Question about Refrigerators
The water tube in my GE (side by side refrig) ice maker keeps freezing. When the ice tray does not get the water, it calls for more. the water ends up spraying all over the inside and freezing because the tube keeps freezing up. If I take the tube out once a day I can sometimes prevent this. I can never leave the ice maker on for extended periods of time. I have lowered the freezer temp and reduced the water feed to try and help but this has not helped.
  • 1 more comment
  • jasper31 Jul 15, 2008
    I had used your site before to correct another problem with the ice maker. My problem was that water was dripping out of the ice tubes and freezing in the ice maker container. I was told to lower the water pressure because there may have been too much water coming into the unit. So now your saying turn up the water pressure so it doesnt freeze. I beleive my old problem will resurface. Also I am not clear on what you are telling me to do with the tube. Can you go into further description?
  • jasper31 Sep 17, 2008
    I have solved the problem with a local repairmen. turns out that there is a module that controls the water flow. If that module does not close all the way, it will slowly pump water in little dropps to the ice maker. this is what cause the freezing. The module was not closing because i have small particles of dirt in my well water and those particles would not allow the module to close all the way. I replaced the module and added a filter to stop the dirt and i have not had a problem since!!!!
    no, I solved it myself but you should add my correction to your sight to help others with the same problem
  • 1,543 Answers
I'd say that micbeth1981 has some good thoughts on this one. I'd also suggest checking to make sure the tube that extends from the exterior of the freezer into the icemaker fill cup may be too long, thus touching the fill cup. Make sure the tube ends in the middle of the fill cup area. Cut the tube shorter if necessary.
Posted on Sep 17, 2008
    Genius:
  • 1,122 Answers
It sounds like you have a air leak somewhere around the supply tube,try looking on the back of the frig. and make sure everthing is tight on the back,and if you have ice in the door look up in the chute to make sure the flap is closing all the way,also check the top of the freezer with a dollar bill,put it in between the gasket and the freezer,now try pulling it out slowly,if it comes out to fast the top of the freezer gasket might be loose,let me know what you find,thanks-mike
Posted on Jul 15, 2008
  • MIKE major Jul 15, 2008
    kevin000 is way off,he thinks your freezer drain is clogged,disreguard his advise
    Genius:
  • 1,847 Answers
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
GE Refrig. Water leaking on floor after ice maker stopped
look at water delivery tube to the ice mker . it has iced over and pluged up causing the water to go out the back and down on floor . . clear the water tube with hot water and problem is over . .. some models cah use a updated water tube. mm
Jul 16, 2010 | GE GSH25JFR Side by Side Refrigerator
GE Profile Refrig model PSC23SGRC ice maker stopped making ice. Water is ok, just stopped? Is this common? Its only 4 yrs old
Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes aand then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
Jan 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
The line to our ice maker is frozen solid with ice. Do you know how to get the ice out of it? I'd prefer to not have to defrost the whole thing.
Pull the refrig out from the wall and you will see where the single tube to the ice maker goes . Try removing the line housing straight out the back , and thawing at the sink . Or , 2 screws hold the ice maker on . Remove the ice maker and thaw the line with a hair dryer . You will need to replace the water valve ( the piece the wall water line connects to on the refrig ) due to a seeping problem . When the valve does not close completely , drops will seep into the fill tube and freeze , thereby , blocking the normal rate of water , entering the ice maker .
Nov 11, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE adora side by side refrigerator DTL181C5RRBS
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maKer is not getting water but the water side works.
Your refrig water valve , has 2 coils on one valve . One is for the water dispensor , and one is for the ice maker . So even if you get water thru the dispensor , the other coil ( for the ice maker ) could be bad . The fill tube from inside the freezer to the ice maker , could be frozen solid , keeping the water from entering the ice maker . This frozen tube , would be caused be the water valve " seeping " , which means , it isn't closing completely , and drips freezing inside the tube . indicating a bad water valve . Pour about 2/3 cup of water into the ice maker . If it dumps , but doesn't refill with water , replace the water valve but also check this tube . If the ice maker does not dump the frozen cubes , replace the ice maker , but also check the coils under the refrig , for dust , lint , etc , needing to be cleaned off . The ice maker needs to be 5 degrees to operate , and dirty coils can keep the freezer at 6 degrees or above .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a GE Profile refrig, circa 1995. The ice
If you are sure it is caused by the ice maker or if it is not it can be fixed. The only way an ice maker would leak like that is if ice is blocking the inlet tube and when the water comes on the water is spewed in a different direction than the ice maker. Most times this is caused by a slow leak in the water control valve for the ice maker side at the rear of the refrigerator. You can stop the problem by melting the ice in the fill tube with a hair dryer and keeping an eye on it until you see ice beginning to build up there again. That would indicate a slow leak in the water control valve that is not closing all the way when off. The other reason for large pools of ice in the freezer is a frozen over defrost condensate drain behind the cover in the rear of the freezer and would require you to unplug power and remove the rear panel. I will try to get some photos and a link shortly that covers that problem a lot more in just a few minutes. Sea Breeze
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I ice maker keeps freezing in our side by side GE fridge.
This annoying problem can have a variety of causes. Check these four things first:
  1. Make sure the water supply is greater than 20 psi. If too low, thewater valve won’t seat properly and it’ll “weep.” Common causes of lowpressure are gunked-up saddle tap valves, kinked water supply line, andusing a reverse osmosis filter to supply water to the icemaker.
  2. Check between the valve diaphram and valve seat for sediment. If found, do not attempt to repair, buy a new valve.
  3. Check to see if the black, flexible portion of the fill tube iswrinkled, twisted, or kinked which can cause ice dams that block thefill tube.
  4. Find out if the water has been shut off while the icemaker has kepton cycling. This, too, can cause the fill tube to freeze up.
If all the above checks out and you’re still getting fill tube freeze-ups,then best get a service guy to take a look. It could be a complicated repair.
Jun 24, 2009 | Whirlpool ED2FHEXN Side by Side...
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
Ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Jun 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
