The kind of printer i have is not in the add printer options list
    Scholar:
  • 137 Answers
If the printer is not included in the built-in printers list of whatever operating system you are using then go to the manufacturer's web site and search for drivers. You may also have success with Google, with a search for "Deskjet 1000 WIndows 98 Drivers" without the quotes and fill in the proper model of printer and operating system.
For more help here please list your printer model and operating system here and perhaps someone here can provide more specific help.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Posted on Jul 15, 2008
I need driver for hp 900 inkjet that will install in windows home basic
To install HP 900 inkjet printer hare is the following step you need follow.
1. Connect you printer with computer and printer should be on.
2. open devices and printers form start and select add a printer,In The Add Printer Pop Up Wizard, Select Add Local Printer and click on next
3.In the Use an existing port drop-down list, select USB Virtual Printer Port (Printer Port) and then click next.
4.Under Manufacturer List Select HP
From Printers List, check whether your printer is listed.
(If your printer is listed there are inbuilt drivers available for your printer in windows 7, if not you can try clicking on the windows update button to get more manufacturers and more printer models, or if you have a disc of your printer drivers you can use have disk option and point to that)
Click On next.
5. In the Printer name text box, type the printer name( leave the default printer name) and then click Next. The printer driver starts to install.
you can also install printer driver with windows update. windows update automatically install your printer driver.
Jun 05, 2012 | HP 900 Inkjet Printer
Tip
Missing printer driver settings and/or features on Leopard.
If your output is faint or if the driver settings and/or features are missing, your system may have automatically added the printer using the Gutenprint driver. Many printer drivers are provided with Leopard but some drivers may need to be downloaded from the manufacturers website.
support.epson.com
www.hp.com
www.canon.com
support.lexmark.com
www.brother.com
Determine Which Driver is Currently Being Used
1. Click on the Apple icon in the upper left corner of the Finder and open System Preferences.
2. In the System Preferences window, click on Print & Fax.
3. In the list of printers on the left side of the Print & Fax window, click once on your printer to select it.
4. Check the name of the driver being used; it is displayed in the center of the Print & Fax window next to “Kind”.
5. If the driver name displayed next to “Kind” is Gutenprint, the incorrect driver is being used. Follow the steps in the next section to select the correct driver.
Selecting the Correct Driver
1. Turn off the printer.
2. Delete the print queue and remove the printer from Print & Fax by clicking on the minus (-) button under the list of printers. Click OK to confirm the removal.
3. Go to the manufacturers website and select your printer or All-in-One model from the appropriate list.
4. After selecting your Printer or All-in-One, the web page will either confirm that the correct driver is provided with Leopard or give you a description and download option for the correct driver for your printer.
5. If the driver for you model is included in Leopard, skip to step 6. Otherwise, download and install the Leopard driver before continuing with step 6.
6. Click on the Apple icon in the upper left corner of the Finder and open System Preferences.
7. In the System Preferences window, click on Print & Fax.
8. Turn on the printer. The system should add the printer automatically.
9. If the printer driver for your model is included in Leopard (not downloaded from the manufacturers website) and the system does not add the printer or if it adds it using the Gutenprint driver, contact Apple for assistance. You may need to reinstall the drivers provided with Leopard.
on Nov 06, 2008 | Epson Stylus Multifunction Printer/...
Tip
Faint output when printing from Leopard
support.epson.com
www.hp.com
www.canon.com
support.lexmark.com
www.brother.com
Not printing from a mac
Use one of the following methods to print, depending on how the printer is connected to the computer. hpweb_1-2_minus.gif Method one: Printing from a USB printer
  1. Make sure your printer is turned on and connected.
  2. Open a document to print, and then choose File > Print .
    NOTE: You can also go directly to System Preferences > Print & Fax .
  3. From the Printer pop-up menu, choose your printer. If you do not see your printer listed, choose Add Printer , and then click More Printers .
  4. In the Name column, select your printer, and then click Add .
hpweb_1-2_minus.gif Method two: Printing from a network printer You can connect to HP printers on your local network (wireless and Ethernet) using Bonjour or IP, as well as shared printers connected to an Apple Airport base station.
NOTE: Apple does not support AppleTalk in Mac OS X 10.6.
  1. Choose File > Print .
  2. From the Printer pop-up menu, choose your printer. A dialog appears, listing any Bonjour printers on your local network. It may take a minute or two for your printer to appear.
    NOTE: Your printer may also be listed in the Nearby Printers submenu.
  3. If your printer does not appear, choose Add Printer from the Printer pop-up menu. Printers that are turned on and connected to the local network (wireless and Ethernet) should appear as Bonjour devices.
  4. Select your device from the list, and then click Add to create the HP printer queue for your HP Photosmart, Officejet, or Deskjet All-in-One printer.
