Question about Siemens SpeedStream Modem (4100) (SS4100)
Just askem for help?
What would i do if i buy a new computer Dell ... but i works slower then the old one..what will i do?
  • Tim Babcock
    Tim Babcock May 11, 2010
    You might want to ask Dell that question. They can be more specific about taking care of the performance
  • 72 Answers
If the CPU, GPU, drive, and chipset are faster than the ones in the old computer, the new one should be faster.But a computer is as fast as it is - you can't specify that you want it to run a certain function of a certain program in a certain amount of time. (How much software is installed has nothing to do with the computer's speed - that depends on how much software is actually *running*. Boot time might increase just a bit if you have a lot of software installed, because it will take longer to read the registry files, but once that's done, any program you run will run at the same speed.)
Posted on Aug 19, 2008
    Sergeant:
  • 359 Answers
You can also reqauest that they not put on all the trial and garbage software that they usually include with their systems, this alone can slow down a computer by 30%
Posted on Aug 13, 2008
I have a Dell E6400. I know, ancient! Is it normal that it gets slower when charging? Like when it's using battery power, it's noticeably faster, but when I plug the charger in it just gets slower..
1.Install the system again. If it works, over!
2.remove the battery, and turn on your notebook with charger. If it works, there may be
something wrong with your battery. You can change a new battery.
3.Install the battery,and plug the charger, power your notebook. Open the Power
management, change the Power plan to High performance.
4400mAh 6 cells Dell Latitude E6400 XFR Battery Replacement Notebook... 90W Dell Latitude E6400 Charger Power Cord Replacement AC Adapter Latitude...
Jan 12, 2017 | Dell Computers & Internet
Adding additional screen makes it run slower
actually driving two monitors put a heavy load on your video processor
you probably need a memory upgrade at least double what you have
also try this
start
control panel
system icon
on left shows advanced settings(should be last on list)
look for video or visual performance button(should be first under general tab)
change radio button from Let windows decide to
best performance
that might help
Jun 09, 2012 | Dell Computers & Internet
Slow, stalls, freezes up
If your hard drive is too full, then your computer is going to perform slower. Delete old files which are not required.
Remove programs that you are no longer using. Delete temporary files.
Empty your recycle bin. Right click on Recycle Bin. Click Empty Recycle Bin>Yes.
Run an error check on your computer. The error check can remove errors that slow down your computer. If you are using Windows, you can do this by clicking Start>My Computer. Right click on your hard drive (typically c:) and then select Properties. Click the Tools tab>Check Now and then Start.
Clean up your registry. You can purchase software that will fix any registry errors on your computer.
Perform this computer maintenance on a weekly basis.
Apr 24, 2010 | Dell Inspiron 1501 Notebook
Can I upgrade a dell 900mhz p3 processor
Not really [ only possible might be to a faster P3 cpu]. Those motherboards are so old it would be cheaper to just buy a new system as Dell cases & power supplies, etc for that old a computer are all proprietary and would take major modification to upgrade to a new motherboard, ram, cpu and such. Hope this helps.
Jul 17, 2009 | Dell (6d514), 900 MHz Processor
I would like to know how to transfer data and software from a old computer to a new one I am considering to buy.
There are a couple of simple and fast ways to do this. They both depend on the systems. If you have two systems that both have network interfaces on them, the simplest way to trasnfer the data would be to connect the two computers together using a router (Linksys WRT54G about 60.00 at Staples). You can then share the drive on your old machine, and copy your data to the new machine using your network.
The second, which is slower but cheaper, is to buy a USB flash drive. 4 GB should cost about $25.00. When this device is inserted into a USB slot, it acts as a second hard drive. You can copy data from the old machine, to this and then move it to the new machine.
Good Luck
May 23, 2009 | HP Computers & Internet
Software counterfeiting
You have a Microsoft product on your computer that has an improperly activated or blacklisted key. Did you have the machine worked on recently? Did you buy the machine used? Did you buy the Microsoft product new from a store? If you bought a retail copy of a Microsoft product (say Windows or Office) installed it and got this message after activating it, TAKE IT BACK TO THE STORE YOU BOUGHT IT FROM. Reputable stores will exchange it for another (you wont get your money back since you opened it already). If you had work done to your computer before this happened, contact the person who did the work for a solution. If you bought the machine used and the product was already on it, chances are its improperly activated. Do resolve this soon; the machine will get slower and slower, and you can't download and install service packs and updates from Microsoft's website.
Mar 24, 2009 | Dell Inspiron B130 Notebook
Move Itunes from old computer to new one.
The easiest way is to buy the cable & software from Dell. I believe they have it labled PC to PC Direct mover. It will allow you to move anything you want from your old computer to new. Hope this helps.
Mar 13, 2009 | Apple iTunes
Motherboard blew up
I would recommend buying a replacement computer, and install the Dell IDE drive in an external 3.5" IDE hard drive enclosure. This way you can pull your information off the the Dell hard drive, and then blow it away.
Keep in mind that new computers use a SATA drive, your old Dell '8200 has an IDE drive. Also keep in mind that your Dimension 8200 drivers won't work on the new computer.
You might be able to install your Dell drive as a slave if you have an open IDE channel available.
Good news is, your old Dell uses RAMBUS memory, which is worth a lot. It's a good parts computer, and most people who look for computer parts know of the bad capacitor issue on Intel made Dell motherboards from that era.
May 15, 2008 | Dell Dimension 8200 PC Desktop
Noisy fan old older computer
Buy a new one here for $10
http://cgi.ebay.com/NEW-DELL-DIMENSION-2350-2300-CASE-FAN-92mm-x-25mm_W0QQitemZ250245854784QQcmdZViewItem
May 10, 2008 | Dell Mini Fan. Dimension (W x H x D) in....
Siemens SpeedStream Modem (4100) (SS4100) Logo
245 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
