Question about Dryers
Changed cord from four wire to three wire on my whirlpool duet and now doesnt turn on
    Genius:
  • 1,122 Answers
Make sure you have the middle wire on the cord connected to the middle terminal on the dryer,the other two it does not matter witch side there on,this should fix your problem ,let me know,thanks-mike
Posted on Jul 15, 2008
4-prong to 3-prong Power Cord Conversion.
On a 4-prong power cord you have 2 hot wires, one neutral wire, and one ground wire. On a three prong cord, you have 2 hot wires and one neutral/ground wire. The difference is the on four prong the neutral wire goes to electrical neutral bus in the breaker panel and the ground wire goes to the ground bus in the breaker panel. Since the neutral and ground buses, although separate, both go to physical ground, on a three-wire setup, you are just putting the neutral and ground wire together, Most dryers actually have a place at the pigtail connection to do just that.
Sep 09, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer has a three wire hook up can i use a four wire cord.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 22, 2010 | Whirlpool Dryers
Our whirlpool Duet dryer has three prong plug and home has four prong outlet. Do we change the cord or the outlet?
You should change the plug at the wall. From your description, your dryer plug has two hot wires and a ground.
Your existing plug probably has 4 wires to it - two hots (120 volts each), a neutral (white), and a ground (green). The two hots are probably black or black and some other color.
You will need to match the plug on your dryer cord with the plug at the wall. The type of plug required should be described in your owner's manual. If you don't have that, then take a digital picture of the plug on the cord of your dryer and bring it to your local hardware or home improvement store. They should be able to match the companion wall plug for you.
Make sure the power is off (important). Remove the existing wall plug. When you wire it back up - this time with only three wires, connect the two hots (black and some other color) to the two hot prongs (terminals) and the green wire to the ground prong. Put a wire nut on the end of the white wire and tuck it back into the connection box. That's it. Turn the power back on and test for proper voltage and wiring configuration at the wall plug before you plug the dryer back in.
If you aren't familiar or comfortable with working on electrical apparatus, you should have a licensed electrician do this work for you. This solution also assumes you are in the USA.
Jan 01, 2010 | Whirlpool GEW9250 Electric Dryer
Plug problem
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 01, 2009 | Whirlpool LER4634J Electric Dryer
Repairing 3 wire drop cord
Sep 09, 2009 | Whirlpool LER5636P Electric Dryer
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Jul 23, 2009 | Dryers
I need to change my eltric cor from a four wire to
The following link explains how to install a power cord for your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Refer to the section that discusses converting from a 4-prong to a 3-prong power cord.
If you have questions, let me know. I hope this helps you.
PS The GREEN wire is ground and gets grounded to the appliance frame.
Jul 06, 2009 | Whirlpool LER4634J Electric Dryer
No Heat
no the four wire cord just has an extra green ground wire,the three pong will work just make sure you have the middle wire on the cord on the middle of the terminal block,let me know how you make out-mike
Apr 02, 2009 | Whirlpool LER4634J Electric Dryer
Four prong plug to three prong plug
Is the receptacle in the wall a four prong or three prong. You will have to match the cord on the dryer to the wall recepticle. If the wall is four prong the dryer cord has to be a four prong. The green wire with the yellow line, that is on the end of the dryer cord, is a cabinet ground and should be attached to the cabinet of the dryer and making good contact. The other three wires on the end of the dyrer cord attach to the terminal block.
Jul 08, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
Top Dryers Experts
