Question about Emmaljunga Coronado Stroller
Assembly of Emmaljunga Toddler Seat
I have been given an old Emmalunga pram (classic) with a toddler seat but dont know how to assemble it. Model - Type A Toddler Seat
  • geebzeee Oct 14, 2008
    I also have an Emmaljunga pram which I believe is a Classic, but the seller on Ebay was not able to confirm. It is a Type A seat unit serial number: 000607-1192. I have a toddler seat with an assembly manual, but it does not appear as though the pram suits the toddler seat (the toddler seat should be screwed in in more places than possible on the pram). Can anyone confirm the pram type I have and what kind of toddler seat is suitable?
2 Suggested Answers
  • 91 Answers
SOURCE: does toddler seat for emmaljunga fit all
No, the older toddler seats will not fit the newer model strollers. You will need to check the toddler seat and see how it attaches to the pram, there are two different styles.
Posted on Apr 10, 2009
SOURCE: emmaljunga toddler seat
You can not get a manual any more as they are not made. They are releasing a new seat in Feb 2010. This works in an identical way so I have been told. I have the old seat. It is easy to understand how it is fixed, but I would have a strong man to help, it can be tough.
Step 1 : locate bumper bar and with an alan key undo the two black clips either side that hold it together. Remove bumper bar from pram, Keep the two clips on the pram with the opening facing up.
Step 2 : With your toddler seat you should have another two of these black clips, place these two on the pram in the same way, but as far forward as they will go.
Step 3 : On your seat either side of the black knob that reclines the seat you will find two holes, simply place the seat lined up with the clips, put the screws with the clips threw the clips and the holes in the seat place, put the other side of the screw on and tighten. Thats it seat on.
Posted on Jan 06, 2010
I need to set up the pram for a toddler and new born and have lost the manual
You will need to recline the main seat unit fully (undo the zips on the inside of the seat unit) and attach the toddler seat on top (with two right angled connectors put into the slots where the bumper bar clicks).
With this setting, you will be able to use this for a toddler and newborn.
I hope this helps.
Oct 28, 2009 | Phil & Teds E3 Jogger
I have been given a near new emmaljunga pram- it's navy blue with the white tyes and blue steel all in great working order. The problem we can;t figure out id how to turn the seat attachment to face the...
Where the seat attaches to the frame (on both sides) there is a lever that you undo to release the toddler seat - the lever is on the handle side of the frame. Unlock the lever by pulling it towards the handle, then taking hold of the toddler seat slide it towards the handle. This causes the toddler seat to release and allows you to tilt it and lift out. Turn the seat around and reverse the process, remembering to attach the "lock end" first. Hope this is clear!
Oct 04, 2009 | Emmaljunga Coronado Stroller
I have a Valco Rebel with toddler seat but I appear to have misplaced one of the round "screws" that attaches the back part of the toddler seat to the pram. Can you please advise where I can get a...
hello i had this problem to i just went to the local hard ware shop with the toddler seat and found a bolt to fit through it and then got some wing nuts because i lost the knob aswell this works fine but i am goin to take the bolt to the lawn mower shop and get a knob to fit the bolt
Aug 04, 2009 | Valco Rebel Jogger
I don't have seat at my home, approximately 8 years old
Yes these can buy these separate at a baby store,I had an extra one.
May 07, 2009 | Baby Gear
Does toddler seat for emmaljunga fit all pushchairs of emmaljunga make - bought pram 2002.
Apr 01, 2009 | Emmaljunga Baby Gear
Can I buy a removable Bumper Bar for my Bertini Shuttle pram??
http://www.bertini.com.au/pages/contact.php
There is their web address. Contact them.
please rate my answer as a fixya!
Mar 09, 2009 | Baby Gear
E3 seat positions
Try using the fully upright (meaning clip the backs) but unzip the sides just a bit or all the way. Also if you need more head support, use one of those carseat head positioners for a little more support. My little one loved getting to ride in the front when big sis wasn't around!
Sep 22, 2008 | Phil & Teds E3 Jogger
Emmaljunga toddler seat
Aug 02, 2008 | Baby Gear
Toddler Seat Accessory
I went to the Valco site and wrote and email to the Support Team and they emailed me the instructions to collapse the Toddler seat with the pram. The pram now 'squashes' nicely!
Jun 26, 2008 | Valco Runabout Deluxe Jogger
Baby Gear Logo
258 people viewed this question
Top Emmaljunga Baby Gear Experts
Jennifer Rock
Jennifer Rock
Are you an Emmaljunga Baby Gear Expert? Answer questions, earn points and help others
