Intermittent whining, screeching noise from Samsung DLP. Replaced lamp not that long ago. Noise was there before and after lamp replacement. Happens most on start-up. Often stops after running for a while.
  • 1 more comment
  • gmfeld Oct 26, 2008
    I have the same problem. My Samsung DLP makes whining, screeching noise at start up. Seems to lessen over time while the tv is on
  • claymarbry Mar 23, 2009
    I found it was the color wheel - the bearings in the wheel were going out, causing the noise. Got the color wheel replaced. Cost me ~$350 at a local repair shop.
  • stevebarnaby May 11, 2010
    It is most likely the color wheel or fan slipping on start up once the unit heats up the sound goes away?
Great! Congrats!
Posted on Mar 23, 2009
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
I have a humming noise coming from my 5 year old samsung 50 inch dlp tv , I have replaced the lamp 6 months ago so what else couyld the noise be coming from? I have a great picture and color.
If it is a high pitched whine it is most likely the color wheel; the bearings in the wheel go bad and if you google the model number with color wheel you will find it.
The whine is the early stages of the wheel failing; when it goes out you will either have shutdown or a grinding sound.
Let me know if you have questions as I am here to help.
SD TECH
Aug 09, 2010 | Samsung Televison & Video
I have a Samsung DLPTV, picture is fine. There is a "whining" noise associated with the TV the whole time its on. Stops as TV shuts down, It's about 4 years old and have not replaced lamp. Could this be...
Google your model number; I suspect it is a bad color wheel--lots of these sets have a fan like noise or even a grinding sound sometimes called a high pitched whine.
The part can be customer replaceable and YOUTube has actual video instructions for its replacement.
SD TECH---Steve
Jun 08, 2010 | Samsung DLP HL-P5663W 56" TV
Just replaced the lamp and the tv turns off after about 60 seconds
First. Did you reset the lamp timer on your tv after replacing the old lamp? This is important to keep track of the life of your lamps. Dust off internally, dust tends to affect the temperature of internal parts. Do you hear any other noises? ex: buzzing, clicking, could be your ballast. If you hear any winding, whirling or screeching noise could be your color wheel.
Jan 28, 2010 | Samsung DLP HL-P5663W 56" TV
When i turn on my tv it make a winding siren noise but no picture, i replaced the lamp, would it be the colorwheel?
sounds like the color wheel as it can almost sound like a whirling siren or a loud screeching sound
Jul 20, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Whining noise
Color wheel is going or gone out. New colorwheels are air bearing and not mechanical.
Jun 27, 2009 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HLR4667 DLP picture problems
Color wheel problem. replace it. If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 03, 2017 | Samsung DLP HL-P5663W 56" TV
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung dlp
HLS4266W 43" dlp. In less than 1 yr whining grew worse, but did know what it was. Year passed with warranty and lamp went out. Replaced lamp. Worked for 3.5 hrs. Turned on next day and did not work. Got another lamp, but did not work. Figured out might be color wheel. Replaced it too. TV started up. Watched that night. Turned on next day, heard loud pop. Lamp never came on. Withdrew and reinstalled lamp a couple times to see if that worked. Did not. Currently, with new lamp and color wheel installed, lamp light blinks, but no lamp comes on. What now?
Sep 17, 2007 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
Electro Med Services...
