Question about Mitsubishi WS-48311 48" Rear Projection Television
Red projector problem?
The TV is about 5 years old. The weather got warm and the red turned off; when it cooled down at night the red came back on... for a few weeks. Now it is out all the time. I am pretty good with electronic equipment but never worked on a TV. From these symptoms, what do you think has failed and is it something that can be replaced easily?
  • DanSD Jul 15, 2008
    What are the chances that this is a red lamp?
    Thank you, I'll give it a try.
  • Mitsubishi Master
  • 8,617 Answers
Most likely its the red drive transistor on the Red CRT pcb which is defective, or it could be as simple as a solder joint issue on the Red CRT pcb.
Posted on Jul 15, 2008
  • Sonny Berry
    Sonny Berry Jul 15, 2008
    Usually when a red Crt goes bad it will turn the screen red with retrace lines or shut the set down. So chances are its in the Red Crt pcb instead
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
I turn on my Sanyo Pro XtraX, with a bulb I replaced about 100 hours ago. The light is red on standy, turns green when I turn it on, but turns off and cools down after just a few minutes. this just started...
This happens to us at work quite often. Usually, it's just that the filters are dirty which doesn't allow the projector to cool and causing it to overheat. We just blow out the filters with a can of compressed air and it solves the problem.
Apr 15, 2009 | Sanyo PLC XU35 Multimedia Projector
When I turn on my EP7120 it starts to warm up and then the 2 warning lights come on automatically. (Red bulb and overheating light) I turn it off and let it cool but when I turn it on the red lights come...
Is the cooling fan working? (If not, then that's the problem).
Check that the intake grid for cooling is not blocked with dust and that it has adequate room to draw in air.
Mar 17, 2009 | HP Ep7120 Multimedia Projector
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Replace Lamp Flashing
Clean the cooling fans, specifically the lamp cooling fan located inside the rear cover, above the optical blocker. This is easily blocked with dust and causes overheating of lamps/shortened life.
Nov 07, 2008 | Sony XL-2100U Projector Lamp for...
Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
Nov 05, 2007 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Oven cuts out after about 15 minutes
most common fault is the cooling fan is failing to come on, whreas the fan will be okay ( check windings with ohmn meter ) it will normally have a ceramic 10k resitor in series with the live which goes open circiut
Sep 25, 2007 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Apparent problem with red projector?
service manual here
http://www.eserviceinfo.com/
I would not replace one stk but all....
more info here:
http://www.digitalhome.ca/forum/search.php
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Aug 23, 2007 | Toshiba 55H70 55" Rear Projection...
Mitsubishi WS-48311 48" Rear Projection Television Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
