Question about Fagor LFA-019 SS Stainless Steel Dishwasher
Fagor dish washer VFU-05S
F8 comes up on display
Have no manuals
  • rhiannon96 Oct 23, 2008
    I have no instruction manual for Fagor Innova VFU-O5S
    New Friend:
What do I do to overcome the fault 'F3' accompanied by beeping ?
Posted on Nov 03, 2013
Why are my dishes dry with water spots?
may need some rinse agent. verify the liquid level in the rinse agent bottle.
Jun 16, 2014 | Fagor Dishwashers
Need manual for fagor splendid
Here is the manual for the Fagor Splendid Pressure cooker!
Jan 13, 2013 | Fagor Elite/splendid Helper Handle
Fagor lf-017s
the water level float is stuck in the "UP" position
Dec 09, 2012 | Fagor Dishwashers
How do I open the Filter on teh Fagor FWM714 iT
Just had same problem... Just loosen the 2 screws at the bottom and it will open easy . Use an Allen key if you don't have a French Allen key. Mind the water that will come out have a dish ready underneath the opening. Ian
Dec 15, 2011 | Fagor Washing Machines
Hi, my new FAGOR 2LF-013S has no problem fortunately, but i have questions. is it possible i connect the water hose to hot water mains ;if ok; does it lead to power consumption reduction, or any other...
some fagors have a built in water heater (not all) your manual should say so , even so I allways connect my machines to hot supply as yes it's less expensive to use domestic heater for water , the heater inside (if equipped) machine just boosts the temp for cleaner dishes
Sep 11, 2011 | Fagor LFA-013 Stainless Steel Built-in...
My fagor dishwasher is not drying the dishes any suggestions
your heating element is burned out at the bottom of the washer above the sump screen
May 16, 2010 | Dishwashers
you might try here fill in your model and search for user manual download
Mar 28, 2009 | Washing Machines
The correct way to start the wash cycle
we have just purchased a Fagor dishwasher also - the instruction manual is worthless.
in regards to the 2 thin tubes, we just inserted them in the gallon jugs that the soap/rinse agents comes in and it works fine. just make sure the clear tube without the label goes in the rinse agent and the labeled tube goes in the soap jug. we did drill a hole in the top cap of the jugs and pushed the line thru and that helped keeping the tubes in the jugs and minimized the mess if the jugs fell over.
in regards to the temperature problem, we found that running it thru a couple of cycles before you start the actual dishes helped get the water temperature up faster. it seems to like to start with normal tap hot water first, so the 1st couple of cycles get the cold water out of the line.
Dec 29, 2007 | Fagor 24 in. FI-48W Dishwasher
Beeps eight times
Correct - lack of water pressure at the dishwasher, not the same as whether there is pressure from the line going to the dishwasher. There may be a clog or a valve that is closed.
Nov 21, 2007 | Fagor LFA-65 IT Dishwasher
Fagor LFA-019 SS Stainless Steel Dishwasher Logo
325 people viewed this question
Top Fagor Dishwashers Experts
ray gallant
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
