You need to have a hdmi out to get digital signal for connecting it to a Hd tv ..but if you have at least a vga out (the plug for standard monitor) ..than you can connect it by using hat one ..and get the sound from the headphones..but will not be a high definition ..but an analog connection ...It will work though anyway ..and do not feel the difference If you want to use it on daily base ..set the second display as a clone ..bu if you want to run different applications on them ..you will have to set it to expend on the second one ..and this way you will have an extension ..I read that some models of eee have a tv out ..if so ..use it ..(remember to check if it is enabled)
SOURCE: is it possible to connect a web cam on my asus
yes, for as long as linux supports USB connector platform. Although they are different OS, they have the same basic concept of recognizing the USB port into your system...
Eee Family Support:
Support: http://asuswiki.asus.com/usaSupport/index.php?title=Eee_Family_Customer_Service
Tel: +1-888-676-3688
Tell them to reset the BIOS password. they do have the tools to reset it.
