Simpson Esprit 750 Washing Machine. The machine will not automatically step through the wash processes,ie wash to rinse to spray rinse to deep rinse and spin. It still performs all functions of a complete wash but we have to manually turn the dial to perform each of the functions of the wash cycle.
  • 3 more comments
  • abirks Jul 15, 2008
    Is it the control panel, or is it the module marked "forward Reverse"? This module is potted, so cannot see components. What makes the dial turn? Is it purely mechanical or is electronically controlled?
    It stopped working automatically a few weeks ago. We have been manually stepping through the wash steps, but my wife has had enough of this!!
  • Anonymous Mar 25, 2014
    lost all power
    I used my machine this morning and now it will not turn on
  • Anonymous Mar 31, 2014
    simpson washing machine wont agitate .all other functions ok
    Genius:
  • 1,847 Answers
The control panel has gone bad needs replacement.
Posted on Jul 15, 2008
  • Legin Varghese
    Legin Varghese Jul 15, 2008
    since when it is not working ?
I have a simpson esprit 750 automatic top load 7.5 kg washer on any cycle i try to fill it up to start cycle as im filling it up the water is draining out
Hi if it's draining out on your floor you have a split hose, very easy to fix just put your washing machine forward(turned off)and lay it on a towel, Look underneath and you should see the split hose..... Good luck....
Mar 18, 2016 | Simpson Washing Machines
Simpson washing machine will not fill with water. Epsrite 750. Hoses are fine, water pressure is fine. Just a dribble goes into the tub
Most hoses have a filter/strainer at the faucet end. This can get clogged. Remove from water source, check and clean.
Sep 03, 2014 | Simpson Esprit 750 Top Load 7.5kg
How do i replace a programm switch on a simpson 750 esprit washing machine
Normally, you would push in on the knob to set to a cycle then pull out on knob to start machine. Am i correct? So when you push in to set the cycle it just spins?
Jan 27, 2013 | Simpson Esprit 750 Top Load 7.5kg
Simpson espirit 750 won't turn on
Hi, This may sound obvious, but have you checked the fuse? if the machine is completly dead this may be the problem or the ON/OFF switch is faulty. If there is life in the machine the problem could be the door switch. If the fuse has blown then there could be a fault such as heater element blown, is the most common to blow a fuse.
May 04, 2012 | Simpson Esprit 750 Top Load 7.5kg
Simpson espirit 750 manual required can't change water level
Hello
Try these links to download the manual to your machine.
laundry.manualsonline.com/ex/product/.../m/simpson/d/.../22S750M
http://www.dataentryjobs.us/67948.html
trd-techconnect.net/User's%20guide,%20Instructions%20book
www.search-document.com/pdf/.../simpson-esprit-washingmachine
www.sign.ac.uk/pdf/sign97.pdf
Feb 09, 2012 | Simpson Esprit 750 Top Load 7.5kg
Simpson esprit 450 washing machine timer not working. It statrs at a certain point (rinse) but doen't work when I set it for wash. It does rinse, deep rinse and spin but doesn't wash at all.
Hi just read your posting.Now just a couple of questions.What water temp have you set the machine for,Is it cold,cold or another setting.Have you got the cold hose going from the cold tap to the cold water valve on the machine with is marked with a C and the same for the hot which is marked H.Please reply with answers to all the questions and I am sure I can help you with this fault.Looking forward to your reply.
May 24, 2011 | Washing Machines
Simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Mar 31, 2010 | Washing Machines
Simpson Esprit 750 washing machine timer?
Hi! My Simpson Esprit 750 washing machine won't click over to the next stage in the cycle. All of the stages work if you turn the dial manually so I am wondering if it may be the timer that needs replacing? I can't hear it in operation. Thanks.
Nov 15, 2009 | Washing Machines
Simpson esprit washing machine
put a new pressure switch in it
Mar 25, 2008 | Washing Machines
Washing Machines Logo
701 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
