Cartridge is jammed, Just clicks steady - Office Equipment & Supplies
  • 11 more comments
  • alfa 155 Aug 03, 2008
    i have a "cartridge jam" problem on my canon mpc 400 printer. can u help??
  • mmmensa Aug 07, 2008
    My printer is doing the exact same thing as hollyharts. Help please
  • Anonymous Aug 24, 2008
    CARTRIDGE JAMED IN DOCK G600 PRINTER .
  • Marvin James Aug 30, 2008
    My MP -730 is jammed in the docking position. I cannot get it to move by pringing or even by opening up the lid like one would to replace a cartridge.
    HELP....Jim
  • Anonymous Sep 02, 2008
    printer just clicks cleaned out reset unplugged nothing
  • Anonymous Nov 05, 2008
    It says the cartridge is jammed but I cleared out the paper (and it didn't rip at all ) and the message is still coming on.
  • rtrask0817 Dec 13, 2008
    the ink cartridge is jammed and all I get is clicks when I turn it on or try to print. How can I get the ink cartridge unjammed?
  • Anonymous Jan 05, 2009
    cartridge is jammed, continuous clicking, no advancement of the cartridge at all, as if something is blocking it's path.
  • Anonymous Jan 09, 2009
    cartridge is jammed after changed black ink and now it just clicks? any suggestions?
  • flowerzor Jan 10, 2009
    mine is doing exactly the same thing however I hadn't had a paper jam or recently changed the cartridge
  • baker738 Jan 17, 2009
    carrage jammed .clicks but won't move
  • jamiemacneil Jan 21, 2009
    I have the hp psc 2410 i had a paper jam, cleared it out, re- installed the printer cartridge and also rest the machine. It still says that there is a carriage jam, and it just clicks and will not move. I also cannot frrely move the cartridge manually . HELP
  • Anonymous Feb 21, 2009
    ink menu says ink not in when it clearly is
Gse123@bellsouth.net
I also have a problem with my MP390. Working fine one day and the next I get a Cartridge Jam message plus it clicks steady. How Can I release Cartridge since it is all the way to the right and will not respond to anything I do? Thanks
Posted on Aug 28, 2008
ON MY CANON MPC 400 PRINTER I GET A "CARTRIDGE JAM" MESSAGE. CAN'T DO ANY PRINTING. CAN U PLEASE HELP!!!!
Posted on Aug 03, 2008
I have the same problem. I bought two new ink cartridges and now the cartridge itself stick and clicks and make all sorts of noise, it's seems it stuck. Yes, I bought the right size ink cartiridges...any help?
Posted on Aug 05, 2008
My dell 1130 has a steady red light
Maybe there is problem with toner cartridge (maybe it is empty or problem with the chip), paper jam or some mechanical problem. Try to take out the toner cartridge and put it back. If the blinking still exist try to replace the chip (or refill the toner cartridge) or check for paper jam. Maybe there is small part of paper - look carefully.
good luck.
Good luck
Jul 24, 2012 | Dell 1130 Laser Printer
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
Indicator is not steady it is blinking.it is not responding to print commands.
Hi
If printer Leb is blinking then you have error in printer check the mention below note.
1) Check the printer door, all door close the properly
2) Check the paper Jam, remove the jam paper.
3) Check the cartridge level, change the cartridge.
Cheer
Jul 19, 2011 | OKI C7350hdn Led Printer
Paper jammed in fuser
Pull the toner cartridge out and leave the door open to relieve the pressure on the rollers.
Grasp the paper close to the fuser and pull gently and steady.
Feb 04, 2011 | HP LaserJet 3055 All-In-One Printer
I have a sheet of paper jammed solidly in the printer - how do I get it out - help, please!
Janet, have you tryed removing the printer cartridge? The paper is usually underneath the toner assembly. Be real careful and use steady pressure and pull gently to get teh paper out. You don't want to **** on it, creating more jams. Look around each roller with a flashlight for small pieces that may have come off also.
Oct 11, 2010 | Brother HL 1250 Laser Printer
How do i get the paper out; it is jammed with 2 pieces.
With firm steady pressure pull the paper out. Take the paper tray out and see if its clear behind it . Open the rear feed and check it also. If necessary remove toner cartridge and check there.
Oct 03, 2009 | Samsung ML 1710 Laser Printer
Printer dosen't print
If you remove the toner cartridge and do not see jammed paper, it's probably jammed in the FUSER. Repost and I can help you remove the fuser.
Jan 02, 2009 | HP LaserJet 1320 Printer
E120 won't print. Orange toner light is on - but the toner is nearly new ...
This problem is caused by an imitated toner............ All you need to do is change it to the old cartridge and see if the light will not be stable. Well the solution i guess is simple............. just go to get a new original toner and it should work well. Hope this helps.
Sep 19, 2008 | Lexmark E120n Laser Printer
Printer frozen- after clearing paper jam-HELP!
Try to reinstall the software, if doesn't work properly the problem is your printer.
Mar 29, 2008 | HP LaserJet 2420 Printer
1,008 people viewed this question
jasbo
jasbo
