Question about Motorola Mobility RAZR V3
Key Pad malfunction
Some of the numbers on the key pad don't work? Any ideas on how to fix the problem.
Thanks.
Luciana819@comcast.net
    Scholar:
  • 87 Answers
With a T6 torx screwdriver, remove the two screws you will see under the battery cover towards the bottom of the phone. Once the screws are removed, gently lift up where the battery contact terminals are, GENTLY. The main flex bends and plugs into the board right there. With a small flat tip screwdriver, unplug the main flex from the motherboard. Once this is unplugged, work that back piece slowly until it comes off. The main motherboard will come with it.
I would just about bet you will see some corrosion where the main flex plugs into the board. Use some rubbing alcohol and a toothbrush to clean both the plug and the end of the main flex. Let dry completely, reassemble and see what you get.
You may also have some corrosion in the top 1/2. You can get into it by removing the 4 rubber bushings at each corner around the main inner lcd, and then remove the 4 T5 torx screws. Once the screws are removed, close the phone and hold it looking at the outside screen with the camera on top. Start working the outer cover off at the top by the camera lens. With the screws out, it is just snapped on.
Once that outer cover is off, you will see upper plug for the main flex on the upper left. Unplug this and clean the plug and the end of the flex the same way, rubbing alcohol and toothbrush.
Preferably 91% rubbing alcohol because it evaporates cleaner.
If this isn't something you want to try yourself, I recommend Wireless Unlimited - Cell phone and computer repair.
www.wirelessunlimitedinc.com
www.myspace.com/wirelessunlimited
423-913-0488 10a-6p M-F EST.
If you mail it to them, they can have it fixed and back in the mail to you the same day they recieve it.
Posted on Aug 21, 2008
Some keys on number pad don't work (2,5,8,0)
You should just bring it in to a pc shop and have them replace the keyboard.
Jun 27, 2012 | Computers & Internet
Number pad keys don't work
Hi
if only the numeric keys working its possible you had a battery leak or some liquid, if you can open the unit and check inside if you'll see acid or spots then it needs repair if this is not the case and it happend after the clear ram try to install the software , if this doea not help its an Hardware failure
This problem can be fixed let me know if you want to fix the Calc
Jun 14, 2012 | Texas Instruments TI-84 Plus Calculator
Pcr265 register keeps doing 55555 like that all the time
Hello, Thanks for allowing me to help you.
Many times this can be caused by a key being jammed into the button pad under the keyboard assembly, witch would need repair.
But what you can do is lift the number 5 key up off the pad a little using a flat head screw driver , you don't want to break it but if its jammed down then this is what the issue is. You looking at a repair here witch depending on the actual cause weather its a key jam or a defective board under the kay. I would first have you check the number 5 key to see if its being depressed into the pad.
Hope this does help.
Best regards,
rulds2008
Jun 15, 2011 | Casio Parts Cash Register PC Desktop
Need tv code for Quasar LSSQ0227 its a comcast
had this problem myself and I assure you that a) Comcast is populated by idiots without training, and b) that Quasar hasn't 'deliberately designed' their tvs to not work with Comcast remotes, which is what Comcast will tell you.
Solution: Add a 1 to the code, ie 10250, 10051 etc. Quasar is a 5 digit code, not 4 as Comcast believes.
Feb 06, 2010 | Quasar VV-1302 13 in. TV/VCR Combo
I was looking on the genie web site on how to change my pin on the key pad. Evidently it wasn't the same key pad. Now my key pad doesn't work at all. How can i fix and do the or original job I started out...
There are many outside keypads and all are different to program. If you go to genie.com or overheaddoor.com(owns genie) there will be a helpline number that will walk you through this. Thanks BB
Jan 09, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Nokia N73 number 2 key not working.
hell there! I want u to try this small antidode get the key pad membrane cleaned which is under the key pad . coz some kind of carbon forms after a period of time or liquids to can cause this too.
lastly if no change change the key pad membrane .
Get a technician to do this for u
have fun
good luck
Sep 08, 2009 | Nokia N73 Cellular Phone
My nokia 6233 keypad is malfunctioned.. the numbers"369,end call and #" are not functioning.. but the other numbers are just ok..what will i do?
Buy a new phone if you realy want to fix that on you will need a new keypad it cost alot to fix maybe more then the phone itself but if you really like it you should fix it.To me its not worth fixing
Aug 01, 2009 | Nokia Cell Phones
GE 900 model no 26938GE1-D key pad
ok pop the phone apart and wipe the gew off the back of the pad and board throw it back to gether and its good as new
Oct 31, 2008 | Lands Phones
Keyless key pad entry code
Ford cars and such will put a sticker on the hinge or back gate with the numbers on it. It will just be a white sticker with black numbers. A five digit code.
God Bless Greg
Jul 16, 2008 | 2003 Ford Windstar
Number Pad not working
I would try re-seating the keyboard cable
http://www.priorityelectronics.com/images/pop_3f4800ef5205420fabcba8488924da5b.jpg
notice 2 screws at top holding the keyboard.
Feb 20, 2008 | Acer NSK8458AN Keyboard
Motorola Mobility RAZR V3 Logo
42 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
