Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Error 1203 I am getting print cartridge error 1203 but the user book does not have any information regarding this 1203 code. the printer is telling me to look in the user guide there are no codes in it. Please help
    Sergeant:
    Champion:
  • 221 Answers
You can try testing your Printer with another Print Cartridge and if the error message repeats, you should contact Service Center as then there would be a Hardware Problem.
Posted on Jul 25, 2008
Hi, i'm getting error message 1203 on the printer and we've lost the user's manual. Can you tell me what this is?
Error 1203 is a very interesting error code. Here is what I found out about error 1203
Error 1203 is a very interesting cartridge error. It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cartridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
I use the lint free cloth(coffee filter work great) with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
Then before you print anything, you should run aligned the cartridges a couple times then run clean cartridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of lint free cloth(coffee filter work great on those holder contact panel.
Article on refilling Dell ink cartridges
Rick
Sep 10, 2011 | Dell 926 All-In-One InkJet Printer
I want to print the letter . on the machine's screen i saw error #1203. it wrote consult user guide . could you tell me how to slove the problem
1203 error indicates a communication problem with your printer and one of your cartridges. Please refer to this article in the Lexmark website: How to Troubleshoot a 1203 Error on the Lexmark X4250/X4270/F4270 Printers. This will help you identify and resolve the 1203 error message on your printer.
Apr 21, 2011 | Lexmark X4270 All-In-One InkJet Printer
Lexmark printer problem. Printer is not printing shows error 1203
Hi
Error 1203 Dell 962
There can only try and I hope it will do the job for you.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on
press copy
you may need to Reset Factory Defaults
Mar 01, 2010 | Lexmark P4350 All-In-One InkJet Printer
Cartridge error
Error 1203 is a very interesting error which normally means that your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges.
Check to see if ink are smeared on the holder where the contact panel with the catridge.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Be sure not to leave any debris of klennex on those holder contact panel.
To reset the error code, disconnect the power cord from the wall. Also remove the power brick from the back of the printer for 60 seconds. Then connect everything again.
Please let me if this information helped.
Please rate me if you are haapy with the solution.
Sep 15, 2009 | Dell 946 All-In-One InkJet Printer
Displays Error Code 1203 - What is that? User Manual is lost.
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
May 05, 2009 | Lexmark X7170 All-In-One InkJet Printer
Error code 1203
Check to see if ink is smeared on the holder where the contact panel with the cartridge is. Use a tissue with a few drops of water to dampen and clean off those contacts on the holder. Print the test page to see how it looks. Be sure not to leave any tissue on those holder contacts.
Try that and see if it works for you.
Apr 09, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark P6250 Printer error 1203 - Consult User Guide
It is a hardware printing problem . Try to clean contacts in printers in cartridge holder by alcogol and elastic rubber. it may become dirty an poor contact. after this you can try this:
Put some layers of the sticky tape on cartridge to improove force of contact.
Mar 06, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Error Message 1203??
These steps are for a Lexmark 4200, but I suspect they will work for your printer as well:
Cartridge Error: 1203
Your print cartridge has a short.
1. Press Power to turn your All-In-One off.
2. Unplug your All-In-One from the wall outlet.
3. Plug in your All-In-One.
4. Reinstall the cartridges.
If this does not resolve the problem, see More troubleshooting options, or replace your cartridges.
Source: http://www.lexmark.com/publications/pdfs/4200/eng/trouble.html
Aug 04, 2008 | Lexmark P4350 All-In-One InkJet Printer
Error message 1203
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
X4270 ALL IN ONE WILL NOT PRINT ERROR 1203 COMES UP,
Noticed you message while searching for answers to repairing another Lexmark printer. You probably already have the answers by now but here is what the manual says.
Hardware Error: 1200
The All-In-One is stalled.
1. Press Power to turn off your all-in one.
2. Unplug your all-in-one fro the wall outlet.
3 Check for paper jams.
4 Plug in your all-in-one
Cartridge Error: 1200
The cartridge carrier is jammed.
1. Turn off you all-in-one
2. Unplug the all-in-one form the wall outlet.
3. Open the control panel.
4 Open the cartridge access door
5. Make sure the cartridges are snapped in place in the carrier.
6. Check for objects obstructing the carrier.
7. Plug in your all-on-one
8. Press power to turn your all-in-one back on.
Hope this resolves your issues.
The ultimate fix for this problem is to give your Lemark and Dell printers to people that you really dislike. Let them live with the frustration. Then buy yourself a Hewlett Packard, Canon, or Epson printer. Check the cost of the cartridges for each brand prior to making a purchase. Purchase the printer with the least expensive cartridges and one that will take the generic (compatible) cartridges available in retail stores and refill stores. My personal favorite are the Epsons. They print excellent colors and are very affordable to own, and most important, operate.
Let me know if it works?
Nov 01, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
262 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
