Question about ASUS M2N32-SLI Deluxe/Wireless Edition ATX Motherboard (1254095)
No signal to the monitor
I recently purchased an ASUS M2N32-SLI Deluxe - For some reason I failed to get a video signal - I tested all connections, to include testing the video card in a different computer - I surmised that the motherboard was defective. I just received a replacement board and same issue - ! I do not get video signal - is it hardware or operator malfunction??
I'm pulling my hair already!
  • tony4s Jul 15, 2008
    Tried all that - only other consideration is that we fried the processor while hooking up all the hardware (doubtful but) - any other possibilities??
    thanks for the effort
  • tony4s Jul 16, 2008
    Ack'd - thanks for the effort
Thanks all for the input - ultimately it was the motherboard - a NEW motherboard fixed the problem. As I was told, this particular motherboard was prone to this type of problems
Posted on Oct 18, 2008
Darklord1 you are awesome. I just built a new system and the motherboard was not detecting the video card. Your solution solved the problem.
Thanks.
CW
Posted on Oct 17, 2008
  • 2,427 Answers
Its actually a configuration problem
1.) ensure that the clock speed jumper is set propperly according to your processor
2.) ensure the the cmos jumper is set correctly
3.) check that all jumper settings are correct accorind to your hardware as described by the manual
4.) make certin that all the power cable / s is in propperly, some boards require the main power cable plus the extra 4 pin yellow x 2 black x 2 to poer the processor,, there should be a place to plug it in on the board itself
if that fails then
1.) unplug the system
2.) remove the cmos battery and the rams
3.) press and hold the power button for 10 seconds then release
4.) replace the memory followed by the cmos battery
if that fails
check that your processor is working..
Posted on Jul 15, 2008
  • Rishi Roshan Ali Jul 16, 2008
    Sorry Sir but all i can come up with is hardware and mainboards or graphics card damage ,, thats all thats left, try another monitor to make sure.
I'm looking for a copy of a install disk for a ASUS M2N32-SLI Deluxe motherboard that I can download.
I assume that you are looking for the ASUS drivers, utilities, etc. You can go to http://www.asus.com and select service, support, motherboards, and enter your data to get to your model and select to download drivers. If you are looking for an operating system install disk you have to go buy that.
Sep 20, 2011 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Wont transmit to monitor
Try a different video card frist off,make sure card is seeted in slot good,and check connectors to monitor and board...Cheers
Nov 28, 2009 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
After Bios install primary card not recognised. When booting up monitor turns off. Monitor works with secondary video card
Try reseating the video card.
Also try the card that does not work in the slot of the one that does to test that it is working.
Oct 30, 2009 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
ASUS M2N32 SLI Deluxe - Fans Come On But Board Doesn't Post
there should be a four pin connector from the psu to the mobo,if thats not it try removing memory sticks one at a time, just make sure you leave one in
Apr 09, 2009 | ASUS AI Lifestylestyle M2N32-SLI...
Video Adapter Issue!
The on board video can be disabled in the cmos. Get in your setup and try to find it under "video". Also check your hcl for compatability.
Feb 28, 2009 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
THE AMD PHENOM 9600 QUAD
off course is compatible.
see this page
http://products.amd.com/en-us/RecommendedMBFilter.aspx
if you see for asus there is only 4 motherboards compatible and the last is the motherboards that you propose.
Sergio
Feb 29, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Second display not working
hi check for the BIOS settings for having both the cards work ..if not then try interchanging the card & slots with each other to check if one of it is faulty?
Bye Let me know
Dec 15, 2007 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Open Questions:
Toshiba Virus Removal ' Remove Toshiba Virus - DataAlign ' Call +1888784-9316 Toshiba Corporation is a Japanese multinational company that is headquartered in Tokyo. It produces products and services like information technology, communications equipment and systems, electronic components and materials, power systems etc. Toshiba products are innovative and cost efficient which provides best solutions for home or business use. Toshiba has become the world's seventh largest IT Company which launched its first laptop in 1985. All Toshiba products have the best qualities like high efficiency in very affordable pricing, innovation at its best, ultra- portability with faster working laptops and desktops. As known by everyone, every Toshiba user require good Toshiba Customer Care and thus requires a good customer support. Likewise, Toshiba laptops also require a reliable support for the proper working of Toshiba laptops and desktops over a longer period of time. Dataalign provides best in class Toshiba Tech Support exclusively for the Toshiba customers. Dataalign tech support is provided by the highly knowledgeable and expert technicians who have years of working experience in this field and these tech support engineers have been particularly trained to be able to solve the issues related to Toshiba products. Toshiba Support of Dataalign has following features: 1. Slow speed issues are resolved. 2. Toshiba support technicians of Dataalign analyze the issue very carefully and follow proper trouble shooting steps to get to the real cause of issue for properly suitable resolution. 3. Blue screen of ***** and other errors are resolved. 4. Issues like virus, malware, spyware is resolved accurately. 5. Tech support experts providing Toshiba Support to the Dataalign customers have years of experience in the field of providing helpful assistance to customers with accuracy. 6. Dedicated staff with lots of knowledge makes the support team of Dataalign the best. 7. Customer satisfaction is taken care of every time. 8. Highest productivity is ensured after services to Toshiba laptops. 9. Resolution is provided over remote access so that Toshiba customers can witness the issue and the overall process of resolution applied. 10. Toshiba Customer of Dataalign works 24/7 and 365 days a year. For any kind of help in Toshiba products contact on the Toshiba Tech support number of Dataalign :- +1888784-9316
May 23, 2018 | Toshiba Computers & Internet
See all ASUS M2N32-SLI Deluxe/Wireless Edition ATX Questions
ASUS M2N32-SLI Deluxe/Wireless Edition ATX Motherboard (1254095) Logo
173 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
