If there is a segmented plastic sheath (flex split loom tubing) covering a bundle of individual wires and it's the protective tubing that's brittle that's normal. As long as you're gentle when handling it even if some of the tubing breaks off it isn't likely to damage the actual wires. Most auto parts stores sell a variety of split loom tubing that you can use to replace the brittle tubing with. The reason it's called split loom tubing is that it is split along it's length so that it can easily be slipped onto wiring harnesses without even disconnecting terminations.
