Question about Maytag Dryers
Maytag dryer model mdg9606aww , no heat gas is flowing, could it be a thermostat?
  • Anonymous Dec 06, 2008
    no ignition on my MDG9606AWW, igniter does not glow
  • Anonymous Mar 24, 2014
    turns on but will not heat and glow plug does not turn on
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 67 Answers
There's a flame sensor near the igniter. If it's defective, the gas may shut off prematurely. Another common problem occurs when one of the electrical coils on the gas valve fails intermittently. If this happens, the flame shuts off before the thermostat sends a signal, which can greatly prolong the drying time. If the sensor or the coils are causing the flame to shut off, replace them.
if this helps please vote me a fix ya
Posted on Jul 15, 2008
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
, ModelMy Maytag will run but not heat. The igniter coil lights, but the gas does not flow. What may be wrong?
If the igniter works either a valve for gas or the thermocouple are suspect here.
Maytag Gas Neptune Dryer MDG5500AWW no heat
see this causes and fix it. God bless you
Dryer tumbles, but there is no heat
Sep 27, 2012 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag MDG9606AWW gas dryer. The heat is intermittent. What part is most likely to need replacing?
Although it could be several things, the three most likely suspects is the radiant sensor P/N 338906, the thermostat P/N 303395 if there is a temperature fluctuation but the burner is active. The gas valve P/N 306176 if the burner is not active. Intermittent problems are very hard to troubleshoot so you need to write down every indication and when it happens. For example: Works good on permanet press, but not on high.
Hope this helps. Hal aka ImJustAvg
Dec 17, 2011 | Whirlpool Dryers
I HAVE A MAYTAG GAS DRYER MODEL MDG9606AWW. THE PROBLEM IS THAT IT STARTS ,FIRES UPAND HEATS FOR A FEW MIN. THEN IS DOES NOT HEAT ANY MORE. I JUMPED OUT THE THERMOSTATE ON THE EXHAUST BUT IT DID THE SAME...
The reason your gas heated dryer starts off heating ok,but a part way through the cycle it is no longer heating as it did when it started,is beacuse the coils that open the gas valve are getting hot and breaking down when they are warm. At start up of cycle the coils are cool,but when the dryer heats up as it runs the coils that are weak can not handle the heat and do not open the gas valve. Replacing the gas valve coils with fresh,strong ones will open the gas valve the entire duration of the drying cycle. All appliance manufactures use the same exact gas valve coils and label them with their unique part number. Having been in the service business i know they are all the same and the part number for the least expensive gas valve coils is 279834
They can be purchased at your local appliance parts store on online at
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
midwestapplianceparts.com
To replace the coils,remove bracket over them(dont worry about where it says dont grip thats for when dryer is plugged in) unplug them and install new ones,that bracket has notches in it and the coils have tabs that inter lock so they position them self exactly where they fit.
This is what the coils looks like
I hope this will help you to be able to repair your dryer, GENE
Aug 21, 2011 | Maytag Dryers
The dryer will run and the drum will turn but no heat. Maytag gas dryer model number: mdg9606aww
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 10, 2011 | Dryers
Maytag Gas Dryer doesn't heat up
The igniter is the part that ignites the gas in the Maytag gas dryer. Long time a go the dryers use to have a pilots. The pilots where on all the time, even when the dryer was not been use.
This wasted a lot of gas and a new design was needed. That is when the igniter or glow bar as is also known, came to be. A bad igniter could be the reason for your Maytag gas dryer not heating.
The radiant sensor is a small black box that attaches to the combustion funnel. The job of the radiant sensor is to allow the igniter to glow until it is real hot, then it shuts the igniter off and opens the gas valve to start the heating process. A bad radiant sensor could the the reason for your Maytag gas dryer not heating.
The gas valve has two coils or solenoids. These coils job is to open the gas chambers inside of the gas valve.
When one of the coils goes bad, the symptom is that the igniter glows, but the gas valve won't open to let the gas flow through the gas chamber to be ignited.
A bad set of coils could be the reason for your Maytag gas dryer not heating.
The hi-limit thermostat is located on top of the combustion funnel, and its job is to open the circuit to the gas valve if the airflow to the dryer is restricted for any reason.
The cycling thermostat is use to control the temperature inside of the dryer. It is factory preset at 155 degree, in other words it will open the circuit to the gas valve when the temperature reaches 155 degrees.
This thermostat is opening and closing all the time the dryer running. A bad cycling thermostat could be the reason for your Maytag gas dryer not heating.
The timer is the part that direct the electricity to the other parts in the dryer. This part works very hard and the contacts wear out and some times they burn out. If the timer contacts won't close, the dryer will not heat.
The motor switch is another safety device that only closes the heating circuit when the motor is running. When the motor is not running the circuit of the gas valve is open and the dryer will not heat. A bad motor switch could be the cause for your Maytag gas dryer not heating.
As you could see, there are a lot of parts inside of the dryer that have to be in good working condition for the dryer to produce heat.
May 27, 2009 | Maytag Dryers
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Dryer working but not heating up.
possible air flow problem,, check exhaust hose and sure not clogged up needs air flow, if long dry times repl/ coils/ only on gas models /if electric./ repl/ hi limit thermostat,// and safety thermostat ,,u need 240 volts 120 to turn on dryer and another 120 to heat ......
Nov 30, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
515 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
