Question about HP Pavilion dv9000z Notebook
How to work numbers on the right side of keyboard on laptop
On our new laptop computer, there are numbers on the right of the keyboard. how do we get it to work?
Thank youo for the fix!
Posted on Jul 15, 2008
  • HP Master
  • 12,061 Answers
Hit the NUM LOCK key in the upper L/H top of the number matrix.. should be all good..
The number keys on the right hand side of the keyboard dont work or are locked, every thing else is ok
The only solution is to have the keyboard replaced, there is a ribbon cable from the keyboard to the motherboard and sometimes the ribbon or the keyboard develop issues. I suggest a computer tech to deal with the repair.
Jan 20, 2011 | Computers & Internet
Right side of keyboard does not work
check to see if your number lock is on. it is located on the top left corner over the number pad
Apr 18, 2010 | Acer Aspire 5500 5570-2609 Laptop
Keypad on right side doesn't work
Try pressing your numlock (top left of the keypad) and try the numbers again. Try your keyboard in another computer -- if they still dont work, you have a hardware failure ... time for another keyboard. If it works on another computer, then I would recommend right-clicking on "My Computer" and selecting "Manage". Go into the hardware manager, and delete your keyboard, and reboot. The Windows will find your keyboard and reinstall the drivers, hopefully resetting whatever configuration was previously blocking your keypad keys.
Apr 10, 2010 | Apple M9034LL/A Keyboard
How do i replace the keyboard on a dell inspiron 1525
How to Install a Replacement Keyboard on Dell Inspiron 1525 Laptop Computer You may need:
  • New keyboard
  • Screwdriver
---Be careful to not break off any of the plastic tabs on the keys as they are difficult to replace.---
  1. Turn the computer off and slide the tip of the screwdriver in the notch on the right side of the hinge cover (the plastic section above the keyboard). Slide the hinge cover up and remove it from the computer, exposing a series of bolts. Unscrew the bolts and remove them.
  2. Pull up on the edge of the keyboard and slide it forward toward the display. Slide the keyboard all the way out of the computer case slowly.
  3. Unhook the flex cable from the computer board to disconnect it from the computer.
  4. Slide the new keyboard into place, connecting the flex cable first.
  5. Screw down the edge of the keyboard with the 4 bolts from before and replace the key cover.
  6. Power up the computer and see how your new keyboard works!
May 01, 2009 | Dell Inspiron 1525 Notebook
Spilled a little rum on the corner right side of the laptop and now had to get an external keyboard because the laptop keyboard types multple letters and numbers when keys are pressed.
If that is the case you can purchase a new keyboard off ebay for $20, remove the screws holding it (will either be underneath laptop or right above keyboard) and replace.
Mar 09, 2009 | Toshiba Satellite A105 Notebook
My Compaq keyboard not working..only the numbers on the right sid
is that a laptop by chance ? and if not .. perhaps it's time to replace the keyboard.
Robert
Dec 16, 2008 | Compaq Keyboard
Acer aspire 3003wcli keyboard stopped responding
You probably activated the "Num Lock" accidently. Just hold down the FN and look for the key that says "num lock" Now you should have your keyboard back and the numbers will just type when you hit the numbers key. I did this to myself yesterday!
Dec 06, 2008 | Computers & Internet
Keyboard is locked into Fn mode and doesn't type letters on the right side
you need to press FN and NumLk together (NumLk on some laptop keyboards is either F11 or F12)
Does this help?
Regards
Please remember to rate
Nov 19, 2007 | Gateway Computers & Internet
Keyboard not working
Hi Simran Hope you are doing good. Please try the following solution. Press Fn (Function button) on the left bottom side of your keyboard that is between the left Alt and thw windows key and while holding it down press the Num Lk key on the top right side of your keyboard. It is between the Prnt Scrn and Pause button. Please chcek your keyboard and advise if it works fine now or not.
Jun 14, 2007 | Dell D520 Notebook
HP Pavilion dv9000z Notebook Logo
89 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
