Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Ultimate Care II Plus Washer Model: LSQ9264HZ0
The washer fills with water, but no agitation or spin. What's wrong???
  • 1 more comment
  • alangel37 Jul 24, 2008
    Just today my I washed a load of clothes but it wouldn't spin and makes a loud noise. The water that was left in the washer drained. Does this model have a belt or just the motor?
  • jill1258 Jul 24, 2008
    My washer fills and starts on the agitation. It stops in the middle of this and does nothing else.
  • masonictrave Oct 26, 2008
    The washer will fill but it does not agitate/pin/or otherwise. When turning the control to the position to start it going, it makes an electronic whine but with no turn over, as if the motor is trying to start but its just not turning over.
    Any ideas of where to look, or??? Any idea on how much it will cost to repair, part vs. part/service?
  • 481 Answers
If you hear the motor running while it is supposed to be agitating or spinning then it is most likely the direct drive coupling between the motor and transmission.Whirlpool Ultimate Care II Plus Washer Model: LSQ9 - 43f18ab.jpg9bd1c44.jpg if you already checked this and think it is a different problem then let me know, i will help you figure it out.  Mike
Posted on Jul 15, 2008
Posted on Oct 25, 2008
2 things:
1) I had the Repair guy check out the Master Control Panel and when he put it back together the problem went away.
2) The latest problem was an intermittant contact on the Lid Switch. Wiring was OK, it just needed a new switch.
Posted on Sep 01, 2008
I have this same problem.......already checked the direct drive coupling....seems to be intact and working properly.....any more suggestions?
Posted on Aug 18, 2008
Whirlpool model SM 8525079 fills with water but will not agitate or spin
If you have motor sounds after water fill,but no agitation or spin it could be a broken direct drive coupling. If it will not pump out water,there could be something stuck in the drain pump.
Jan 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool ultimate II washing machine fills up and agitate but does not spin or drains the water out. how can I fix it.
You have a bad motor. Your washer is a direct drive machine. It turns in one direction to agitate and the other direction to both spin and to pump. You have lost one direction in your motor.
Oct 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Does not spin or empty
it might be jammed or there might be dirt or some sort of a clog. I would suggest you clean it out.
May 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Jan 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer does not agitate after filling with water
does it spin?
sounds like your coupling is broke.It takes the place of the belt if it breaks it won't spin or agitate. it will still pump though.
Part # 285753A
Nov 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Aug 04, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
1,916 people viewed this question
Dan Webster
Dan Webster
Sal De
