How do I change the TV to AUX mode in order to play DVD's or VHS's?
  • 927 Answers
GOOD DAY, CARL;
To change inputs on the TV, 90% of the time, it is done on the TV's remote control. Look for a marked button; 'video' or input. Press button to desired input. Other TV's have device/input buttons and will display on the TV's screen, scroll up or down, using the arrow buttons, once on desired input press the 'enter button.
GOOD LUCK, big IRISH. Come back with model number and I can be more particular, or e-mail me at mmrkcar@yahoo.com.
Good Luck again.
Posted on Jul 15, 2008
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
Wheni push input, i get the options but no arrow i push will move down to option to play vhs
not enough info , if your trying to change the tv input , make sure you select tv on the universal remote first , you either need to keep pushing input til it moves down to your desired input , or use the arrow key to move it down to the input. some require you to hit enter or ok to select , others just wait a second , it should change. if your getting the options menu when your hitting input , then the remote is not compatible with your TV / VHS / DVD...
If you get the input to change and your successful , make sure you hit VHS in order to call a command , if its still in tv mode , your only going backwards , make sure whatever your trying to control , the remote is selected to that device ... Good Luck ..
The Cable Guy .... hope that helps !!!
Mar 12, 2015 | RCA RCR314WR Universal Remote Control For...
No sound when playing dvd, connection to vhs player
tried to record coming from other tape and replace the audio cord.
Sep 15, 2012 | Televison & Video
VHS won't play
If it's showing a welcome screen, the DVD is on. The VHS won't show a welcome screen. Some machines are a little tricky because they want to start in the DVD mode. I would concentrate in that area.
Oct 09, 2009 | Samsung DVD-V5500 DVD Player/VCR
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
I need to know how to hook up DVD player with Cable TV I have the cable with the white yellow and red. I hook one end into the TV and one into the DVD player. I don't get a pic or sound. I do not havethe...
The key is having at least a Universal Remote ($10.00 or less) that will operate your brand of TV. Your TV is only looking at "stations". You need to make it see Aux-1, Aux-2, or Line In mode. BUT, another trick is to run the DVD into your VCR (if capable). Select the VCR proper "input mode" (Aux-1, Aux-2, or Line In mode) then the DVD will play through the VCR and it will play through the TV on either channel 3 or 4. Problem solved!
Jun 27, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Just want the Orion TV (Model: STV 2763) to play VHS videos
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
Yahoo.
May 21, 2008 | Orion STV2763 27" TV
Stuck in Progressive Scan Mode...please help!
There should be a switch on the DVD player that is makred 'progressive/interlaced.' You need to flick this switch til it says interlaced, as obviously your TV cannot view progressive signals. It may be on the back of the player, or under a flap on the front.
Feb 04, 2008 | Televison & Video
Dvd into vhs input
If you can watch TV normally then it should be a button on your VCR remote. It could be "Input", "Line" or "Aux". Tvs with more than one input line will may require 2 presses on that button, one for each line. This is the best answer that I can give not seeing your remote. Any questions?
Nov 07, 2007 | Hitachi VTFX685A VHS VCR
TV DVD VHS combo 27 inch
this problems its no posibil to rezolv home becous is nesesari technology of laborator
Apr 14, 2007 | Emerson SB350 13 in. TV/DVD Combo
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