Your computer can usually detect whether a printer has special accessories installed, such as additional paper trays or a duplex unit. If it cannot, a dialog appears that lets you specify them. To enable full functionality, make sure the settings in that dialog accurately reflect the installed options.
The latest HP Utility is included in Mac OS X 10.6.
Method one: Open the HP Utility from System Preferences
  2. From the Apple menu, choose System Preferences .
  3. Click Print & Fax .
  4. In the list of printers on the left side of the dialog, select the HP All-in-One to view the options in the Print & Fax window.
  5. Click Options and Supplies .
  6. Click the Utility tab at the top of the window, and then click Open Printer Utility . The HP Utility opens. Features and options may vary depending on your printer model.
Method two: Alternative The HP Utility can also be launched from the printer icon in the dock to open the Printer Browser window.
  1. Double-click the printer icon. The Printer Browser window opens.
  2. Click Printer Setup in the toolbar.
  3. Click the Utility tab.
  4. Click Open Printer Utility . The HP Utility opens. Features and options may vary depending on your printer model.
Jan 18, 2011 | HP Officejet 6310 All-In-One InkJet...
Having troubles printing on a 4 x 6 Index card. I choose that option, but it continues to print on regular size paper. The 4x6 cards are in the 4x6 photo tray. I've tried all the settings I can think...
Click on startà control panelàprinter and faxes.
Click on top left Add a printer option. This launches the Add Printer Wizard. Click next.
Select Local printer attached to this computer and uncheck automatic detect and install my plug an play printer option then click Next.
Now, Use the drop down arrow to select USB001 then click next.
Select the Manufacturer as HP from drop down list and select DeskJet 990c from printer drop down list. Click Next.
Verify the printer name and set the printer as default then click next.
Do not select print a test page option.
Click on Finish
Sep 18, 2010 | HP Photosmart C7280 Laser Printer
Attemts to print e-tax summary the printer is defaulting to cd
Click on Finish
Click on start then run type notepad.
Write any stuff and then try to print.
ADD A PRINTER IN VISTA
Click Start and click Control Panel.
Click Hardware and Sound then Printers.
Click Add a printer. This launches the Add Printer Wizard.
Click Add a local printer.
Now, Use the drop down arrow to select USB port 001 then click on Next.
Select replace current drivers
Click on Finish.
Click on start then search type notepad.
Jul 12, 2010 | HP Photosmart Premium C309A All-In-One...
Its identifying my printer as being offline, how do I correct it
Click on Finish
Click on Finish.
Jul 10, 2010 | HP Officejet 4315v All-In-One InkJet...
The printer is showing the message offline,how to reslove this
Please click on start on the computer----Control Panel-----printers and Faxes.
Please right click on the printer icon and click on use printer online.
Then again, click on the printer icon and click on cancel all documents.
The issue will be fixed.
If still you are not able to print, pleae follow the below steps.
Click on Start on the computer---- and in the search box or RUN type "services.msc" and hit enter.
Here you will see an option "print spooler".
Just stop that print spooler
and then restart that spooler.
This will make it print.
If still you are not able to print, please follow the below steps.
FOR XP operating system
Click on start button on computer then control panel then printer and faxes.
Click on the option of Add a Printer and click on Next on the Wizard.
On the next page select the option of Local Printer and uncheck the option of Plug and Play devices.
On the next page, select the option of Use Existing Ports and select the option of USB Virtual Port and click on Next.
On the next page, select HP as the manufacturer and Deskjet 990c as the printer.
Select print a test page option.
Click on Finish.
FOR VISTA operating system.
Click windows logo and go to Control Panel.
Click on Printers.
Now, Use the drop down arrow to select USB port 001 then click Next.
Click on Finish.
Jul 03, 2010 | HP Deskjet D1560 InkJet Printer
I have a HP Psc 2355 All-In-One InkJet Printer Bottom of page is cut off sometimes printing from vista computer
USB Cable Connection:
=== HP Deskjet 990c Drivers on Vista ===
* Click on the Windows button.
* Type 'Printers' without the quotes and press enter.
* In Printer folder, click 'Add a printer' button on top.
* Click on the option 'Add a local Printer'.
* Put a check mark beside 'Use an existing port' and choose DOT4_001 or USB001 or USB002 from the drop down box.
* Click on next.
* Choose 'HP' from the list of manufacturers and 'HP Deskjet 990c'from the list of printer.
* Click on next.
* Follow the onscreen instructions to configure the drivers.
NOTE: While printing, please choose the all-in-one as HP Deskjet 990c all-in-one and then try printing
Network printer:
* Put a check mark beside 'Use an existing port' and choose TCP/IP from the drop down box.
* Click on next.
* Click on next.
Oct 16, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Panasonic dp-c262 doesn't network with mac computers.
about the only thing i can think about at the moment is to go to control add printers add by network connection find the printer that is required it should do a connection for you.
im not very good with macs
Apr 01, 2009 | Panasonic DPC262 Printer
jasbo
jasbo
