Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Problem with recording playback
I cannot start from beginning nor pause a program being recorded on tv1.
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • DISH Network Expert
  • 48 Answers
Reboot the box by unplugging it for ten seconds. You can also call dish and request speaking with Dr dish.
Posted on Sep 08, 2013
  • 51 Answers
I would suggest unplugging the receiver from the power outlet for about 10 seconds and then plugging it back in, do not turn receiver back on, it should come up on its own after a few minutes, if it doesnt wait another minute and then press power, it will reacquire signal and then you can try again. is this issue only effecting tv1???
Posted on Aug 07, 2008
How to dub tape to tape
Hi Dale,
You're kind of light on details of the equipment you're going to use - so the best I can do is provide generic instructions. You'll need two devices - one must be able to perform playback for source media and the other for recording or copying duties. Inspect the jacks provided on the rear of both units. Most provide standard RCA type "Phono" jacks for left and right audio channels. Connect a stereo patch cable (with plugs that match the jacks of the playback and recording devices) between the left and right OUTPUT (or "PLAY") jacks on the source device and the left and right INPUT (or "RECORD") jacks on the recording device. Insert the source tape, cd, album, etc. in the device that will playback the original and insert a high quality blank media into the device that will provide recording capabilities. Begin playing the source. Set options such as tape bias, Dolby Noise Reduction, etc. on both source and recording devices to match media in each. Advance the playback source to a point that contain the loudest sections. Set recoding levels by monitoring the VU meters on the recoding device and vary the input adjustment levels so that only the loudest prortions of the program just begin to briefly "flirt" with the 0Db or red zone of the meter. Signals that cause the meter to indicate into this area and beyond begin to overload the amount of information that can be recorded on the blank media and often result in muddy audio quality during playback, later. You should also record the same section repeatedly with differnt options (bias, noise reduction, etc.) to actually hear the difference to determine which sounds best to you. Once levels are set, queue the playback device and start recording. In the case of tape, allow enough recording time to let the leader section of the tape to pass beyond the recording heads for several seconds or more. Once the desired amount of silence has elapsed, play the source program. Allow it to run to completion using both sides in the case of tape and then playback the entire new recording to make sure it recorded without any issues.
Apr 09, 2015 | Televison & Video
My dvr shows a 1hr program fully recorded, and begins playback fine. After almost 10 min playback ends but when paused, continues to show another 50 min available.
Hello! Daniel Busa with Dish Network here. That actually happened to me about a month ago a hard reset resolved it for me. If that doesn't do it try deleting all of the recordings that don't play back correctly,reset it again and keep an eye on things, it may be a bad box.
Nov 10, 2010 | DISH Network ViP722 DTV Receiver /...
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
Option window will appear.
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
Timer Programming
Auto Finalize
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
Using [
K / L], select “VCR DVD”. Hit [ENTER].
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
VCR to DVD duplication will start.
C] to stop the
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Well... If you are looking for the pause function for the playback kepp reading. if you are trying to pause while filming go to the next paragraph.
It is verry unfortunate that while you are trying to view your video on your camcorder or while hokked into your T.V. there is no way of pausing. You can only stop and play your video and once you stop it it will restart at the beginning of the recording. To view it better and have more controll over all of the settings your best bet is to attach it to your computer,
Now if you are trying to record something then want it to stop recording all you need to do is press the little button with the picture of the video camera once more,as soon as what you want to record is complete. This will stop the recording untill you press it again when you want to record something else
Dec 25, 2009 | Vivitar DVR 865HD High Definition...
Cannot operate svr-925 digital recorder, need manual
How to Record:
1. Make sure HOLD switch (on side of unit with pocket clip) is set to off position (slide to right is off - to left would be hold)
2. For best results set unit with mic(rophone) which is on top of unit toward sound source and press REC/STOP button (Top button on front of unit just below LCD display). Recording will begin and will be indicated on LCD display.
> Red Record LED will be on and the message number, recording time will be displayed on the LCD.
3. To stop recording, press REC/STOP button one time.
* If no other buttons are pressed within 1 minute at stop position, it will power off automatically.
4. Pause during recording by simply pressing MODE/PAUSE button- press button again to resume.
There is a Voice Operated System (VOS) Recording button on left side also. You can record with voice activation to conserve recording space but I have found that you lose a portion of the recorded sound as it activates and if there is no sound for a very few minutes the unit powers off and you will get nothing further recorded. I recomend just keeping VOS in off position.
5. To erase a recording: Select the message number you want to erase and while it is stopped (the message number will appear in LCD with the length of recording showing also)
Press and hold the ERASE button until the LCD begins blinking "ERASE" then, while it's blinking simply press the erase button again and the recording will be erased.
6. To play back a recorded message find your message by "toggling" the switch on the right side of the unit that says INDEX. That switch is the fast forward/reverse play etc. To Play simply push the switch in. This button/switch takes a little practice to use but the Play portion is straight forward. Use the front buttons to pause and stop during playback.
Hope this helps.
Jan 04, 2009 | Sims SVR-S825 Handheld Digital Voice...
Problem with DISH DVR 625
You can accomplish this by either going to the specific TV and selecting the record option at the time the program is about to come on or you can press menu-8-5 and change the record preferences. You can either set the DVR to record programs to the TV2 location by default or TV1 by enabling the record plus feature. In dual mode without record plus enabled all programs you select to record default to the tuner you are viewing e,g, if watching tv1 and selecting to record a program in the future it will record to the tv1 location.In single mode all recordings default to tv2 so you can continue to watch live tv from tv1. I hope this answers your question and thanks for using Fix Ya. Let me know if I can further assist you.
Dec 14, 2008 | DISH Network DVR-625 DTV Receiver /...
How do i choose tv1 or tv2 on my DVR?
Your recording will record onto your one DVR box, for playback on either tv. On many satelite boxes you have to search for the program you want by entering the name. Then select the program and select to record the future broadcast.
Dec 07, 2008 | DISH Network DVR-625 DTV Receiver /...
Phililps DVDR5570H only plays zone 4.Is there an unlock code for multizone playback?
Try this:
Models supported:
  1. Power on the recorder
  2. Wait for player to initialise.
  3. Press [HOME] on the remote control.
  4. Press [PLAY / PAUSE]
  5. Key in 1 5 9 1 2 1 2 1 2 0 0 5 2 5 5 – The numbers will appear in the display of the recorder.
  6. Press [PLAY / PAUSE]
If the recorder goes into browser mode during the procedure, then it will need to be re-started from the beginning.
If at any point the recorder is reset to factory settings, then the procedure will need to be carried out again.
Jul 27, 2008 | Televison & Video
Dear lost366,
The problem lies with micro IC (cpu IC) . This has to be replaced. Please contact authorised service centre.
Jun 15, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
