I got a durabrand DBTVI024 and each time i try to watch a channel which is rated tv-14 or above a blue screen appears and says Blocked due to V-guide
I solved the problem by holding the v-chip button on the remote controller for like 30 seconds and then a menu appeared and let me choose to stop the v-guide fonction.
Posted on Jul 15, 2008
How to get full picture on my tv?
First, ensure your tv is using the highest resolution possible (Usually 1080 for flat screens) by using an HDMI cable from the receiver to the television, and that you are on the correct input. Second, ensure your tv is not sizing the video by using the 'picture size' or 'aspect' or 'ratio' key on the remote that came with your tv (Not your DISH remote). Third, tune your DISH receiver (with your DISH remote) to an HD channel (for VIP model receivers, when you tune the channel to an HD channel, an opaque white 'HD' appears insude the blue box at the top of the screen). Fourth, hit the star key on the remote, while watching the screen. On the right hand side, near the top, it will cycle as you hit repeatedly the star key, the style of screen widening. Hit the key as often as you need to make the screen appear the way you want it to. The receiver will remember your setting for all HD channels. When finished with the HD channel, tune your receiver (with your DISH remote) to a SD channel (any channel in the guide that does not have the HD icon). Repeat the fourth step.
For Hopper/Joey family receivers, hit menu, settings, screen size. Follow the instructions to resize your screen to match your preference. When finished, repeat step four above on each an HD and a SD channel.
Mar 15, 2015 | DISH Network Televison & Video
Directv tech support told me to turn off the V-chip on my Sony Bravia TV to program the tv to my Directv remote. How?
SETTING V-CHIP
This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls
and restrictions. This function is to prevent your children from watching violence or sexual scenes
that you may choose to exclude.
Press the MENU button and press the SET + or – button to select the V-CHIP SET option,
then press the ENTER button.
Enter your password (4 digits) using the Direct channel selection buttons (0-9).
In the event of entering incorrect password press the RESET button. Then press the
ENTER button.
Enter the same password for confirmation, then press the ENTER button.
Press the SET + or – button to select the V-CHIP option.
Press the ENTER button to select the ON.
Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press
the ENTER button.
Press the SET + or – button to select the desired rating for the applicable video or TV
channel. Press the ENTER button.
And to change or put in a new password:
NOTES:
• If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD"
option then enter your new password.
• The V-Chip function is activated only on programs and tapes that have the rating signal.
• Once you block a program using the V-Chip function, the blocked program cannot be watched
based on the content of the show. When the program starts, the "INPUT PASSWORD" will
appear on the screen. When you want to release the V-Chip temporarily, enter the password.
If you change the channel or turn off the TV while the V-Chip function was temporarily released,
the original setting will be resumed. If you return to the channel you were watching you must
re-enter your password to temporarily release your V-Chip function again.
• When you watch the TV from the cable box or the VCR with the RF Modulator, then you release
the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The
TV channel is not used in this case.
• When changing the channel with the cable box or the VCR, approximately 10 seconds will
pass until the program appears.
Jan 21, 2010 | Durabrand DU1301 TV
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
HOW CAN I RESET THE V CHIP TO UNBLOCK ALL THE RATINGS
Try this procudure from the manual.
Notes (for TV RATING and MPAA RATING):
● You cannot access the setup menu when the
“PROTECTED PROGRAM by ...” message
appears. Move to an unblocked channel
before you hit [MENU].
● When you select a rating and set it to
[BLOCK], the higher ratings will be blocked
automatically. The lower ratings will be
available for viewing.
● When you set the lowest rating to [VIEW],
all other ratings will automatically be available
for viewing.
V-CHIP SET UP
MENU
To exit the menu
[CHANGING THE
Oct 04, 2008 | Durabrand DWT2405 24" TV
V-chip or parental control
SETTING V-CHIP
ENTER button.
the ENTER button.
NOTES:
End of manual text.
try this thx nick
Feb 07, 2008 | Curtis-Mathis CM32010 TV
Have A durabrand remote and cannot figure out what channel to use to watch dvd's
est1964-I am guessing that your tv is a duabrand, did you try to put in 00 as a channel alot of tv's use this as AV input,if not try to channel down to AV mode this is fairly common.Try that out and let me know,maybe we can figure this out. cooltek Feb.18/08
Jan 12, 2008 | Durabrand DWT1304 13" TV
Duraband tv counting down!
wow is that a joke a 14 in tv????????????? i have no coment for a loser like you
Jan 07, 2008 | Durabrand DWT1905 TV
What do i do about the v guide & how can i get it off??
MY TV BRAND NAME IS APEX MODEL # APT2702 & I HAVE THIS BLOCK THAT COMES UP WHENEVER YOU TRY TO LOOK AT CARTOONS ON ANY STATION. IT READS AS FOLLOW>>>>BLOCK DUE TO V GUIDE , RATING TV - Y 7-FV. PLEASE HELP ME GET THIS OFF MY TV !!!
Nov 24, 2007 | One For All URC4110 Remote Control
Channels blocked
Hello to all, go to your TV menu and go to V-chip set up, then go thru and see that you don't have any channels blocked. If you do and you are watching a show with that rating, you will receive the "protected program message".
Have a great day!
Oct 21, 2007 | Emerson EWC1304 13 in. TV/VCR Combo
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
