin case and check round the raceway, chances are you have a small piece of thread stuck
Oct 25, 2009 | Necchi Sewing Machines
Necchi 3101 Mechanical Sewing Machine Logo
880 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
